template question....
    February 2006
Posted by Wulf on Monday, November 26, 2007 9:36 AM
Looking for a method to create a perfectly round circle mask for painting Japanese insignia. I've tried the trace and xacto route with little success.
Andy
Posted by ABARNE on Tuesday, November 27, 2007 12:27 AM
I've made round masks quite using an Olfa circle cutter and Tamiya tape.  Essentially, it is a beam compass with a blade in place of pencil lead.  I think I picked it up at Michaels.  I found it pretty easy to use, cutting the tape on a self-healing mat.  Its main limitation would be the minimum diameter which would be around 1/4" or 3/8".  I have a 1/48 Zero-sen, and I plan on using it for the insignia.
Another AndySmile [:)]
    April 2005
Posted by wing_nut on Tuesday, November 27, 2007 6:31 AM
Andy all you needs is one of those green circle templates from Staples or Office Depot.
Cut 2 at once crossing the tape for easy seperation. Cut on glass with a new #11 blade from nice sharp edges.  Draw the reference lines on both to help with alignment on the wing/fuselage.  Cover the hole with a piece of tape before you peel it up and it will stay nice and round while you position it.
The template is good to have around for rescribing too.
Marc
    February 2006
Posted by Wulf on Tuesday, November 27, 2007 8:03 AM
great idea...thanks for the help
Andy
    September 2003
Posted by Daywalker on Tuesday, November 27, 2007 10:59 PM
Great tip Marc, thanks for that! Thumbs Up [tup]
Frank
