Thanks for the feedback.
Brizio: I have a 1:1 1963 Vespa which I have had for 23 years now. No need to model one!
Doog: High praise indeed from you. I think God is in the details. When you scratchbuild, it really makes you look very hard at something and understand why it looks like it does.
Manny: Thanks v. much. I have wanted to build a box diorama since seeing the scale dinosaur ones in the Museum in Sydney when I was a kid. I think the trickiest part is going to be the lighting...will there be enough through glazing on the top, or will I need to supplement it with some LEDs. With fire escapes, the shadow on the wall is a big part of the effect. I'll have to wait until I am almost finished before I decide.
Thanks Stern0, redleg and razor. I am glad it works for you.
PO: I need to get the corners a little neater. You can also see where I tried having a longer X in the lower two segments and pressed it flat again, but its still visible. I want to work on evening out the centre of the X in the ducting. I do also have to add horizontal T beams around the joins and wall brackets. So you can see there is still a lot of work to do.
Captain Mac: rust and peeling paint are what I want on these. Its been fun working with brass, as it gives a lot of structural integrity to what could be delicate elements.
Jim Barton: I want to hotel room look a little used and stained with pale pastel colours and water stains around the air conditioner, like you find in those chain hotel rooms.
I'll post more as it comes along.
