1/72 B-52D with Big Belly Mod, Operation Arc Light
    April 2012
Posted by Striker8241 on Wednesday, May 8, 2013 9:51 PM
Buffirn
Table space!  It is my plan to take up much table space at my local contest next year.  If I don't goof off, I will have 3 BUFFs, a Toad, a B-47E and, maybe, an XB-70.  That should make them happy!
Egad!  You'll need a convoy just to get that lot to the contest!
    April 2012
Posted by Striker8241 on Friday, May 10, 2013 7:55 AM
Hi, All,
I've started building my second bomb clip so I tried out Duke Maddog's method of dipping the bombs in a layer of paint to paint the noses and it worked beautifully. Thanks, Duke!
The bombs were first spray painted with Testors flat olive drab enamel. For the yellow, I used Model Master acrylic Insignia Yellow. I used the paint full strength since it covered the olive drab color of the bomb without re-dipping.
I discovered early on that I needed to limit the amount of paint I was exposing to the air so I looked for something small enough to hold a minimum amount of paint. I ended up cutting off the end of one of those clear plastic tubes that Exacto blades come in.  I cut the tube so the lip was 2 mm above the bottom of the tube - the depth of the paint on the 500-lb bombs. You can cut them different depths for different size bombs.
 To control the level of the paint, I used a hobby syringe to add a few drops now and then. Once I was done, I could suck up any left over paint and put it back in the bottle.
The Verlindin bombs have a grove in the nose that defines the painted part of the nose. This is a good reference point but I discovered that if you let the paint wick into or above this grove, it tends not to do so evenly and you end up with an uneven paint line. If you adjust the paint level so it comes to just below this line, you get a nice even line almost every time.
As I dipped each bomb, I stuck it to a strip of masking tape I attached to my overhead light. This kept the bombs vertical while the paint dried. At first, I wicked off the bulb of excess paint but I discovered that this tended to thin the paint around the end of the nose and the olive drab color showed through, so I just hung up the bombs and let the paint dry with the excess paint.
Again, thanks Duke for the idea.
Cheers,
Russ
    June 2003
Posted by Duke Maddog on Friday, May 10, 2013 9:28 AM
You're welcome Russ! Glad I could help. That was a brilliant idea with the clear blade container. Well done.
    April 2012
Posted by Striker8241 on Friday, May 10, 2013 12:20 PM
Thanks, Duke.
    April 2012
Posted by Striker8241 on Friday, May 10, 2013 3:05 PM
Striker8241
"At first, I wicked off the bulb of excess paint but I discovered that this tended to thin the paint around the end of the nose and the olive drab color showed through, so I just hung up the bombs and let the paint dry with the excess paint."
This turned out to be a bad idea with the acrylic paint. The thick paint at the tip didn't harden properly and had to be trimmed away, forcing me to touch up a number of the bombs. So it looks like it's better to go ahead and wick away the excess paint.
Russ
    February 2010
Posted by Bockscar on Friday, May 10, 2013 10:35 PM
Striker8241
Thanks, Dom.  I thought of adding storage space like that, and I have the time but not the desire. Me and woodworking don't get along very well - certainly not that well Big Smile.
Thanks for the idea, though!
Russ
That's an even better idea Russ than what i had in mind,Geeked
we would have made a great tech teamWink....lol......
I would like to build a unit like that, i could put a big Buff on top and all kinds of of support aircraft
underneath.....
Dom
    February 2010
Posted by Bockscar on Friday, May 10, 2013 10:39 PM
Striker8241
Hi, All,
Cheers,
Russ
Wow, paint techno-surgery,
Thanks guys, I'm a bit behind, Tomorrow I'll put some more bombs together.
Great  idea Duke!
-Dom
    June 2003
Posted by Duke Maddog on Saturday, May 11, 2013 9:11 AM
Thanks Dom!
Posted by Gamera on Tuesday, May 14, 2013 2:02 PM
    April 2012
Posted by Striker8241 on Tuesday, May 14, 2013 2:41 PM
Thanks for the info, Cliff!
Cheers,
Russ
    April 2012
Posted by Striker8241 on Thursday, May 16, 2013 3:31 PM
Hey, Dom,
You should be assembling your first bomb clip soon and you will need some kind of clamping system to gently hold the panels and chafing curtain together while you glue on the top hangers. Below is the system I use. It's just two blocks of wood pressed against the assembly and tied together with two strips of masking tape. You only have to lift one of the blocks to release pressure on the clip. Hope this is of use to you.
Cheers,
Russ
    April 2012
Posted by Striker8241 on Thursday, May 16, 2013 7:56 PM
Version 4 of the Big Belly Bomb Clip and Transporter Trailer Manual now available.
Hi, All,
I just finished this new version, and it may be the last - I'm sick of it! Big Smile. There were too many updates and changes to list so you'll just have to read and compare it to the earlier version - if you have the earlier version. One of the major changes is the update to the correct version of the transporter trailer.
Many thanks to Ken Williams (SOMM) for converting my Word document to PDF format!
If you would like a copy of this latest manual, please PM me.
Cheers,
Russ
    February 2010
Posted by Bockscar on Thursday, May 16, 2013 8:45 PM
Striker8241
Hey, Dom,
Cheers,
Russ
Thanks Russ:
That looks like another great idea.
I see you put the gap in your clip panels, I wish!
I'll give that a try. Those bombs look great, the the fuses
really stand out.
Dom
    April 2012
Posted by Striker8241 on Friday, May 17, 2013 2:32 AM
Bockscar
really stand out.
Dom
Thanks, Dom. This was my second clip - actually third if you count rebuilding the original. The last clip, along with the rebuilt original, will go into the aircraft - that is, if I can ever force myself to build the last one  Big Smile.
One thing that bothers me about my diorama is the transporter trailer - there's only one so far. In an actual loading scenario, I believe there were six trailers around the aircraft - three with the empty clips from the previous mission and three with loaded clips for the current mission. Building the trailers would not be that hard if I had the wheels - that's the dig. I may have to get into resin casting...
Hmm... and I would also need to build three empty clips...
(walks away scratching head...)
Russ
    March 2009
Posted by Buffirn on Friday, May 17, 2013 2:13 PM
You could always say that the BB Stackers were extra efficient that day and had already removed the empty clips to reload them.  That would save you some work
Resin casting isn't that bad.  It takes patience which will be no problem for you.  I have some stuff right now that I am thinking about doing.  Hmmm, maybe we can work out a  deal and I'll cast for you.  We'll have to chat about that.
Jim
Jim Williams
    April 2012
Posted by Striker8241 on Friday, May 17, 2013 4:33 PM
Ya, that's true Smile. I really appreciate the casting offer, Jim, but I need to learn how to do it myself. However, now that I know you know how to do it, I'll be bending your ear for sure Big Smile. In any case, the additional trailers would be something for later down the road, after I finish this monster as it was originally planned.
BTW, the two halves of the base are essentially done. I installed 12 magnets and 3 guide pegs today (the picture below shows the two halves back to back). Tomorrow, when the glue dries, I'll see how everything lines up. After that, its staining and finishing. I've decided to build the display cabinet rather than a pedestal for the diorama to sit on so I'll be starting on that in the near future.
Cheers,
Russ
Tags: B-52D , diorama
    November 2010
Posted by Son Of Medicine Man on Friday, May 17, 2013 9:00 PM
That is looking great Russ!  Yes  Yes  I was bragging about your work tonight at our IPMS meeting.  Everyone was impressed.
Ken
    April 2012
Posted by Striker8241 on Friday, May 17, 2013 9:10 PM
Thanks, Ken!  Very kind of you for the good words. Fortunately they can't see all the mistakes or the blue cloud over my bench when I'm working Big Smile.
Russ
    February 2010
Posted by Bockscar on Sunday, May 19, 2013 12:26 AM
Hear you on that Russ:
Ice-cream Castles in the sky......but Blue clouds got in my way........Angry
Dom
    February 2010
Posted by Bockscar on Sunday, May 19, 2013 7:55 PM
Striker8241
Cheers,
Russ
Years ago, I was a sculptor, and made many molds and resin casts including industrial molds.
I had a client with a big 4' platten for vacuum casting, never saw a bubble in a casting out of that beast.
Here is a belt buckle I did for him:
And my last resin castings:
Sorry for the fuzzy photos...
This is my very last art project, it has been sitting on my sculpture work bench for almost 8 years:
"I think I've lost my head!!!!!"
"Wise up sweat heart, we both lost our surgeon!!!!"
Dom
    April 2012
Posted by Striker8241 on Sunday, May 19, 2013 9:14 PM
Wow, nice work, Dom! Yes Yes
Russ
    February 2010
Posted by Bockscar on Sunday, May 19, 2013 9:21 PM
Thanks for the compliment Russ,
those girls are begging me for company,
but the dog took his bone outa' town.....
then he forgot where he buried it.......
doggone.......
I'm embarrassed I can't even cast a little wheel anymore.Embarrassed
Dom
    April 2012
Posted by Striker8241 on Tuesday, May 21, 2013 7:38 AM
Hi, All,
Well, this diorama project is finally approaching completion. The base is essentially finished and is drying from its second coat of sealer. The bomber is fully painted and ready for its first gloss coat. Most of the support vehicles and equipment are done and ready for weathering. There is still a lot to do but I estimate I will be finished in about 2 months.
I was able to convert the decals that came with the model from tail number 50-677 to 56-612, the tail number of the aircraft I'm modeling. Once I get the first gloss coat on, I'll apply the decals.
Cheers,
Russ
    March 2009
Posted by Buffirn on Tuesday, May 21, 2013 11:18 AM
Russ, did the magnets work for you?  Just curious in case I decide to build something like this.
Jim Williams
    April 2012
Posted by Striker8241 on Tuesday, May 21, 2013 11:39 AM
Hey, Jim,
Yes, they work great! Sorry, I meant to tell you sooner. I probably should have used at least two more. In my case, 12 is enough to hold the two sections together securely. You have to "break" it to separate them or pull hard from the side.
Many thanks for sending them to me. Sure beats putting in and removing screws!
Russ
    November 2012
Posted by buffjock on Tuesday, May 21, 2013 11:45 AM
Russ,
Looking at the photos you posted, I can only come to one conclusion..... Yer Frickin insane!!!  Keep up the good work!!
How did you get a sheet of decals with 56-612?? I do my serials with dry transfers from Woodland Scenics.
Major Kong
    April 2012
Posted by Striker8241 on Tuesday, May 21, 2013 12:19 PM
Thanks, BJ! .....and you're probably right! Big Smile
As for the decals, the kit decals came with tail number 50677. I copied them into Photoshop and changed the numbers to 612. Now I'll print them onto a decal sheet using my inkjet printer.
Cheers,
Russ
    November 2010
Posted by Son Of Medicine Man on Tuesday, May 21, 2013 5:59 PM
Nice job on the table Russ!  For somebody who doesn't like woodworking it turned out really nice!
Ken
    April 2012
Posted by Striker8241 on Tuesday, May 21, 2013 8:23 PM
Thanks for the good words, Ken!  I'm just glad to be done with it. Now I need to get the tarmac laid down. And it looks like I'll have to go ahead and build the cabinet for it or I won't have a place to work on it. Ah well... Big Smile
Russ
    March 2009
Posted by Buffirn on Wednesday, May 22, 2013 6:45 PM
I don't see a 781 yet!  :)
Jim Williams
