GAF
Joe, don't let any of this scare you off! Paint whatever you feel will look best, and damn the torpedoes!
Thanks everyone for the compliments. Antoni, thank you for the information on the colors, also great information about the 352nd too. One of Preddy's "Cripes A Mighty " mounts is on my short list, so this will be useful when its time to throw down the blue nose.
Gary, thanks for the encouragment. I like to annoy my co-workers with the adage of "if you want it your way....Burger King is down the street". That aside, I generally start out with the recommended formulas then eyeball them until they look good to me. I've been doing this since I switched to Tamiya paints.
Anyways, after him-hawing around on a scheme, I ultimately decided to do George Bostwick's Jug soley on the fact that he scored a 262 kill. It also helped that the kit came with the markings. I ordered Superscale sheet #48-1091 at Sprue Brothers with intent to build Eugene Andermatt's "Miss June" only to discover his plane was an early M and had no fillet....for the love of @#$!. Well at least I can use the stenciling and insignias instead of the Tamiya ones.
I started by using Blue Tac to tape off the fuselage demarcation line. The NMF wings and tail surface leading edges were taped off too. I then painted the red cowl ring XF-7 Flat Red, taped it off, then blue tac'ed it to the plane. I then sprayed the panel lines XF-1 Flat Black. For the lighter blue, I mixed up the Tamiya recommendation of XF-18 Medium Blue, XF-2 Flat White, and X-16 Purple, which is supposed to be similar to Azure Blue. I sprayed it and thought it looked too purple. I added some XF-83 RAF Ocean Grey and liked it better. Once It looked ok to my eye, I added white and made condensation streaks across the wings.
![](http://i856.photobucket.com/albums/ab128/joeswarbirds/P-47%20M/paintitk5_zps40bad88d.jpg)
![](http://i856.photobucket.com/albums/ab128/joeswarbirds/P-47%20M/paintitk3_zps2520061b.jpg)
I then used the instructions as a reference and masked off the camo pattern. (note: I had to tap into my fresh blue tac supply.....lol)
![](http://i856.photobucket.com/albums/ab128/joeswarbirds/P-47%20M/paintitk7_zps862c1d00.jpg)
I then mixed up the darked blue. I went with the reccommended XF-17 Sea Blue, XF-1 Flat Black then XF-2 Flat White. It looked too grey to me so I added a touch of XF-8 Flat Blue. I then added more white and streaked this too. Here's how it turned out..
![](http://i856.photobucket.com/albums/ab128/joeswarbirds/P-47%20M/paintitk9_zps0cdbb0dd.jpg)
![](http://i856.photobucket.com/albums/ab128/joeswarbirds/P-47%20M/paintitk10_zps9922b40c.jpg)
I removed all the tape and gave the air frame a light post shade. I also taped off and sprayed the black band around the cowl. I read some scuttlebutt that this band signified a jet kill, like a badge of honor, but I couldn't verify this. Truth be told, I think it looks silly and kind of detracts from the overall look.
![](http://i856.photobucket.com/albums/ab128/joeswarbirds/P-47%20M/paintitk2_zps0f340810.jpg)
![](http://i856.photobucket.com/albums/ab128/joeswarbirds/P-47%20M/paintitk12_zpsbf640b90.jpg)
I have no idea how accurate the blues are, but I'm pleased with how it looks so far. I hope to get started on all of the fiddly bits soon.
Joe
