Tamiya 1:48 Douglas A-1J Sky Raider COMPLETED
    March 2015
Posted by Toshi on Friday, October 16, 2015 8:13 PM
Before I started the build, as a written commandment, I read the instruction manual thoroughly only to find that several Tamiya XF codes were not available.  So for any one interested.  Here are the XF codes.
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    March 2015
Posted by Toshi on Friday, October 16, 2015 8:15 PM
And now the cockpit.
    March 2015
Posted by Toshi on Friday, October 16, 2015 8:19 PM
    November 2008
Posted by plasticjunkie on Friday, October 16, 2015 8:35 PM
Gamera
Toshi: The Sharpie does work but I think I saw someone here complaining about 'bleed-though' and getting bad reactions with the paint. I won't use them again. I think your paint marker is probably much safer.
Gamera
A while back I mentioned about the use of the regular Sharpies and the reaction to model paints on another thread. Sharpie makes a separate line of oil based markers that are safe to use. Testor's paint pen is safe too. I'm sorry to say that the Sharpie ink will eventually burn thru your paint. It may take months but it may eventually happen.
There are many threads on this very subject so here is one of them:
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/91035.aspx
Toshi
You are off to a good start.
 GIFMaker.org_jy_Ayj_O
    March 2015
Posted by Toshi on Friday, October 16, 2015 11:06 PM
The fuesalage was painted, photo etch added, and per Eduard, I added a copper line on the right and left according to instructions.  Once that dried, the fuesalage and the cockpit were assembled.  Then the other half was placed together, I lined everything up, and it literally went together like a "Snap Tite" kit.  Wow.  Tamiya knows what there doing.
Next up is the assembly of the engine, cowling and the attachment of these assembled parts to the main frame.  This is something I very much with great excitement look forward to!  I can't wait to assemble the wings and the tail.  Dry fitting already has confirmed my assumption that these items are also built like a "Snap Tite" kit.  The body was glued together with the ubiquitous Tamiya Extra Thin Cement.  I've noticed that this is a industry standard.  Well, it worked like a charm.  With the help of some rubber bands.  Please enjoy the photos below.
By the way, I ordered a Trumpeter 1:32 visible Me262 from another seller with a tracking number, for the second time.  Dear Lord, please have this kit not lost and provide me with the Me 262.  With no mail lost, I should be able to receive my Me262 by Monday and a huge bottle of Iwata AB Acrylic cleaner.  I hope this works!  I know this will work!!!!
I tapped my ruby slippers three times and said"There's no place like Tamiya Extra Fine Cement"!  LOL!
Toshi
    March 2015
Posted by Toshi on Friday, October 16, 2015 11:08 PM
    March 2015
Posted by Toshi on Friday, October 16, 2015 11:12 PM
    September 2012
Posted by GMorrison on Friday, October 16, 2015 11:19 PM
Toshi that pen work you wont like. Trust me. You will end up painting it out before you are satisfied.
Either go back over it with more primer, sand it down to a level thats subtle, or seal it with flat lacquer and then prime it.
    March 2015
Posted by Toshi on Saturday, October 17, 2015 1:25 AM
GMorrison
My I ask, what consequences or issues will arise with this Enemal Gloss Black Pen Paint?
    March 2015
Posted by Toshi on Saturday, October 17, 2015 1:30 AM
plasticjunkie
Gamera
Gamera
Toshi
Thank you plastikjunkie, any comments at all will be appreciated.  Thank you so much for following my threads so religiously.  This means very much to me, once again "Thank you sir"!
Toshi
    June 2014
Posted by BrandonK on Saturday, October 17, 2015 12:51 PM
Toshi, I used that exact method on my Me-410 and it just didn't look right while I painted it so I kept painting until it disappeared.
This is where I repainted it. Too the eye, it just doesn't look right. The uneven lines applied by the airbrush provide a more convincing panel deformity that perfect lines with the pen. But, hey do what YOU find works best for you and that YOU like the most. They are your models and no one elses.
BK
PS, you work on the pit is fantastic. Great job, truly amazing.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Saturday, October 17, 2015 3:09 PM
Toshi
The issue with using these pens is that it creates a sharp dark color contrast and it takes some effort to attempt to blend the top coat colors over it. Doing these dark lines with an air brush is different as it creates a soft fading effect making it much easier to blend over with the top coat.
I'm in no way saying it can't be done with the paint pens, simply that it's easier and the effects are better if air brushed on.
Posted by Gamera on Saturday, October 17, 2015 11:09 PM
PJ: Thanks, I remembered someone had commented on the use of the Sharpie but couldn't remember whom. No big deal, the aircraft I'd used them on I ended up junking for another reason.
I have to agree, pre-shading can look too perfect. Here is one place you want to colour outside the lines at least some.
Toshi: Cockpit does look good!
    March 2015
Posted by Toshi on Sunday, October 18, 2015 8:08 AM
Thanks guys!  I now understand what needs to be done.  I really appreciate the heads up.  This has turned into a positive event.  I'll do what GMorrison said and Laquer dull coat the aircraft.  Then I'll re-prime it and go from there.  Again thank you gentleman.
Toshi
    June 2003
Posted by allan on Sunday, October 18, 2015 10:08 PM
Hey Toshi, you dont have to apologize for "lack of contributions to the aircraft forums." I think youve contributed more than anyone of us in the last few months.
Smile
No bucks, no Buck Rogers
    March 2015
Posted by Toshi on Monday, October 19, 2015 6:55 AM
allan
Smile
Thank you allan for your kind words and support.  It's much appreciated.
Toshi
    December 2009
Posted by roger_wilco on Wednesday, October 21, 2015 1:14 AM
Hi Toshi,
Checking in to see things are progressing on your Skyraider build.I thought about you the other day when sorting through my stash as I found a 1/72 A-1 Skyraider kit (Tskuda brand) I forgot about even owning!
"Build what YOU want, the way YOU want, and above all have fun!" - RIP Modeler Al.
    March 2015
Posted by Toshi on Wednesday, October 21, 2015 7:38 AM
roger_wilco
Hi Toshi,
Still moving along just not as much to show as I sprayed it with Testors Laquer Dullcote and Tamiya Primer.  I'm now getting ready to try the panel lines and then the base coat.  Are you going to start on that kit anytime soon?  Thanks for checking in, I'll have some photos up later today or tonight.
Toshi
    December 2009
Posted by roger_wilco on Wednesday, October 21, 2015 10:08 AM
Hi Toshi,
I'm looking through my stash currently trying to decide what to build.I have several Zeros in 1/72nd scale and a couple of those are peaking my interest. But knowing me I could change my mind and wind up building a 1/48th scale jet!
    March 2015
Posted by Toshi on Wednesday, October 21, 2015 10:17 AM
roger_wilco
Hi Toshi,
Sounds like a cool plan!  A Zero and or a jet.  Build both at the same time.
Toshi
    March 2015
Posted by Toshi on Wednesday, October 21, 2015 11:17 AM
To my fellow forum members,
I want to thank the forum members that stepped in to show me that there were several options for me on building the A-1.  I went over everything and finally decided that I'll spray the Sky Raider with Testors Dullcote and use Tamiya primer to cover up the Testors Black Ink Pen panel lines.  This suggestion by GMorrison made sense, thank you GMorrison! I also saw Brandon's experiment of which did not appeal to him nor I.  Thank you for sharing that Brandon.  Lots of fantastic feedback.  I love this forum And it's members.  I guess now, when I need something to be painted black I'll just use the ink pen until it dies. LOL!
I did my best to outline the A-1 panel lines and per some very useful information from M.Brindos, I applied the base coat.  What really helped was that the primer was the same color as the MM base coat.  I still have not been able to replicate what I deem as exceptable, but I did get a half step further.  The panel lines in my opinion are way too subtle.  There's things I can tweek on my next build.  I have some photos of the Sky Raider below.  Please don't laugh as hard as I did!  LOL!
Most importantly, as suggested by everyone here, I had fun and lots of excitement, and I'm still not done with this aircraft.
Toshi
This is where it gets really intense!
I did the cowling first, if I screwed that up, no problems and it was the least of panel lines.
    December 2009
Posted by roger_wilco on Wednesday, October 21, 2015 11:26 AM
It's looking really good Toshi. By the time I type and submit this you'll probably have the next coat of paint on! Really looking forward to seeing the completed model on this one.
    July 2014
Posted by modelcrazy on Wednesday, October 21, 2015 11:29 AM
Toshi my friend that is really looking like a Skyrader. I had no idea they had such large speed brakes! The panel lines IMO, look fine, remember, while darkened panel lines look great on models, you really don't see them to often in the real world.
Steve
Steve
    March 2015
Posted by Toshi on Wednesday, October 21, 2015 1:39 PM
roger_wilco
Oh, no.  I can only wish.  LOL.  So far, I just messed around with the landing gear.  I still have to go over the A-1 and do a wash, I think?  Then there's all those rockets, bombs, and a huge drop tank.
Toshi
    March 2015
Posted by Toshi on Wednesday, October 21, 2015 1:41 PM
modelcrazy
Steve
modelcrazy
Steve
. Yes, there's another dive brake at the bottom of the A-1.  Thanks for the info my friend, I need to still do so much more.
Toshi
    March 2015
Posted by Toshi on Wednesday, October 21, 2015 1:51 PM
Posted by Gamera on Thursday, October 22, 2015 7:21 AM
I think you pretty much nailed it Toshi, that's just what you want- just barely visible.
    June 2014
Posted by BrandonK on Thursday, October 22, 2015 8:47 AM
It looks great Toshi, looking forward to seeing some color on it.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    December 2003
Posted by scottrc on Thursday, October 22, 2015 11:00 AM
Hi Toshi, another great looking build taking shape.  I learned the same way you did about pre-shading.  I thought skipping the set up and cleaning of the airbrush by using a pen or brush on the panel lines would be fine, until the top coats went on and then, like GM said, I could really see the demarcation between black and the top coat. Yuck!  With the airbrush, you can feather the pre-shade out so it will give the subltle, blending effect.
For me, easier said than done, I am still a big novice at it and will be trying it again on my Zero.
Keep on building and posting.
Scott
    March 2015
Posted by Toshi on Thursday, October 22, 2015 11:37 AM
Gamera
It's not as good as you guys, I'm still struggling to get it just right.  Thanks to you as well as other forum members, I at the very least, comprehend the process.  I just need to dial in my skill set.  Thanks Gamera!
Toshi
