I got the idea to use SuperClean, from a thread at AgapeModels, in which someone demonstrated using it to remove the chrome from the Tamiya chromed P-51D kit. I was building the Monogram Red Baron hot rod at the time, and I wanted to strip the chrome from all of the chromed sprues. Yes, insane, but AMS kicked in, and I needed to be able to clean up seams and sprue gates, so, I was going to repaint everything anyway.
I used an old glass baking dish, round, about 9 inches across. I poured some SC into the dish and placed one of the sprues in the bath. Within seconds, the chrome began to dissolve into the solution. In two minutes, the chrome was gone, and what was left was the styrene, literally squeaky-clean.
From there, I tried it on some old metal figures that I bought for repainting. I found that paint took a little longer to soften and dissolve than the thin layer of chrome plating did, but still, in about 5 minutes, paint had dissolved into the solution, and I removed the piece. The paint rubbed off, and rinsed off under a faucet. I used an old toothbrush to scrub away more stubborn spots. I needed to do a little picking at relief areas to remove the paint embedded there, and I have since found that I'll do a couple of passes when removing paint. But when I used oven cleaner, I had the same experience, and that required good ventilation and gloves. It's a good idea to work in a well-ventilated environment, anyway, but SC is not nearly as caustic or volatile. I use glass jars of various sizes and keep several batches going at any given time.
As far as spot-removal goes, removing paint from a specific spot, while preserving the surrounding painted area, here is a figure on which I had to do that. I messed up her one eye:
and I didn't want to strip the whole figure. So I used an old paint brush to apply some SC and I was able to remove the paint just from her face:
It took a couple of passes, and I had to be careful, but it worked pretty well. Here's where that figure is now, by the way:
I just find it particularly easy to work with, and since a batch can be used over and over, it's cost-effective, at arond eight bucks a gallon at WalMart. And since it's a de-greaser, it has household cleaning uses, even.....cleaning the oven.
I haven't abandoned other solvents completely. I still use mineral spirits and lacquer thinner, or water or isopropyl, as appropriate. But for stripping paint, this is what I now use.
