Ok gents, I'm calling construction work on this one done!
Those damn fenders took way longer to assemble than I thought...
Fenders aside, here are some pics for you:
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger048_zpse36327e0.jpg)
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger049_zpsb53d780d.jpg)
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger050_zpsa73434b3.jpg)
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger051_zps363c53e8.jpg)
I managed to break the "tip" of the turret MG mount off and wasn't able to find it again, so I simply took some Evergreen plastic profiles (H-profile and plastic tubing) to build one from scratch. I think it actually looks a bit better than the kit part...
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger052_zpse34e5e37.jpg)
I replaced all the handles on the hatches with 0.6mm copper wire (only 4 handles in total) and adde some wiring to the headlight:
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger053_zps2b04cca8.jpg)
I also glued the front fenders in place:
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger054_zps39801f7b.jpg)
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger055_zpsd4f6fc38.jpg)
I had to glue one of the side fenders on as well, because the fit of those 2 fenders was rather poor. There was a 1mm gap between them, but I think I managed to cover that one up with the PE strips "connecting" the fenders.
Next thing to add were the rear fenders. Those things were a royal pain to assemble, because I was restricted to superglue only. I don't have any soldering equipment and also none of the required skills...
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger056_zps6ea414f4.jpg)
![](http://i1275.photobucket.com/albums/y459/SchattenSpartan/DRAKingTiger057_zps6945547a.jpg)
I dropped one of the PE hinges and wasn't able to find that one either (what a surprise!). I decided to shave off the hinge detail from the kit part and use that one instead of the PE hinge. I don't think the difference will be too obvious when it is painted. Most of that stuff will have at least a slight amount of mud on it, so I can hide some of that area anyway...
It's time to spray some paint on this Cat, so off I go to my bench again to get some paint in my AB! I won't post pics of the painted model today, because it's already 1 AM here in Austrai and I'll go to bed immediately after finishing this painting session. I'll post some pics tommorrow evening...
Cheers, Clemens
