What glue to use and when?
    April 2016
Posted by Luftwaffles on Sunday, May 15, 2016 12:00 AM
Currently, I have 2 glues in my arsenal: CA (Loc-tite) and Tamiya Extra Thin.
If I'm building a model, in what different situations should I be using the different glues? Should I just mainly use Tamiya E.T., or should I be using a different viscosity or type? I know CA isn't the best at long-term durable blends.
What do you suggest for small parts (1:72) and for larger 1/35 armor?
Thank you all in advance for your advice.
Sincerely,
Joshua
    July 2013
Posted by modelmaker66 on Sunday, May 15, 2016 12:30 AM
tamiya extra thin on all styrene and ca glue on non styrene.
Posted by Tojo72 on Sunday, May 15, 2016 11:08 AM
I have found that Tamiya Extra Thin works for about 99% of my needs,once in awhile I will use a super glue type.
Posted by Don Stauffer on Sunday, May 15, 2016 11:12 AM
I keep a number of glues on hand.
My go-to glue is Loctite gel CA.  The gel CA is somewhat gap filling- the parts do not have to fit together perfectly, and it sets slower than the thin stuff, so I have a bit more working time.
I use the same brand of the thin CA, where I have a perfect fit and do not need extra working time.
CA will fog transparent plastic, so I use the window cement for those- the stuff that is like white glue- for canopies and stuff that is installed from the outside. For windows such as airliner and bomber windows that are inserted into the inside before closing the fuselage, I use epoxy for a very strong bond, because if one of those pops loose you have a real problem!
I will sometimes use solvent cement for a very long seam where I need a really long working time, but I don't seem to get a very strong bond.
I have bought some of that UV setting stuff but have not used it yet.  I hope it will work for windows and canopies. I intend to try some tests with scrap plastic before I use it.
    March 2013
Posted by patrick206 on Sunday, May 15, 2016 2:15 PM
Hi, Don -
A question, please, what are the glues you describe as "solvent cement" types? Are they the thicker ones that we used to see in tubes?
Thanks
Patrick
    March 2013
Posted by patrick206 on Sunday, May 15, 2016 3:14 PM
Luftwaffles
Sincerely,
Joshua
Hi, Joshua -
I use several products, for the most part I use Tamiya ET. That one is used when there is a good parts fit, with a fine brush I use the "capillary flow" method, just touching the seam and allowing the cement to spread through the joint.
If the contact points are very tiny and a strong joint is unlikely, I use a Model Master cement in a plastic triangular shape container, with small metal tube for controlled application. The product number is 8872.
This one lays a narrow bead of cement, really useful for wings, tail surfaces etc, when there is a wide flat surface to apply the cement to. Often the leading edges of wings and stabilizers have a mating surface that is too narrow for it, then I use the Tamiya ET and tape to keep it all together until set. I really like this thicker stuff, (8872,) just takes a little time and practice to get proficient with it.
I used to use Tenax for a faster set time, but no longer available to me. As a replacement I have used the Micro Mark "Same Stuff," it seems to work the same but the smell is a bit dis-agreeable, no matter to me as there is very positive air flow at my bench. Gives a very strong bond, but is not quite as user friendly as Tamiya.
For CA I use Loctite and Loctite gel, but on a rather limited basis, I have yet to be fully confident in it's long term strength. I don't know if it gets brittle or whatever, but over time it looks to me like it starts to get a bit flaky and grainy.
For canopies I like either plain old white glue, or the canopy cement made by Testor's I think.
Patrick
Posted by Rob Gronovius on Sunday, May 15, 2016 5:37 PM
    January 2013
Posted by seastallion53 on Sunday, May 15, 2016 6:57 PM
I will use tamiya thick to brush on long parts so it does'nt dry out before i get all of the surface covered.
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, May 15, 2016 8:11 PM
Luftwaffles
Sincerely,
Joshua
You will get a wide range of opinions but in reality use whatever works for you. There really is no right or wrong glue to use no matter the scale. Some use tube glue, others thin liquid glue, CA glue, etc...
This something you need to figure out for yourself to find what works best in whatever situation.
I will say this - DO NOT use super glue on clear parts. They'll cloud them up.
    April 2016
Posted by Luftwaffles on Sunday, May 15, 2016 10:14 PM
Currently I'm working on the 1:72 Hobby Boss Leopold railway gun. The thing is I'm wondering what I need to use for the dainty suspension parts. I use the Tamiya for most everything, and the superthick gel Loc-Tite for gap filling (along with everything else lol).
    July 2014
Posted by modelcrazy on Sunday, May 15, 2016 10:31 PM
Like Don, my go to is CA, typically thin. I prefer Bob Smith Industries CA's. I will use Tamiya’s cement at times as well.
Steve
    December 2015
Posted by Dash8 on Monday, May 16, 2016 8:43 AM
Tamiya ET 99% of the time, gave up on CA glue just not strong
enough me even with the paint removed.
On the bench: Revell Euro Fighter 1/32
Ontario, CANADA
Posted by Don Stauffer on Monday, May 16, 2016 9:12 AM
patrick206
Hi, Don -
Thanks
Patrick
Solvent type glues are ones that melt styrene plastic.  Some people refer to the result as welding the seam.  Many model firms have their own brand of such cements, such as Testors, Tamiya, etc.  It is a liquid, virtually water viscosity.  I use MEK (when I can get the real stuff, not the artificial MEK substitute), or Acetone.  These are obtainable at hardware stores at reasonable prices for a quart can.
The commercial ones may have extra ingredients, but they are mostly MEK, acetone, or a combination of the two.
    March 2013
Posted by patrick206 on Monday, May 16, 2016 3:32 PM
Don Stauffer
patrick206
Hi, Don -
Thanks
Patrick
Thanks, Don
Good explanation, understood. Acetone is good for plastic joins and a great AB parts cleaner. Lasts forever. $7.00 per quart at Sherwin Williams.
Patrick
    September 2009
Posted by Cobra 427 on Tuesday, May 17, 2016 4:59 PM
I only use Bob Smith Industries in the purple bottle for building, and epoxy for gluing anything that is porous, and won't hold with thin glues, or wood, or Elmers' glue. Silicone based hot glue I only use for windows, or Elmers' for securing them without worrying about crazing like superglues can. I don't use Tamiya, or any of their products  - There's no point in doing so since they don't offer anything that I can't get locally and it's no better in quality.
~ Cobra Chris
Maybe a picture of a squirrel playing a harmonica will make you feel better?
    November 2008
Posted by plasticjunkie on Sunday, May 22, 2016 12:31 PM
About 95% of my gluing is done with Tenax or Plast I Weld in a Touch'n Flow applicator. I have mastered the applicator and I can deliver glue with pin point accuracy. Most of the time I do not need any filler/putty cause of the melting and fusing of the plastic which after being cured, sands smooth leaving no join line.
For canopies I mainly use either Aleene's Tacky Glue or Testor's Clear Parts Cement.
For PE, depending on the application, I either use Aleene's where strength is not a factor or Gorilla Gel CA where stregth is critical.
For resin I use Gorilla Gel Ca.
 GIFMaker.org_jy_Ayj_O
    February 2007
Posted by mitsdude on Tuesday, May 24, 2016 12:17 AM
I still keep the old Testors tube glue in my arsenal. I use it on ocassions where large parts are involved.
I find myself use two main glues. The Model Master in a black bottle with metal tube and The Tamiya thin.
Posted by Texgunner on Tuesday, May 24, 2016 8:05 AM
I haven't seen any mention of Faller Expert glue.  I've been using that for more than 20 years.  It, along with liquid cement (or MEK) and CA, and white glue for clear parts, covers my glueing needs.
http://www.amazon.com/Faller-170492-Expert-Plastic-Cement/dp/B0000WROZ2
"All you mugs need to get busy building, and post pics!"
Posted by Don Stauffer on Tuesday, May 24, 2016 8:37 AM
Texgunner
I take it that is a solvent cement, right?  The ad was not very informative.
Posted by Texgunner on Tuesday, May 24, 2016 8:42 AM
Yes Don, it is.  It is thicker than Tenax or MEK though.  Yet it is still thinner than the old tube glues. It's a good modeling product.Smile
Gary
