Thanks for the comments stick man! Now here's that update I said I'd get up.
Been doing alot of work in the front, back, and inside the scout car. In the back I've started putting in the handles and support truss for a step plate. The pieces fit in quite nicely, but a seam does have to be removed on every truss piece.
The doors have also been fixed and painted up. Eash door has three major pin marks on the interior, so those have to filled in, no doubt about that. On the exterior their aren't pin marks, but theirs some shallow marks that could use a bit of putty.
As for the dash, I painted the dials and then filled them with a little Testor's clear parts cement & window maker. The engine wall behind the dash needs just a base coat and nothing more. Thank goodness. When the hood goes on, the engine wall completley vanishes from view(since the dash is in front.)
Finally here's all the work done so far. The hood is on, the window frame is on(clear part to go in later), and the round frame going around the top is finished.
