Hey mg.mikael, just to prove I've started on the DUKW, I snapped a couple of pics of the pit under construction.
So it begins, the epic tale of...
Mobi Duck
this is a pic of the kit intake screens. It would've been nice to have had these molded seperatley. A series of holes were drilled, then with a razor I played connect the dots until the screen section was removed. Then came a series of files starting with a coarse .5" wide flat all the way down to a flat needle file, then the sanding, and then a little work with the scalpel to finish off the openings.
A frame was built with styrene angle to accept the screen and some strip styrene was added as a retainer for the screen. This is a pic with the shrould in place on the starboard side. I still need to add the exhaust pipe which runs out this side and tweak that misaligned styrene strip.
The molded on pedals were replaced by strip and rod styrene. All the shift levers for the tranny, the transfer case and the E brake lever were kit parts cleaned up. The DUKW's cabin is nearly all plywood construction, and as such I added wood grain with a needle chucked into my pin drill.
The kit provided seats were IMO are very well done. A little clean up was all that was required.
I'll try not to post too many pics in the future. Should have most of the cabin finished and painted by this afternoon. Then it will be on to the cargo hold.
Thanks for checking in...
Mobious
