Since the last update quite a bit of work has happened on the build overall. Painting was started and finished, along with work starting on the fan-like propellers. Soon it will be onto the wingframe itself, which is a model in and of itself. (Considering it has more then 70 pieces I'll have to scratch!)
As for painting, with the boiler, engine, propeller shaft, rods, muffler, and weight box constructed it was time to paint. The weight box is a simple mix of Testors Steel and Floquil Weathered Black. The weight box to boiler rods are simply weathered black, the boiler is MM acrylic Dark Gray. The box that is seemingly coming out of the boiler is weathered black (for those wondering how it was constructed after the top plate was glued, I simply used Testors Contuor putty to fill in the gaps and made a simple box. Not much to it, just quite a bit of sanding.)
The propeller shaft is just testors steel and the rods are a vary dark mix of Testors Steel and Floquil Weathered Black once again. Lat but not least the muffler was painted in a subtle shade of steel and black.(Obviously it was attached before the putty was applied to the upper portion, but painted afterwards.)
As for the propeller work, it has so far gone off with out a hitch. The propeller on this aircraft isn't like the standard one you see on aircraft today or even in WWI. It's like a hand-held fan, simply a piece of material held by a brace. So to get started on that I had to create a type of brace, it lead me to use toothpicks. Their curved, hence in a way aerodynamic. Plus their their the right radius for this scale.
So once I decided to use toothpicks, I realized some would have to be bent to create a curve for the ends of the brace. This meant going back to the technique of soaking wood in water. Mine soaked a week, but that's because I didn't have time to work on them earlier, you'd be okay with 24 hours or so.
Once soaked through, I made a jig (yep, just like I did in the first steps of this build.) I simply nailed in the nails, based off eyeing it. The curve is your preference, so feel free to make it whatever angle you want.
For the propeller itself I'm using a size 3 clarinet reed, yep one from a musical intrument. If your wondering what reed material exactly, it's French grown Arundo Donax Cane.....how exotic. I will be using the thin end, that's the working end in other words when used with a wood-wind instrument.
Thanks for looking, all comments/questions welcome!!
