Got some more work on this Cat.
This Hasegawa kit is a bit over engineered and a lot of things could have been simplified. For example, the nose gear is maded up of 12 parts, the mains are 8. The intakes is another bunch. Some parts fit good and others do not, requiring trimming and sanding. Usually Hasegawas have a good fit but this one requires a little help. None the less it's a great looking model.
It's about ready for paint which I hope to get on by tomorrow. The tail fins did not line up either cause the mounting tabs were too long. I had to slice off a bit from each tab to make the fins properly fit on the rear fuselage.
![](http://imageshack.com/a/img903/179/aAgpy8.jpg)
Hasegawa does not include any weapons in the kit so their weapons set was used. The Aim54s were drilled for mounting pins made from stretched sprue. Corresponding holes were drilled on the pallets and wing pylon mounts.
![](http://imageshack.com/a/img911/5483/LOwgG7.jpg)
I was very surprised and pleased to find the Aim54 pylon mounts included in the kit!
![](http://imageshack.com/a/img911/7070/zNzqcl.jpg)
It looks different than the common Sparrow set up. A Sidewinder will be on the top rail.
![](http://imageshack.com/a/img910/4476/pWaaKt.jpg)
The tanks, tail hook assembly and weapons were all assembled, sanded and polished and ready for paint. The kit includes several different chin pods ranging from early to late updated A Tomcat.
![](http://imageshack.com/a/img907/1743/aPk8SL.jpg)
I just need to add some small parts, mask the canopy and windscreen and it will be ready for some color.
