Correcting a Bad Coat of Future
    January 2014
Posted by Silver on Wednesday, June 17, 2015 3:20 PM
To repair Future is often impossible w/out damaging the work behind it.Golss no spar varnish out shines anything when fully cured in a dust free dry environment.It dries hard and last for many years.I seal my metal finish w/gloss varnish then eight years later it looks the same like it was done an hour ago.also Future holds finger prints real good that the local law enforcement can use it for their training.LOL. take my rare good advice.
    August 2008
Posted by tankerbuilder on Thursday, June 18, 2015 9:46 AM
AHA , Mike :
    I always wondered about that . I have used the stuff on and off with mixed results .When I put it on my latest two aircraft to do decals it came out darned near the same texture as the paint and the same semi- gloss !
     Changed the air pressure and tried again with it straight from the bottle . Same results . It is now used on the floors !
    March 2014
Posted by Lockon on Thursday, June 18, 2015 10:01 AM
Silver
The best thing is not to use Future at all.Enamel or acrylic glosses dry harder and have better quality chemicals
Silver
To repair Future is often impossible w/out damaging the work behind it.Golss no spar varnish out shines anything when fully cured in a dust free dry environment.It dries hard and last for many years.I seal my metal finish w/gloss varnish then eight years later it looks the same like it was done an hour ago.also Future holds finger prints real good...
First of all, Future is an acrylic and it does dry very hard (it is, after all, designed to be walked on!).  Second, how would you have any idea about the "quality" of the chemicals?
Future is super easy to repair (smooth out, remove finger prints, etc): wet sand using Micromesh (or similar) from about 3200 grit working your way up to finer grades, then use a soft cotton rag for the final buff.
I have airliners that are over ten years old finished in Future and they look perfect to this day...
    January 2014
Posted by Silver on Thursday, June 18, 2015 10:39 AM
If Future is super hard to walk on.Why do you use it more often in re - applications on the floor?It scarfs up. , anyway if you want to use Future , go right ahead.
    November 2008
Posted by plasticjunkie on Thursday, June 18, 2015 11:23 AM
Silver
Well, apparently you have not used Future very often. If you goof, fresh Future can be easily removed with Windex as in dipped canopies which has happened to me. Even if it clouds reacting to a wash or solution, another coat will usually  bring back the finish. I use it over enamels and have no problems wiping it off with Windex if the need comes up which it rarely does. I recently removed it when I sprayed it and came out pebbly. Just took a wide brush and a small container with Windex from the Dollar Store and removed all of it with no damage to the topcoat. I let it dry and then brushed on 4 Future coats and looked like smooth glass.
 GIFMaker.org_jy_Ayj_O
    March 2014
Posted by Lockon on Friday, June 19, 2015 10:16 AM
Well... you do *walk* on floors with shoes but most of us don't walk on our models... the point here is that someone asked for advice on how to use Future and some of us who have learned to use it to great effect are trying to help in that regard... therefore, likewise, if you don't want to use it then don't!
Moderator
    September 2011
Posted by Tim Kidwell on Friday, June 19, 2015 11:13 AM
OK, let's keep it civil.
The thread is about fixing an issue with Pledge FloorCare Multi-Surface Finish (what was once Future). Saying and repeating that you don't use it and why you don't use it isn't conducive to the conversation.
Snark isn't conducive either.
It seems that Adam has figured out a solution, and is working on the orange peel in the meantime. If you don't have a suggestion for correcting a problem after using PFM, please move on to another topic.
Tim
Timothy Kidwell
tkidwell@firecrown.com
Editor
Scale Model Brands
Firecrown Media
