Thanks!
I'm not sure it's an exact match to the real aircraft. I thought I had the paint I needed but when I pulled it out most of the bottles had dried up. I live about 45 min. from the nearest hobby shop and was snowed in. Since I had a whole drawer of green and brown paint I tried to match it as closely as possible to the colour plates in Geust, Keskinen, and Stenman's Red Stars: Soviet Air Force in World War Two.
I've been using the pre and post-shading style I picked up from Floyd Werner's DVD set. Lay down a base coat, apply darker paint to the panel lines, apply lighter paint to the center of the panels and then spray a light dusting of thinned base colour to blend everything together till the shading is barely visible.
Bottom: Base: Model Master Enamel Russian underside blue
Dark: Sorry I forget what I used.
Light: MM Lichtblau RLM 76
Green: Base: Tamiya NATO Green XF-67
Dark: Tamiya JN Green XF-11
Light: MM Russian Armour Green
Brown: Base: MM Leather 4674
Dark: Panzer Schokladnbraun 4797
Light: MM #4 Brown 4249
Everything acrylic except the Russian underside blue that the hobby shop only had in enamel. It's a little complicated at first but once you do one or two aircraft it becomes pretty simple.
