Not sure I have the hang of preshading yet...
    January 2015
Posted by TheMongoose on Monday, November 28, 2016 8:35 PM
I'm practicing on the engine exhaust for my 1/32 F-4E Phantom. I thinned testors flat black and sprayed it in the creases of the exhaust. After it dried I thinned testors steel 60/40 thinner to paint. I put 2 light coats on with my airbrush at about 8psi. There are some shadows but I feel like it's covered up too much. Haven't done this before so would appreciate some other opinions if these pictures are clear enough.
1st coat
2nd coat
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    January 2009
Posted by fermis on Monday, November 28, 2016 8:45 PM
Metalic colors cover everything. So, it's not you!
For metals, like in this instance (I use MM Metalizers), I start with "burnt Iron"...nice and dark...then fill in/highlight areas with lighter colors...Steel, Aluminum, etc...leaving a little bit of the darker color where I want it. A very fine airbrush helps. Mine will spray a dot, about an 1/8th inch, sometimes a little smaller. Low pressure and very close to the part....very steady trigger finger!
    July 2014
Posted by modelcrazy on Monday, November 28, 2016 9:23 PM
Don't worry, I don't have preshading down either.
Steve
    January 2015
Posted by TheMongoose on Monday, November 28, 2016 10:02 PM
fermis i'm 1 for 2...i can make a line that narrow but I've lost the steady hand. More practice required. I'll try some aluminum over it tomorrow and we'll see how it looks.
modelcrazy im a glutton for punishment i guess. I'm determined to figure this out lol
    March 2010
Posted by Nathan T on Monday, November 28, 2016 11:03 PM
One brand of metallics that work real well over preshading is Alclad. They are pre thinned in the bottle.
