Hi, All,
My two Ford tow tractors are finally finished. I used the ones from the Hasegawa US Aircraft Weapon Loading Set #35005. However, I discovered this version is not the same one we had back when I worked on B-52s. It only has one door and that is in the back. That setup is entirely impractical for a busy tow tractor working on the flight line.
Our tractors had two doors in the front, one on either side (as shown below) because the operator had to be constantly climbing in and out to hook up and unhook trailers and stands. Trying to do that from a single door in the back would be too difficult and time consuming. I don't see how the Hasegawa version could ever have been used by the Air Force.
At any rate, I decided to modify the kit version to the two-door version, which turned out to be a time consuming project. In addition to opening the doorways in the sides of the cab, I also had to modify the rear wall of the cab since, in the two-door version, there was no door at the back and the lower window was shaped differently.
Some further modifications: I thinned out the rear-view mirror arms, removed the warning light assembly from the roof (our tractors didn't have them) and rounded off the roof edges, thinned out the steering wheel, removed the oil breather from the top of the radiator, added a tank and tail lights in the back, corrected the rear hook assembly and added one to the front. I also added glass to the windows (not included in the kit). The radiator and the fenders are not shaped quite right but they would require too much work to modify. It still looks pretty close to the original.
The small tank at the back is not a fuel tank. I suspect it's a compressed air tank for the tractor itself or for trailers that have air brakes - like maybe the bomb clip transporters. I haven't been able to find any information on these transporters but they weighed over 8 tons fully loaded and disk or drum brakes likely would not be enough to safely control them. This is just a guess though.
The reflective striping on the tractors was often hand painted and varied from base to base. The stripes on the back bumpers were often painted quickly and not very neatly, so I can justify mine .
Cheers,
Russ
