Finally, here's my long overdue update on my Bren carrier. Alot of pics, since most are progress shots of what I started with and how it progressed.
Here's a pic of the tracks without the mask before they go on the carrier.
Here's the kit supplied tow cable, but it just looked too plain since it would be going on the front hood of the carrier. So I decided to make my own using the string you see in the background.
I had to carve off all the tow cable on the kit piece, but keep a minimal amount since I needed a base for the new tow cable to go around. The other piece is the radio, for which I had to scratch a back for, since Tamiya seemed ignorant of adding one.
Here's the improved radio and the tow cable so far. Wrapped the string around the plastic piece, using super glue to get the ends connected, then just a slight dip in some Elmer's glue water. Then it was painted a basecoat of Testor's Steel, washed black, then covered in hydrated iron powder(haven't gotten around to removing most of the powder yet, so it looks darker then it will be.)
The suspension springs looked like c***, so they had to go. My replacment......the springs from inside a lock. Yes, you heard right a lock. I needed super small springs, so I cracked open some old locks in the basement, and presto! Perfect 1/48 suspension coils. However I didn't have enough so I had to scratch a few out of copper wire. Nevertheless how's that for scratching!
They were painted a darkened mixture of Testor's steel and black, then roughly covered with MM acrylic green. The bar inside the coils are actually the kits suspension coils that I cut off. After sanding off any detail, I shaved them down to fit in the springs.
Here's some pics of the entire Bren carrier so far:
Thanks for lookin'!
