MrSquid2U
SF,
I probably should but I'm just not one to make Dios? That would be the way to go but I don't wanna embarrass myself.
And thank you!
Not necessarily a full on diorama but a display base to show off the articulating suspension. If the suspension remains dynamic (working) then its easy as the vehicle will fit the ground. If you chose to glue (lock) the suspension in a position then make the ground match the wheel bottoms.
Once you have the 'shape' of the ground here is some easy steps to make cool looking & realistic gound work:
Ca glue on the largest stones, after use diluted white glue to add smaller ones and sand like material. (largest to smallest) Use progressive layers to fill in around the larger stones and not on top of them. Shake off excess each step, even brush off with a coarse brush.
Spray the entire scene with light or med. gray primer.
Wash with acrylic red / brown.
Dry brush with light gray, keep every paint step random and not uniform.
Add grass & vegetation to suit, if you stick with a 'moon buggy or desert creeper theme then adjust vegetation & colors accordingly.
This is a 1/144 scale 38(t) with model RR scenic grass & shrubs using above described technique.
