Its over, its over , its over. ![Sad](http://cs.finescale.com/emoticons/emotion-6.gif)
Alas, I wasn't able to finish the Panther F. After moving I ended up in a deep funk and just couldn't get back into modeling, even though my work bench was ready a month ago. But I decided to force myself back, so last week I started working on the resin F turret, hoping I might complete the kit in time. I realized that the IR assembly couldn't be fitted in the cupola because the resin turret is solid, not hollow, and there was no rim underneath to attach it to. So I spent the better part of two nights slowing hollowing out the inside of the cupola and turret with a Dremel to create a rim underneath so I could glue in the IR mount and also because the hatch would be open and I needed to create some depth under the cupola.
Not being able to access the interior of the cupola rim so that I could scrape out enough resin, I decided to drill a large hole from the bottom so that could I insert a micro-chisel and try scraping from underneath. I was very careful to make sure the drill bit was in the right spot and drilled very slowly. I didn't want the drill to go too far and drill right into the cupola! So guess what I did?? Yep, despite my best intentions, the drill bit pulled itself too far, before I could stop it, and chewed away part of the cupola......![Bang Head](http://cs.finescale.com/emoticons/icon_smile_banghead.gif)
![](http://i197.photobucket.com/albums/aa263/bufflehead5/Dragon%20Panther%20F/DSCN5000_zps7c23b61e.jpg)
![](http://i197.photobucket.com/albums/aa263/bufflehead5/Dragon%20Panther%20F/DSCN5001_zps7a643bf3.jpg)
(sigh) This happened last week. I was so disgusted I just walked away and couldn't return to the bench for a few days. I knew I couldn't fix this in time, if even I could fix it. I can't use the kit turret because I already used it for some painting experiments....its too far gone.
The kit is too far along to give up on. I'll add it to my shelf queens and try to find another resin Panther F turret for it. Maybe it will grace the FS Forums before too long!
Sorry to all for my absence. Looking back over the last couple of pages I can't believe the great work you've all done! Kudos to all of you for the outstanding work and to Eric for another fine Group Build.
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
![](https://media.fotki.com/2v2HMhuUqxAhM97.jpg)
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
![](https://media.fotki.com/2v2HyLWnJxAhM97.jpg)
