How I Build Dioramas(step-by-step)
    February 2004
Posted by JohnReid on Sunday, August 13, 2006 11:18 AM
Guide my hand in your work today.JWRR. My goal in life is to be as good a person as my dog already thinks I am. My Photoshop: http://s6.photobucket.com/albums/y250/JohnReid/
    February 2004
Posted by JohnReid on Sunday, August 13, 2006 11:55 AM
Mercedes 180 HP engine build.
The above pic of the engine block was taken from a page supplied with the kit of all the resin parts.The crease that you see across the middle of the block is actually where the paper was folded and not on the casting itself.
This is where I will begin this build by removing what very little flash there is on the casting,then washing the parts in soapy water.I will remove a little resin where the propeller hub meets the engine.If you want your prop to spin enough material will have to be removed to accomodate the entire prop hub.Mine will be stationary so it will require only minimum drilling.I could do this now but I think that I will wait until after the 2 pieces of the block are joined together.
In comparing the parts of this engine with the Model expo version ,that I had previously built ,the quality ,accuracy and fit of the parts is clearly superior.This looks like it will be a fun build!
__________________
It has been said that the difference between a "pilot" and an "aviator" is that a pilot is a technician,and an aviator is an artist in love with flight.
JohnReid (Aviator)
    February 2004
Posted by JohnReid on Sunday, August 13, 2006 6:54 PM
    February 2004
Posted by JohnReid on Sunday, August 13, 2006 7:17 PM
Monty's finished! except for a few final touchups under the hangar lights.I haven't figured out where to place him in the diorama yet but he could go just about anywhere.I think that I will put aside the figures for now after having completed 14 of them so far.Now its on to that Mercedes engine! One thing about doing dioramas you certainly never get bored with any one subject.
    February 2004
Posted by JohnReid on Monday, August 14, 2006 9:19 AM
Another change in plans.I hate to say it but summer is growing short in the GWN.Soon it will be too cold for this almost 66 year old body to spent much time sitting outdoors.(its not too bad if you keep moving) Therefore ,I think that i will divide what is left of summer into doing the Mercedes engine indoors on rainy or cool days, and finishing the hangar lighting outdoors on nice days ,as I need the room to workon the large roof rafter assembly.Why am I telling you all this?Because it may be a little confusing at times jumping from one subject to the other and those of you who expect a quick build of the Mercedes may be disappointed in the lack of consistency.
__________________
JohnReid (Aviator)
    February 2004
Posted by JohnReid on Monday, August 14, 2006 9:30 AM
    February 2004
Posted by JohnReid on Tuesday, August 15, 2006 9:00 AM
    February 2004
Posted by JohnReid on Tuesday, August 15, 2006 11:03 AM
Mercedes / Lighting?
I have cleaned up ,washed and glued the two engine halves together using exopy and CA on the edges.Be sure to line up both the top and bottom halves so the bolts look lined up as above.
I plan to paint this engine with a brush only(although I do have an airbrush handy) just because I enjoy the plaeasure of painting by hand.
For a great resource on this engine and many others check out the book "Scale Aircraft Drawings Vol 1" by Air Age Inc.
I plan to light my Jenny diorama using a Radio shack 120v60hz transformer.I had begun to wire the rafters using model train hobby wire but I find that it is just too fragile so I was wondering if 24 gauge speaker wire could be used instead.I plan to run this wire from the transformer to a reostat(so I can control the intensity of the lights) and then to the individual light sockets.The light sockets are wired with the lighter hobby wire.Would this create a problem using 2 different gauges of wire? How many 12volt,65MA bulbs could I run off of this transformer.The actual wording on the transformer says:
SEC.6.3-6.3V 12A Radio Shack PRI.120V60Hz
Thanks!
    February 2004
Posted by JohnReid on Wednesday, August 16, 2006 12:44 PM
    February 2004
Posted by JohnReid on Wednesday, August 16, 2006 1:09 PM
In the above pic you are looking down upon the top of the engine block.The recessed areas are cut in to receive the cylinders.They are in the casting and not cut in by me.On the bottom of the bottom cylinder(in the pic) you can see where some material has yet to be removed to fit into the blocks recesses.
The instructions recommend two sided tape to dry fit the cylinders .I think that I will use small pins.Temporary dry fitting is necessary because of the linkages that are required between the cyliders must be installed before final gluing.
The cylinders are very well cast with only a very small mold line that can easily be removed.
I painted the block with silver to which I added a touch of black gesso.As long as I have something silver and shiny at this point I am not to concerned about getting the colors just right.Everything has yet to be weathered with washes of acrylic and pastels.
    February 2004
Posted by JohnReid on Wednesday, August 16, 2006 3:39 PM
    February 2004
Posted by JohnReid on Wednesday, August 16, 2006 3:58 PM
Here I have dry fit the cylinders to the block using small track pins.I anticipate that this should work better than 2 sided paper(I hope) because I will be able to rotate the cylinders to position them ,as well as bend the pin a bit to keep everything straight and at the same time hook up the plumbing between the cylinders and then use super thin superglue around the bottom to attach them to the block.
I oversized the holes for the 4 clamps that fasten down the cylinders to the block on the real engine.Experience has taught me to do this now rather than wait until the cylinders are in place ,because of the limited workspace.The two holes on the end couldn't be enlarged due to lack of material ,so I will shave down the clamp shaft instead.
    February 2004
Posted by JohnReid on Wednesday, August 16, 2006 6:37 PM
    February 2004
Posted by JohnReid on Wednesday, August 16, 2006 7:02 PM
After many hours of lining everything up I have finally put the cylinders on for a trial fitting.This is the most important step in this build ,for all the other parts to line up properly ,the cylinders must be in their proper position.
As you can see from the pic my engine still requires some tweaking here and there.This is very tight work and requires a lot of patience to get it right .Next will come the trial fitting of small pieces of tubing that act as a link between cylinders .
    February 2004
Posted by JohnReid on Thursday, August 17, 2006 10:17 AM
    February 2004
Posted by JohnReid on Thursday, August 17, 2006 2:41 PM
    February 2004
Posted by JohnReid on Thursday, August 17, 2006 6:40 PM
    February 2004
Posted by JohnReid on Thursday, August 17, 2006 7:22 PM
I disassembled the cylinders and block and painted the cylinders black gesso above and silver with a little black gesso added below.I reassembled the engine for the picture and now I can disassemble it again and begin the plumbing between each cylinder starting with #6 at the rear.This plumbing is a small piece of aluminium tubing.The more detail builders may want to replace the tubes with a scratchbuilt part.I plan to build this engine as it came in the kit, as my engine will not be handheld but in a diorama viewed through a window, so too much detail would be just wasting my time.
    February 2004
Posted by JohnReid on Friday, August 18, 2006 6:48 PM
    February 2004
Posted by JohnReid on Friday, August 18, 2006 7:30 PM
The pic above is somewhat distorted due to my scanner. The plumbing between the cylinders is finished.I made new aluminium sleeves that are slightly larger than those supplied for ease of fitting on to the resin stubs.Everything was touched up with black gesso.
The next step is to install the 4 stirrups at the base of each cylinder which securely fasten the cylinders to the block.
The bottom row of holes in the side of the cylinder is where the fibre support tube will be installed.The top row is for the spark plugs.Note: on the right side of the engine the spark plugs are not on the center line of the cylinder but more towards the rear.
    February 2004
Posted by JohnReid on Friday, August 18, 2006 7:55 PM
    February 2004
Posted by JohnReid on Saturday, August 19, 2006 1:54 PM
    February 2004
Posted by JohnReid on Saturday, August 19, 2006 2:28 PM
I decided to install the L&R fibre support tubes next.The holes in cylinders 1 and 6 side were drilled deeper to accomodate pins that hold the fibre tube to the side.I also drilled the holes deeper in the fibre tube where the sparke plug leads will enter into the fibre tube.Larger holes were also drilled into the end of each tube for the 6 wire leads to the distributor.
I will now paint this assembly and permanently install it.
    February 2004
Posted by JohnReid on Saturday, August 19, 2006 6:29 PM
    February 2004
Posted by JohnReid on Saturday, August 19, 2006 6:40 PM
While I still have easy access to the area,I decided to do a little weathering using pastels.With a soft fine brush I simply scrubbed a little black and grey pastels into the low spots and corner areas.Now I'll do the fibre tubes.
    February 2004
Posted by JohnReid on Sunday, August 20, 2006 9:40 AM
    February 2004
Posted by JohnReid on Sunday, August 20, 2006 10:27 AM
Now back to the big picture for a moment!
This pic basically encompasses Phase 1 of the "Memories of Flight School" diorama.The main hangar ,the outbuildings and attached modules.The red roof building is the future radio shack/dispatch area.The attached building on the L/H side of the hangar is actually now a garage door/ramp area that allows better viewing into the main structure.Phase 2 (if I decide to do it)will be a 2nd hangar,garage and tool shed as seen in the larger pic to follow.At present I have 2 airplanes,14 figures and 8 cars and trucks planned for installation.The figures are finished,as are 2 cars and 1 truck and 90% of the 2 Jenny airplanes.
I don't want to have a huge front ramp area, as I want the main hangar doors to act like a stage for the diorama and the central uniformed WW1 pilot group ,with little outside distraction when viewing from this angle.I feel that both sides and back of the main hangar can be developed into parking lots with a junk yard out back.(lots of great possibilities for weathering) I am not a great lover of a lot of flora and fauna in my dioramas(or even in my bird sculptures for that matter)but being an airport I don't feel that I need a lot of that anyway.
I have made some minor changes to the storyline as I now will have 2 parade cars in the dio.The original Ford model T and a RR touring car to accomodate all the passengers.In the parking lot there will be various airshow cars as well as trucks(all modified from various 1/16th model diecasts and plastic kits)
I will finish the main hangar and modules first and then the rest on an add-on basis.
That's the plan so far.Should be fun!
Cheers! John.
    February 2004
Posted by JohnReid on Sunday, August 20, 2006 10:33 AM
Phase 2
    February 2004
Posted by JohnReid on Sunday, August 20, 2006 5:40 PM
    February 2004
Posted by JohnReid on Monday, August 21, 2006 9:15 AM
In the interests of not leading anyone astray
Please note:that the stiffups at the base of each cylinder should be horizontal to the top of the block and not at an angle as on my engine.I would under normal circumstances get out the old un-cure at this point and fix it but in this case when it installed in the diorama it really won't be seen.
I have temporarily installed the fibre tube for the spark plug leads but I will not install the plugs or the wiring at this time.This would probably be one of the last things to be done on the engine during its re-build and I may show this being done in the diorama,with plugs and wiring on the workbench.(For further info please see Martin Wolf wonderful build of this engine at www.wwi-models.org)
Martin took a multi-media approach and used this resin kit as a base for a lot of scratchbuilding.
Next its on to the carb intakes and air box.
