Thanks Marko!
So, we're working with a load of 1,750lbs. That allows us 1,250lbs of useable weight before we hit max gross weight (an area you DON'T want to be operating in in combat). With a full bag of gas that's 242 gallons of JP4. JP4 weighs 6.5 lbs per gallon, which brings us to 1,573lbs of fuel. We're over gross by 300lbs. So, trade off 50 gallons of gas for a full ammo load. That leaves us 190 gallons or 1,235lbs of gas. Right up near Max Gross still. With the environmental conditions (temp, humidity, high DA) a running takeoff MAY be possible.
Of course, now that I've calculated all of this, I forgot one other crucial element. The flight crew and all of their gear. Figure each crewman at 160lbs. Add 35lbs for each chicken plate vest (yes, they are that heavy, I have one sitting in my hobby room). 23lbs for each M60. 400rds for each M60. Not to mention the sundries that one finds in the cabin of a Huey. Smoke grenades, frags, thermites, you name it. Figure another 1300lbs for all of that stuff?
When it comes down to it, the XM50 system MAY have flown in Vietnam, but it wouldn't have been good for anything but short duration anti-mortar patrol around a base. It'd probably burn off half of its fuel just trying to get airborne!
BREAK
Ray,
I think the first pic with the closeup of the anti-strela exhaust is 553. Comparing the camo on the tailboom there and on the color pic of the one we know to be 554, there is a definite difference in pattern. It could definitely have been redone, but it is my hunch that the closeup pic is 553 having maintenance done on it. Judging from the lack of camo paint on the cowlings, I'd say it was probably in the middle of getting "camo'd up"!
Jon
