Double Action Air Brushes
    September 2013
Posted by Tangomikespe on Saturday, September 14, 2013 11:52 AM
I ahve a pasche single action AB, would like to upgrade to a double action.
Any recommendations?
Posted by Don Stauffer on Monday, September 16, 2013 9:20 AM
The old Badger 150 is still an excellent airbrush and not too expensive.  One thing I like about Badger brushes is that they are not too finicky and really last a long time with few parts replacements needed other than the cheap and readily available teflon washers on some models.
    March 2012
Posted by mustang1989 on Monday, September 16, 2013 9:35 AM
I'm still learning the double action airbrush thing but I am learning using a Badger 150. So far I like it but its a definite change from the "safe zone" Badger 200 I've been using.
 Forum | Modelers Social Club Forum (proboards.com)
Posted by Tojo72 on Monday, September 16, 2013 10:23 AM
I always say Badger 150,been using mine for 15 years
mgh
    May 2011
Posted by mgh on Monday, September 16, 2013 1:09 PM
I have an Iwata HCS that I absolutely love, but it is the only one I have used, so cannot compare it to anything else.  I will say that finally getting a dual-action was the best decision I ever made.  Lots of people do far better work than I can, and do it using a single-action, but for me the dual-action is far easier to use.
From everything I have read, either the Badger or the Iwata would be a good choice.
    November 2010
Posted by john087 on Monday, September 16, 2013 1:32 PM
I also recommend the iwata. I have the eclipse. It was my first and is my only airbrush. Very easy to use and clean.
Posted by Bish on Monday, September 16, 2013 2:22 PM
I have had my Badger 150 for years. I have recently got a 100, basically the same thing but gravity feed. As long as its clean right, I have never had a problem with them.
    February 2015
Posted by Bick on Monday, September 16, 2013 4:42 PM
I used a Badger 150 for many years - a great airbrush but after trying a gravity feed brush, I switched to an Iwata Revolution CR and now an H&S Evolution Silverline. It's really personal preference but I think, among quality brushes, the choice between gravity feed and siphon feed is the more important decision. Siphon feed AB's, for ME, are more difficult to keep clean (paint containers partcularly) - cleaning the needle/nozzle is similar for either type.
    December 2011
Posted by Chrisk-k on Tuesday, September 17, 2013 12:07 AM
Iwata Eclipse
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    October 2008
Posted by P mitch on Tuesday, September 17, 2013 5:04 AM
I have two badger double actions brushes and both are great, the 150 as a siphon and the Renegade Velocity. The Velocity is rapidly becoming my favorite but it is expensive. Have a look on Ebay for an old 150 as long as you give it a good clean you should be fine with that
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    August 2009
Posted by denstore on Tuesday, September 17, 2013 4:33 PM
I agree with Bick. Most quality brands are good, and the focus should be on deciding on gravity, side or siphon feed. Since you already have a single action, the large surfaces are covered, and a gravity fed airbrush ought to be the best complement. Alternatively, a side fed airbrush could be OK. They are a bit best (and worst) of two worlds.....
Better an airbrush in the hand, than ten in the car....Stick out tongue
