What glues are you using ?
    December 2015
Posted by Dash8 on Saturday, January 9, 2016 10:09 PM
I find in this hobby it is good to have
few differnet ones for what they excel in.
So far have had good luck with:
1-Lepage ultra gel CA for general work,
very good glue placement with this bottle type
2-Zap-a-Gap thin CA for large plastic halves
that have not been painted yet, this glue
runs right along the seams then just give
excess a quick wipe with a paper towel and tape
the parts together and let dry
3-Lepage Five minute epoxy
for clear parts, no fog and good
set time. Also all painted parts
are scraped off.
On the bench: Revell Euro Fighter 1/32
Ontario, CANADA
    July 2014
Posted by modelcrazy on Saturday, January 9, 2016 10:50 PM
Well Dash, let's see.
I did use Bob Smith Industries thick and thin CA's exclusively, but now I've added Tamiya Extra Thin Cement.
For canopies I use white glue or Mod Podge.
That's pretty much it.
Steve
Steve
    December 2015
Posted by Dash8 on Sunday, January 10, 2016 8:53 AM
Never thought of mod podge Steve, cool
Ontario, CANADA
Posted by Don Stauffer on Monday, January 11, 2016 10:20 AM
I use Loctite CA, both gel and thin
Epoxy
White glue including canopy/window variant.
I have solvent glue on bench but very seldom use it.
Posted by Tojo72 on Monday, January 11, 2016 3:05 PM
I almost exclusivly use Tamiya Extra Thin,and a little CA from my LHS
    December 2015
Posted by Dash8 on Monday, January 11, 2016 10:10 PM
How do you like the gel bottle Don ? works great don't
you think, the Lepage version has the same
bottle for pin point glue placement.
Ontario, CANADA
    June 2010
Posted by 5-high on Tuesday, January 12, 2016 12:01 AM
I use tamiya extra thin
And intsta-set CA..micro Krista klear for canopies ..oh and micro liquitap for temporary holds .
5 minute epoxy for landing gear (if needed )
That's about all .
Pete
Posted by Don Stauffer on Tuesday, January 12, 2016 9:18 AM
Dash8
Yes, I do like that bottle- one of the reasons I like the Loctite.
BTW, the main place I use epoxy is on windows in airliners and bombers- windows that glue in from the inside.  I need a REALLY strong bond there- stronger than those white glue type canopy glues- because if a window pops inside during masking or finishing, it is a real disaster.
    May 2011
Posted by Real G on Wednesday, January 13, 2016 3:26 AM
I primarily use Tamiya extra thin cement, but I like Gunze's Mr Cement better.  But no one brings it in here, and I can't have it mailed.  I use gap filler and thin CA only when I must.  I buy whatever CA I can get but I like the Zap brand.  I use Kristal Kleer for canopies where I cannot use the Tamiya extra thin.  I do keep a bottle of Testors liquid cement when I need time to wiggle a delicate part into position.  I also have their thicker cement in the black squeeze bottle, but rarely use it nowadays. I think it is decent stuff, but other glues can do the same or better job.
“Ya ya ya, unicorn papoi!”
    January 2014
Posted by jelliott523 on Wednesday, January 13, 2016 8:15 AM
Seems like I must be one of the odd-men out here. I primarily use Plastruct Plastic Weld and Bondene as my glues of choice. I also have a bottle of Flex-I-File Plastiweld. I occasionally use BSI medium and thin CA with accelerator. For clear parts I use Gator-Grip PVA (thick and thin) or Testors clear parts cement. I will also use regular white glue for temporary holding of parts for painting.
    January 2015
Posted by Moff on Wednesday, January 13, 2016 9:13 AM
  • Extra Thin Cement: Mr. Hobby Mr. Cement S. Someone demonstrated in an ISM review that it dried slightly faster than Tamiya's extra-thin. I got some on Ebay, and it works well enough. I haven't decided if I'll find some more Mr. Cement, or just buy some Tamiya extra-thin when this bottle is unuseable.
  • Normal Cement: Revell Contacta Professional, Hamilkar Barkas's go-to glue...he barely ever uses extra-thin! I've been trying to get my hands on some for quite a while, and I finally have. It's currently somewhere in transit.
  • Super Glue: various thicknesses of what I assume is a generic cyano brand, "Extreme Power". I'm considering shelling out a bit of money and trying a name-brand cyano at some point.
That's basically it. I haven't had need of epoxy or other glue types yet.
"Gaiety is the most outstanding feature of the Soviet Union." - Josef Stalin
    April 2008
Posted by spiralcity on Saturday, February 6, 2016 8:17 PM
Pretty much whats pictured, although I usually keep a bottle of thin CA on hand, at the moment I have run out.
    August 2011
Posted by BashMonkey on Saturday, February 6, 2016 8:46 PM
I use primarily Zap-Gap for 75% of the time. Plastruct Weld 10% Elmer's white 10% J&B Weld epoxy 5%
 ALL OF YOUR BASE ARE BELONG TO US!
    July 2013
Posted by steve5 on Saturday, February 13, 2016 10:21 PM
quick question , probably been asked a 100 times , what are the different uses for thin , medium and thick ,ca glue's please .
    July 2014
Posted by modelcrazy on Saturday, February 13, 2016 10:54 PM
Thin is good for capillary action, medium works well applying parts and thick, which I don’t use except on wood RC planes, is for gap bonding.
Steve
    July 2013
Posted by steve5 on Saturday, February 13, 2016 11:12 PM
thank's modelcrazy
    January 2010
Posted by CrashTestDummy on Tuesday, February 16, 2016 12:15 PM
It depends on what I pick up at the time!  Wink
Actually, for long seams, and where I can, I use my flex-i-file Touch-N-Flo applicator with the flex-i-file plasti-weld.  For flat area to flat area, or smaller pieces, I've used Testors plastic cement (the one in the black 'square-ish' bottle.  For clear parts, I use the Testors clear parts cement, or Elmer's.
I'm also very fond of 5-minute epoxy, and use it a LOT, especially on photo-etch, or small parts.  I've also used clear enamel on flat photo-etch parts with great success.
I've had very little luck with the super-glues.  I think our environment has too high a humidity (even in an air conditioned house) that the glues frequently set up in the bottle between uses.  And it's not because I don't cap the bottle well.  We've had unopened bottles set up.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    January 2015
Posted by Moff on Wednesday, February 17, 2016 7:49 AM
CrashTestDummy
I absolutely HATE that stuff. There's nothing particularly wrong with the glue, but the bottle is so annoying. You have to squeeze it for 5 minutes before getting anything out if it, and that's before the glue starts blocking the nozzle and reacting with the plastic of the bottle.
