Terry and i knew we wouldn't get a lot of entries like a TIGER GB would but we knew those who joined would be as weird as us.
Terry where did you get the figures and what did you use for the camo net? and how did you build the switch? i would like to do one in 1/35 but taht would call for my mini torch to heat the rails sufficiently to bend them.
all the builds are really nice, the figures fit and i can see the story, which is really important in a diorama. two things jump out and i really don't know how to change one of them easily.
firstly everything is panzer gray.what can you do? if it's prior 1943 there are no options and color modulation doesn't have enough contrast at this scale.
secondly everything is parallel to the sides of the base. AGAIN this will be a problem with RR dioramas unless you want a HUGE base. and cutting track and ties at an angle is just plain annoying. even if you put a road in diagonally for the FLAK, it would widen the base A LOT.
these are not critiques of your build but general observations on RR stuff. obviously if we need a base for a single locomotive the parallel issue isn't relevant. my 1/35 RR gun will be 3 feet long and 8 inches wide minimum to dispaly the gun, 4 feet plus if i add the flatcar and ammo, min 18 inches wide if they offload from a truck next to it. both are big footprints and i have no blinding revelations on other options.
guess i best figure it out since i will be doing the revell 1/200 Big Ass coal mining bucket loader next year.
