SF - "Chwat" is looking great to me! Bummer about the tracks but do you think it will be obvious when she's finished? I don't think it will be too bad unless someone really studies it. I'm curious to see how you'll lighten up the colors too.
Eat - Nice job on another one finished! Looks like it's armed for some hard ground pounding!
Hans - The interior of the Val will look good with the little details. The engine will look good too with the PE wiring. Looking forward to seeing the engine painted. What happened to the "war room"?
Ruddratt - Simply marvelous engine! You're in a whole other league of modeling than me! Nice!
Well, I pulled out the old Flamingo again. A little work here and there is better than none at all!
Worked on the rudder because I wanted to position it off to one side. There was no line for a rudder so I laid down some Dymo labeling tape and started scribing with a needle in a pin vice. Once I had scribed a good cut in it, I finished it off with a PE saw.
I then drilled three small holes in the back of the tail and glued in some .020 styrene rods and cut them to length.
Next, I needed to make matching holes for the rudder. To do that I added a dab of red paint to the rods and put the rudder in place. Now I have a nice guide as to where i can drill my holes.
Then I drilled the holes in the rudder at an angle. Slide it in place and... "taa-daa"! All finished!
