Aircraft Trivia Quiz
    January 2009
Posted by F-8fanatic on Thursday, August 12, 2010 2:56 PM
simpilot34
This should be a fairly quick one, especially for those Fw-190 afficianados.
On said plane, what was the cooling fan on the radial engined ones connected to? The propshaft or the crankshaft?
The cooling fan had a hollow hub, which was attached to the prop shaft.  The fan itself was driven by a reduction gear system.
    March 2006
Posted by simpilot34 on Thursday, August 12, 2010 9:58 PM
Sorry guy's that isn't correct. The new builds of the 190 do show that to be true, however, I am going from a dvd I have on the 190 that has WWII footage and a direct frontal view of them turning the engine over from a dead stop.
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    March 2007
Posted by bondoman on Friday, August 13, 2010 1:15 AM
Gear driven from the crankshaft at 3.12 times engine speed.
    January 2009
Posted by F-8fanatic on Friday, August 13, 2010 7:35 AM
can we clarify please?
I gave one answer and the poster before me gave the other.  And you said that we both were not correct.
The hollow hub is indeed connected to the prop shaft, but like I said the fan itself is driven from a gear system, not from the prop shaft.  That is why I made the two statements, to clarify that the fan is not driven by the prop shaft itself.
    March 2006
Posted by simpilot34 on Friday, August 13, 2010 9:46 AM
In all fairness, I should have asked the simple question of, did the fan turn the same speed or faster than the prop. I found this while looking for  more info.
A remarkably compact installation, adequate cylinder cooling was obtained using pressure baffling augmented by a magnesium alloy fan geared to turn at 1.72 times engine RPM (3 times propeller speed).
From this site:
http://tighar.org/Projects/Histpres/Corrosion_Report/bmw801.html
So in reality it isn't 'connected' to either shaft. I goofed again, sorry for the confusion guys. The DVD I have clearly showed the fan turning faster than the prop and I assumed it was directly connected to the crankshaft. I will try and be more careful next time.Embarrassed
Floor is free!
Posted by osher on Friday, August 13, 2010 10:36 AM
As the floor's free...
This aircraft was lightened, but, this resulted in a g-force issue.  An interesting, but sometimes uneven (and hence dangerous) solution was found.  To get around the sometimes uneven solution, a more explosive solution was found, which a ground crewmember unfortunately found about the hard way.  In the end the pilots were just told not to exceed a certain g.
Which aircraft?
    June 2003
Posted by SteelSnail on Tuesday, August 17, 2010 11:36 AM
I think we need a tip. Maybe the era or country of origin.
    April 2009
Posted by gmat on Tuesday, August 17, 2010 12:07 PM
I think that the last person perhaps unwittingly gave a hint in his comment. I could be wrong.
Best wishes,
Grant
    March 2010
Posted by Scorpiomikey on Tuesday, August 17, 2010 9:18 PM
juts a stab but i remember hearing something like this about the F-104.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
Posted by MQM107 on Thursday, August 19, 2010 12:14 PM
I'm thinking it is the F8F Bearcat, which had explosive charges in the wing tips.
Posted by osher on Thursday, August 19, 2010 12:49 PM
Ooops, sorry, bit slow to respond there! No, not the Bearcat, but, very close.  We are on the tip of the answer...
    July 2008
Posted by Railfan 233 on Thursday, August 19, 2010 2:22 PM
MQM107
I have a side question. What were the explosives for?
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpgRed, White, and YOU! group build of 2010
    April 2009
Posted by gmat on Friday, August 20, 2010 4:49 AM
When the Bearcat was built, it was felt that the aircraft could overstress the wing when maneuvering, so breakaway wing tips were designed and installed, but then apparently situations of having one tip break away and not the other created a more dangerous situatuion. So explosive bolts were installed to insure separation of both wing tips. In the end it was felt that the explosive wing tips were more dangerous than useful, so the whole idea was abandonned.
Best wishes,
Grant
Posted by osher on Friday, August 20, 2010 5:29 AM
I read it was the Hellcat, not the Bearcat.  However, as Bearcat is close, and, as there could be a difference on source information, I'm going to run with MQM.
MQM - over to you!  What do you have for us?
Posted by MQM107 on Friday, August 20, 2010 8:48 AM
You can imagine the perplexed look on my face when told the Bearcat was incorrect. So much so that I just got in the car and drove down to the Naval Aviation Museum about 20 minutes away. I have a buddy who works there  and he showed me where they (the bolts) went. So anyway, this aircraft had (has) a unglamorous nick name of the Leaping Heap. Who am I?
    October 2007
Posted by Milairjunkie on Friday, August 20, 2010 12:18 PM
Well there aren't that many A/C that can leap, so I will go with the H.S. Harrier?
Posted by MQM107 on Friday, August 20, 2010 1:39 PM
You are correct Milair. Although I think that name applies better to the Yak 38. Your up on plate.
    October 2007
Posted by Milairjunkie on Friday, August 20, 2010 2:42 PM
OK - I agree regards the Yak as well.
This aircraft was chartered during the Falklands war to the RAF, The RAF had previously operated & retired the type?
    March 2007
Posted by bondoman on Friday, August 20, 2010 2:57 PM
Gosh, the VC-10.Hmm
    September 2004
Posted by Borg R3-MC0 on Friday, August 20, 2010 3:42 PM
I think it is the Short Belfast.
    October 2007
Posted by Milairjunkie on Friday, August 20, 2010 3:55 PM
Borg R3-MC0
You would think correctly;
    September 2004
Posted by Borg R3-MC0 on Saturday, August 21, 2010 10:21 AM
ok, to stay in the UK, what Shorts design was used by the USAF?
Posted by osher on Saturday, August 21, 2010 11:39 AM
Sherpa
    September 2004
Posted by Borg R3-MC0 on Sunday, August 22, 2010 10:54 AM
It is indeed the Sherpa! Over to you Osher!
Posted by osher on Sunday, August 22, 2010 11:34 AM
This British aircraft was designed to be built in larger numbers in WWII but was only built in limited numbers (60 or so I believe)  It was based on an existing airframe, but, had significant changes, based on an earlier Farman design, which ironically had been a failure, with input from the Americans.  The technology developed was then given back to the Americans.  Although this aircraft wasn't used much, it lead the way to the future for the allies.  What was the aircraft?
    July 2004
Posted by stikpusher on Monday, August 23, 2010 9:49 PM
Gloster Meteor?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2007
Posted by bondoman on Tuesday, August 24, 2010 2:30 AM
Martin Maryland.
Posted by osher on Tuesday, August 24, 2010 3:18 AM
Here's a clue: under it's original engine, it was reasonable, but, after just a few, a change was made to Merlin engines.  This gave a better than exepected performance.  The airframe was a pre-war design, but, in use pre-war to post war.  This unique version of the aircraft though had a unique interior, which also resulted in a unique looking front fuselage.
    January 2008
Posted by acmodeler01 on Thursday, August 26, 2010 1:40 PM
I've been searching all day, the only thing I can come up with is the Wellington. How about another clue?
    March 2006
Posted by simpilot34 on Thursday, August 26, 2010 1:56 PM
I want to say Bristol Blenhem, but I don't think they ever had merlins did they?
