Very old REVELL B52 WIP
    January 2018
Posted by PeterPan on Wednesday, February 14, 2018 2:41 PM
mmthrazx, Doing a great job with your project.
To find the scale of your model, divide actual length with model length.
B52 length 49 m, wingspan 56 m.
49 m / 144 scale = 340 mm
49 m / 175 scale = 280mm
Peter
    December 2017
Posted by mmthrax on Wednesday, February 14, 2018 7:36 PM
Thanks Peter.  That is great info.  I really appreciate it.
Just keep picking away at it...
    December 2017
Posted by mmthrax on Monday, February 19, 2018 1:47 AM
Managed to get a little bit done.  I discovered these tiny nubs under the wing.
Evidently they are for the mounting of the X15 aircraft as seen in this old school Revell release:
Trying to keep the collateral damage to a minimum, I used my new tiny files to remove them.
It's not as bad as it looks, and one nub went much better than the other one.  Smile  I made a small cradle from a pool noodle (thanks to the shipbuilding.ca website--credit where it is due) and got the tanks mounted.  Those went well.
That's where it went south.
    December 2017
Posted by mmthrax on Monday, February 19, 2018 2:10 AM
I mounted the engine pods to the mounting struts.  Big mistake.  I should have mounted the strut to the wing first.  The net result of this is that the engines are not level.  The struts did not want to fit properly and I began to stop smiling.  I decided to lose the battle today to try to win the war tomorrow.  They went on the plane, badly, and I decided to putty the gaps.  That procedure seemed to go well.  I have a feeling that it will all work out.  I'm smiling again.  Laughing as I learn.  Confused  Time for primer.
    July 2014
Posted by Bakster on Monday, February 19, 2018 9:10 AM
Problems aside... it sure is a cool looking plane. Keep at sir.
    September 2012
Posted by GMorrison on Monday, February 19, 2018 9:37 AM
Sure looks like a BUFF.
I'm impressed- this model was conceived as little more than an "afternoon" build. You are doing a really swell job.
    December 2017
Posted by mmthrax on Monday, February 19, 2018 12:52 PM
Thanks guys.  I appreciate that.  Smile
    August 2013
Posted by Jay Jay on Monday, February 19, 2018 6:22 PM
Nice job overcoming the fits and problems of this kit. it's gonna turn out well in your capable handsYes
    July 2004
Posted by stikpusher on Monday, February 19, 2018 8:09 PM
GMorrison
Right... I built it as a kid in such a session... this one is coming out far better...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2017
Posted by mmthrax on Monday, February 19, 2018 11:21 PM
Thanks Jay Jay and Carlos.  I appreciate the kind words.  It motivates me to do better.
I did some more putty work around the engine struts and tanks.  I am using the Perfect Plastic putty.  So far I really like it.  I am using the tiny syringe, then using a green microbrush with a tiny bit of water to try to smooth it.  When they say it is water soluble, it is VERY water soluble.  The tiniest bit of water will set it off.  I feel like I am using a "dry brushing" technique to try to move and smooth the stuff around.  I am having decent results.  I then use a Q-tip to try to remove any wet streaks that will dry later.  Hopefully, once I get this fairly smooth the primer will help.  Of course it will reveal what madness is to ensue. Smile
    August 2015
Posted by crown r n7 on Tuesday, February 20, 2018 7:00 AM
way to go !!  fill those gaps. you teach them gaps
 Nick.
    December 2017
Posted by mmthrax on Tuesday, February 20, 2018 11:36 AM
Thanks Nick.  Doing my best.  Some of the work is pretty rough, but I am where I am in my progression, and I can't be anywhere else.  It will get better.  Thanks for the read and reply.
    September 2006
Posted by the Baron on Tuesday, February 20, 2018 12:29 PM
Great progress!  "Patience and perseverance made a bishop of His Reverence!" Smile
mmthrax
...I am using the Perfect Plastic putty.  So far I really like it.  I am using the tiny syringe, then using a green microbrush with a tiny bit of water to try to smooth it.  When they say it is water soluble, it is VERY water soluble.  The tiniest bit of water will set it off...
Yeah, one of the guys in my club mentioned that, when he used the putty, then tried to wet-sand the seam.  The water dissolved the putty.  It's a very minor disadvantage to a product that has received glowing reviews otherwise.
    December 2017
Posted by mmthrax on Tuesday, February 20, 2018 12:57 PM
the Baron
Thanks Baron.  I haven't heard that one before, but I like it.Smile
the Baron
 Agreed.  I would say it is minor.  So far I haven't needed to wet sand anything.  I may have a differing opinion in the future.  I am taking it as it comes.
Thanks for stopping by and commenting on my build.
    January 2018
Posted by PeterPan on Wednesday, February 21, 2018 2:30 PM
mmthax, what do you use for putty? I need to get that stuff.
Peter
    December 2017
Posted by mmthrax on Wednesday, February 21, 2018 7:31 PM
Thanks Peter.  I appreciate that.
I am using Perfect Plastic Putty.  I like it so far.  Make sure you order the syringe kit too.  If I was using a spatula it would be a disaster.  There is a good promo video of it on youtube.
Thanks for stopping by.  Smile
    January 2018
Posted by PeterPan on Thursday, February 22, 2018 6:26 AM
Thanks Mark.
Peter
    January 2018
Posted by PeterPan on Saturday, February 24, 2018 4:11 AM
If the putty is so soluble to water, it may be of advantage for cleaning up the dry rough bits with a most, not wet, Q-tip or rag.
Peter
    December 2017
Posted by mmthrax on Saturday, February 24, 2018 11:21 AM
I've noticed it is a delicate balancing act.  I have been using a BARELY wet microbrush to try to manipulate it.  Any more than that and you risk washing out the whole joint.  I'm still trying to get a handle on it.
    January 2018
Posted by PeterPan on Thursday, March 8, 2018 1:55 AM
What's happening Mark?
I am going to have to make more popcorn.
Peter
    December 2017
Posted by mmthrax on Thursday, March 8, 2018 5:23 PM
Hi Peter,
Thanks for checking in.  Yes I suppose your last batch has gone stale.  Sorry about that.  The weather here has been dismal.  If it is not freezing cold it has been flash flooding.  I ordered and just received the small desktop paintbooth.  Need to get some paint on this thing.  Should have a new report real quick like.Smile
    January 2018
Posted by PeterPan on Thursday, March 8, 2018 7:08 PM
A paintbooth? I made one a while ago, but it has not been used that much.
If you don't mind, please send us a photo of your desktop paintbooth.
Peter
