Helicopter Group Build 2009
    March 2007
Posted by bondoman on Tuesday, June 16, 2009 2:11 AM
Ouch. Actually, no, I met her in China on a hotel balcony and repaired her camera in an hour, flat, using the basics in my shoulder bag.
    June 2003
Posted by Avus on Tuesday, June 16, 2009 2:17 AM
Wow! Nice to see some familiar faces or avatars and there are some interesting subjects.
Badge-proposal:
What do you think?!
Klaus
Thanks to ImageShack for Free Image Hosting
    June 2008
Posted by lewbud on Tuesday, June 16, 2009 2:44 AM
Cool.  It worked and continues to do so as far as I can tell.  You are a lucky man.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    March 2008
Posted by ludwig113 on Tuesday, June 16, 2009 7:15 AM
 Avus wrote:
Badge-proposal:
What do you think?!
looks good to meThumbs Up [tup]
    March 2008
Posted by ludwig113 on Tuesday, June 16, 2009 11:57 AM
ok here goes...this is my build,or it will be on the 1st of july.
i kind of like the gazelle as it was the first helicopter i flew in...
    March 2008
Posted by modelchasm on Tuesday, June 16, 2009 12:13 PM
Badge-proposal:
What do you think?!
Hey, yeah! I like it .... there's no Killer Egg (hater) but yea, I like it!
BTW, I'm going to need A LOT of help with questions during these builds. As stated on the helo forum earlier, us ground pounders know JACK about little flying thingys with spinner ... thingys. We just get rides and then hop out when the ground get close .... :)
"If you're not scratching, you're not trying!"  -Scott
Posted by jeaton01 on Tuesday, June 16, 2009 5:02 PM
Now, I am really upset at the inexperience being shown here!!.  Avast ye all, lest ye be run down the tail boom of the venerable H-19 with the tail shaft cover not in place!!
There is only ONE proper way to motivate a model rotorcraft around the front yard.  You must put your right thumb in your belly button, whilst holding said rotorcraft in the remaining digits of that hand, and looking down blow on both the main and tail rotors, else both main rotors in that type (for autogyros an electric power source or rubber band motor may energize the prop) so that the effect is convincing to onlookers.  While these things are being done, it is merely necessary to rub your hair (or pate, as the case may be) with your left hand and utter "Froom  Froom Froom" as you pivot around while running around in the limits of your yard.  There will be no spitting or drooling as that may mar the finish of your model.  If dizziness is imparted eventually, or other effect of being out of breath if you are not an accomplished operatic Bass, or Tuba player in a Polka or Mariachi band, you will eventually safely autorotate yourself to earth, transferring the model from your right to left hand as you descend withouth losing simultaneous contact with either belly button or head (pate).  Those of the left handed persuasionmay reverse the hand sequence, those who are ambidexterous may make the choice, but must state the choice in writing beforehand.
Quite simple, really, much easier than keeping the throttle correlated on any Bell or Hiller of the early days.  Those newbies who came along and have operated only turbine powered helicopters with the little hat switch to set the governor may have a bit more practice to do.  And then of course, those hydraulic fluid drenched persons like me who primarily worked on the wretched things and went through the contortions necessary to do that and flew them less frequently until later years will have no trouble whatsoever.
So there, Bondoman, you have it.  There will be no easy out.  As to you being a lucky guy, surely it be so.  But is SHE a lucky girl?  Maybe in time, if your deportment improves in the latter  days.
Avus, thank you very much for the fine badge.  Make It So!!
Ludwig, I'll update the first post with your build.
Lewbud, you are on the roster.  Happy camping, and yes standards for entry are a bit loose, just like discipline in the typical helicopter unit.  Those officers really know better than to mess with the guys who tighten the "savior" nut.
John
    September 2015
Posted by Aaronw on Tuesday, June 16, 2009 10:30 PM
 bondoman wrote:
 lewbud wrote:
I see you let that scurvy dog Bondo in so I guess you'll take just about anybody.
I vomit out my crew door down onto your rotor, sir!Yuck [yuck]
And so it begins.My father made me promise (aeronautical engineer as he is) to never ever ride in one of these infernal machines, which have absolutely nothing to do with science.
It's like an elevator without a building. It's like an updraft without a parachute. It's like a train without rails. It's like positive pressure in an outhouse. Oh, never mind.
Captain Eaton, as my friend Keith who was a pilot in Hueys in VN always said, when you hear the pop, duck and get to know the collective like your mother. I may quit this mess yet, unless someone can explain to me how to run around my front yard with the finished model and make RRRRR noises. I'll probably trip and go endover into the pond. Oh, but the helo will flutter to earth. Not likely, AAARRRGGGHHHPirate [oX)]
Gaaah, helicopters don't go RRRRRRRRR, they go fwop fwop fwop. Evil [}:)] Big Smile [:D]
Posted by jeaton01 on Tuesday, June 16, 2009 11:37 PM
That is true, unless they are Italian, and then Dago Wop Wop Wop.
John
    March 2008
Posted by modelchasm on Wednesday, June 17, 2009 1:07 AM
holy crap ... I don't know if I'm coordinated enough to be apart of this GB!?! fwop fwop RRRRrrrrr ... ??? All I've ever known if Stomp, stomp, stomp, point tap, tap, tap ....
Maybe I could just get one of you guys to "fly" me around the yard ....
Drop off and pick at the nearest LZ anyone?  :)
    June 2003
Posted by Avus on Wednesday, June 17, 2009 1:25 AM
Thanks jeaton01 for clarifying the technique and the international standards!
I'll have to adapt this technique to the balcony (no yard for me!) and avoid incoming AA from hostile pigeons!
As for the badge I'll post a link to the resized image a few days before the build starts. This way we can wait for other proposals.
Klaus
    March 2007
Posted by bondoman on Wednesday, June 17, 2009 1:44 AM
Self appointed Crew Chief Bondo says that the basis of this GB is Humor.
I want a video from someone by 10.00 pm Friday, PST. Photobucket will host your download.
The point is I am looking for some helicopter humor, which is a given since the things are a joke. Of course they aren't and a Vietnam committee would be a most welcome thing. I ask for a volunteer the idea being that it's a build-within-a-build.
I'll have an entry but you'll all look winded if you don't contribute.
John Eaton may have contributed to this order.
To Mike Forney:
http://www.youtube.com/watch?v=2K0bGlUSz20
Hiller employed three of my cousins.
    March 2008
Posted by modelchasm on Friday, June 19, 2009 6:21 AM
So, I've tried not to work on my MH-6 dio so that I can have it be part of the GB when it starts up, but I'm having WAY too much fun with it and its really come a long way this week. I don't think that I'll be 100% complete with it by the start, however, I don't think that w/ the progress that I've made on it that it would really fit the bill for the GB anymore. W/ that said, I'm not backing out, but rather just mark me down for Academy's 1/35 OH-58D for the GB.
Posted by jeaton01 on Friday, June 19, 2009 4:11 PM
So then the OH-6 is a "practice build".  Smile [:)]
John
    November 2008
Posted by Justinryan215 on Friday, June 19, 2009 8:15 PM
If I get the time, I may also do Revell's 1/48Apache...we'll see how timecomes now that I amback in the workforce!
Justin
"...failure to do anything because someone else can do better makes us rather dull and lazy..."
Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth...
    June 2009
Posted by Tango Juliet on Sunday, June 21, 2009 1:21 PM
I've been away from plastic for a few years, but what the heck, count me in.  Now I'll have to figure out just what I'll model.  I currently work for Era Helicopters, LLC, as a CSR, so it'll more than likely be one of ours.  I'll let you know sometime this week.
 ***Make it a UH-1N from the now defunct 72nd Helicopter Sq., Langley AFB***
Ever since we de-activated the Squadron in November of '95, I've wanted to do this.  The only trouble is the Wing and Squadron markings.  I've never tried to make my own decals, and I don't think there are any available after-market.
TJ Rohyans
Mobile, AL, USA
    September 2015
Posted by Aaronw on Sunday, June 21, 2009 2:57 PM
Check with fireball modelworks, he does a lot of UH-1 stuff and has on occasion been able to help people out with custom markings for their UH-1 builds.
http://www.fireballmodels.info/
    June 2009
Posted by Tango Juliet on Sunday, June 21, 2009 3:32 PM
I may look into it (there not on his current list of things).  Thanks.  I know back in 2006, I got some after market sets from another decal supplier for other units and was happily surprised at what I was able to find (5th TFW, Minot AFB, ND; and the ANG Unit F-4's from where I grew up in Ft. Wayne, IN).  Since I'm just getting back into this, I'll have to dig through my supplies and see who that was.
TJ Rohyans
Mobile, AL, USA
Posted by jeaton01 on Sunday, June 21, 2009 4:44 PM
You're on the list, TJ.  Welcome aboard.
John
Posted by jeaton01 on Sunday, June 21, 2009 4:50 PM
Klaus, I've seen no more submissions for the badge, so are you happy with us using the one you offered?  I like it.
John
    June 2003
Posted by Avus on Monday, June 22, 2009 9:50 AM
Not only I'm happy, I'd be honored!
This is the link:
http://img20.imageshack.us/img20/7739/heligb2009badge.jpg
as usual you have to encose it in the [img-] tags.
Klaus
Posted by jeaton01 on Monday, June 22, 2009 12:33 PM
OK, then, we will make it so.  The badge can be added to your signatures at any time.
John
    March 2007
Posted by HM2 Somers on Wednesday, June 24, 2009 7:55 PM
Please, how do you add badges to your signature? I've looked and can't figure this out. Pam
Pam
    July 2004
Posted by Aussie747 on Wednesday, June 24, 2009 10:29 PM
Sign me up!
Revell NH90 as an Aussie MRH90
Ray
    June 2003
Posted by Avus on Thursday, June 25, 2009 1:27 AM
Go to the "Update Profile" page and paste this link (removing the asterisks) in the signature box:
[*img]http://img20.imageshack.us/img20/7739/heligb2009badge.jpg[*/img]
Remember to click the "Save Changes" button on the bottom of the page otherwise the new signature won't be saved.
Klaus
    March 2007
Posted by HM2 Somers on Thursday, June 25, 2009 8:32 AM
Thanks Kalus! I take it we are supposed to store the image on a site and then paste the link in?
Pam
Posted by jeaton01 on Thursday, June 25, 2009 11:17 AM
You are on the list, Ray.  Welcome!
Pam, yes the image has to be hosted somewhere.
John
Posted by darson on Friday, June 26, 2009 1:58 AM
John please sign me up for a Revell 1/72 Aussie ARH Tiger.
Cheers
    September 2003
Posted by blkhwkmatt on Friday, June 26, 2009 10:37 AM
I just received the Eduard Photoech parts for my UH-60L, and I must say that they will look awsome and will add so much to the bird.  Right now it is taking all my willpower to not order the Cobra Company UH-60L resin sets, although they would add so much to the project.
Here is what I am thinking about making the Hawk look like, I'll have to scratch some of the stuff that is missing from the kit and add the Flare buckets but that shouldnt be too terribly hard, just a bit time consuming.
Matt
Quidquid latine dictum sit, altum videtur!!! - Anything said in Latin sounds profound!
Posted by jeaton01 on Friday, June 26, 2009 5:14 PM
Gotcha, Darren.
4 more days before the official start date, and it looks like Matt is ready at the gate.
John
