Thinning Tamaya
    September 2007
Thinning Tamaya
Posted by Pie Man on Thursday, October 11, 2007 10:29 PM
Hi,
 I just want to know whether you can use water to think Tamaya acryl, i just really dont want to screw up my new AB!!!Smile [:)]
Thanks
    December 2003
Posted by hkshooter on Thursday, October 11, 2007 10:50 PM
Be best to use Tamiya thinner. You can't go wrong with it. Isopropal alcohol in a pinch. I've never tired water to be honest, so I don't know what you'd get but it won't hurt your AB. You could pee in it to thin if you wanted and the AB won't know the difference. What WILL be affected is 1) the AB's ability to spray it reliably, and 2) the look of the final finish. IMHO, for the nickle I'll spend on it per kit Tamiya's thinner is the only way to go.
    August 2005
Posted by Phil_H on Thursday, October 11, 2007 11:10 PM
Water tends to break down the adhesive properties of Tamiya paint. It also increases its tendency to bead rather than flow, and thats definitely something you don't want.
As previously suggested by hkshooter, use Tamiya thinner for best results. Alternately, IPA. I have used methylated spirits, which (in Australia) is 95-98% ethyl alcohol and add a drop or two of acrylic retarder to the mix.
I have found that Tamiya paints, particularly the flat colours,  can be thinned far more than what most people suggest. It's not unusual for me to go 4:1 thinner to paint for base colours, or 1:1 when I need denser coverage.
As far as water goes, I only use it for cleaning up afterwards.
I'll go a little further to add that thinning ratios are only a guide, they are not set in stone. Viscosity can vary from one colour to another and from one production batch to another. Even if you buy two jars of the same colour, if you leave one on the shelf unopened and use the other to brush paint for an hour or so, evaporation of thinner out of the open jar will mean that the used jar is "thicker" than the new one. So thinning ratios can be a rough guide, but in the end, thin it to the consistency that works for what you are doing.
    September 2003
Posted by Daywalker on Thursday, October 11, 2007 11:58 PM
I have to agree, Tamiya thinner is by far your best option.  I use it to thin my Tamiya and Gunze, and use 91% isopropyl alcohol to clean my AB.  Works a treat! Thumbs Up [tup]
Frank
    September 2003
Frank
Posted by MikeV on Friday, October 12, 2007 12:26 AM
There are cheaper alternatives that may yield great results.
My friend Greg (Plasticmod992) told me he prefers Ethyl Alcohol 70% with Tamiya paints and it has worked great for me so far.
DHM
    September 2007
Posted by DHM on Friday, October 12, 2007 5:09 AM
I also use Tamiya thinner (X-20A) and have always had good luck.  I have also found that isopropyl alcohol works well, but add a drop of acrylic retarder or you may have big tip dry problems because the alcohol speeds drying times.
    January 2003
Posted by Triarius on Friday, October 12, 2007 10:21 AM
There are two options for thinning Tamiya acrylics.
Tamiya's proprietary thinner, which I have been told is 90% alcohol with a retarder added, although I have not checked the MSDS.
Isopropyl alcohol, 90+%. This is much cheaper than the Tamiya thinner. However, if you use it to reduce (commonly, thin) Tamiya for spraying, you should also add a tiny drop of acrylic retarder, such as those made by Golden, Liquitex, etc. available from any place that sells artist's supplies. This is by far (about 500%, IIRC) the more economical route. It also has the advantage that you have the retarder handy for brush painting. (Do not add retarder, alone, directly to the paint. Mix it with isopropyl first or it may cause the paint to do funny things.)
For brush painting, add a tiny drop of retarder to a small amount of isopropyl, dip your brush in that before you dip it in the paint, and each time you load the brush. Never brush paint directly from the jar.
    September 2007
Posted by Pie Man on Sunday, October 14, 2007 9:09 AM
Hi Guys!!!
Thanks for the great responses!Make a Toast [#toast]
 I think i will try some of the other ideas such as the Metholated spirits rather than going out and paying for the thinner.
Thanks again!Smile [:)]
    August 2007
Posted by ben1227 on Sunday, October 14, 2007 11:17 AM
You said methylated spirits is ok to use for thinning Tamiya's...Here in America I think they label it as Denatured Alcohol, which is mainly ethanol denatured with methanol. Does it thin any differently than normal isopropyl alcohol? Iso has either 30% (if you buy 70% alcohol) or 9% (if you buy 91% alchol) water content, not pure alcohol.
.:On the Bench:. Tamiya 1/72 M6A1-K
    January 2003
Posted by Triarius on Sunday, October 14, 2007 11:41 AM
Yes, denatured alcohol will behave differently with Tamiya paints, and is marginally incompatible with some of them. It also evaporates much faster than isopropyl of either concentration.
Use 90% isopropyl. If you want faster evaporation, add a little denatured or methyl alcohol. If you want slower evaporation, add a little distilled or deionized water.
Don't use the 70% isopropyl, as you never know what is in the water used to dilute it. Most 70 % stuff is shipped as 90% or higher, then diluted locally with tap water. Some of the things in tap water that are perfectly fine to drink will play hob with paint.
    August 2007
Posted by ben1227 on Sunday, October 14, 2007 11:49 AM
Ok, I guess I'll just keep using 90% Iso...I sometimes get tip dry though because alcohol evaporates, so I could add a little distilled water to slow down evaporation?
    June 2006
Posted by MaxPower on Sunday, October 14, 2007 3:00 PM
I'd just go to your hobby shop and get Tamiya thinner. The big bottle was $10.99 and I'm half way through it in 18 months! It's great stuff and I have never gotten tip dry with it.
    January 2003
Posted by Triarius on Sunday, October 14, 2007 7:04 PM
Add one small drop of acrylic retarder and kiss tip-dry adieu. Golden, Createx, Liquitex, whatever. A bottle will cost you less than $ and last a lifetime.
Isopropyl 90% is what, $3.00 a bottle for 12-16 oz? Just do the math.
    August 2005
Posted by Phil_H on Monday, October 15, 2007 9:38 AM
Here in Aus, IPA seems to sell at about $10.00 (Aus) for 250ml and seems difficult to get hold of. On the other hand, methylated spirits (ethanol) is about $3.50 per litre at the supermarket. I'd like to try IPA if it were more readily available.
I haven't encountered any compatibility problems when using ethanol as a thinner. None that I've noticed anyway.
It does tend to "flash dry" very quickly, but perhaps my higher than "normal" thinning ratio and the addition of retarder helps in this regard. It also helps that I am spraying from no more than 4 inches max, though thats more because thats how I've come to do it rather than any sort of allowance for the medium.
It's worked ok for me so far. Big Smile [:D]
Posted by Anonymous on Monday, October 15, 2007 12:24 PM
Hi can someone please help ? What ratios of paint and thinners do you use ?
I have been using 4 or 5 paint to 1 thinners. I have used 1 and a half xf59 on a tank alreday and i have only done the bottom half  Boohoo [BH]
Also, should i glue the shovels and guns etc on the tank paint it all xf59 ( yellow) and repaint them after it has time to dry, or paint them before and then glue them on after the hull colour
Thank you
    May 2005
Posted by Bgrigg on Monday, October 15, 2007 12:47 PM
Typically I use 2 or 3 parts paint to 1 part thinner, but Tamiya's XF line can endure even thinner than that. I've heard of people using 1 to 1 or even 1 part paint to 2 parts thinner!
What I really look for is the consistancy of 2% milk.
For the second part the correct answer is "depends"!  Both ways are typical, and depends on the ability to paint all sides of the part when they are glued in place.
So long folks!
    January 2003
Posted by Triarius on Monday, October 15, 2007 7:20 PM
PhilH,
Yipe! Well, if it works for you, great! As with almost everything airbrush: YMMV.
To add to what Bill said, I'm one who frequently thins Tamiya 1:1, or near that. Again, the apparent consistency of 2% milk.
    August 2007
Posted by ben1227 on Monday, October 15, 2007 8:18 PM
I'm going by the 2% milk rule and it seems to work great...It is true that you can get Tamiya very thin. I accidently squeezed to much thinner in once, and it was almost a below-watery consistency, but it still airbrushed ok. I remember someone telling me not to do this, but I thin with Windex sometimes. I get horrible tip dry if I thin MM Acryls with Windex, but Tamiya does fine for some reason.
    January 2003
Posted by Triarius on Monday, October 15, 2007 9:48 PM
That someone who told you not to reduce Tamiya (or anything else) with Windex was probably me. You are a braver man than I , Gunga Din.
I would worry about long term stability of the Tamiya reduced with Windex. OTOH, some latex paints do use ammonia compounds as co-solvents. It is possible that Tamiya is a latex modified acrylic, or (less likely) an acrylic modified latex. The former would explain it's tendency for tip-dry and its odd reaction to retarder under the wrong circumstances. (Don't ask. Here there be dragons.)
    May 2005
Posted by Bgrigg on Monday, October 15, 2007 10:00 PM
Ross, you should change your avatar location to "the white space on the map"! Laugh [(-D]
So long folks!
    January 2003
Posted by Triarius on Monday, October 15, 2007 10:13 PM
No, it's the black space on the map… Alien [alien]
(updated)
