Kermit,
Great job on the Spitfire! I like the engine detail, which kit is it? (being lazy here, thought I would ask vrs flipping through 20 pages)
Ok, a lot shown in this picture. The road wheels are barren on the inside, the white row of circles will be cut out & centers punched out so there is a separation to paint between the rim and tire.
The 75mm ammunition has a coat of Brass enamel with flat black tinted with silver on the tops. A coat of acrylic flat black wash will follow with the tips highlighted with graphite (pencil lead)
The upper hull has its base coat of enamel flat white, a light wash of ??? will follow, being careful to not darken to much. On the rear deck are the plates to be above the tracks. To be installed after the ammunition is loaded in the magazine.
The lower hull has painted components sitting in it. The seats are made with a punch set, the cushions show how close the sizes are on the Micro-Mark punch set. The transmission & drive line was sprayed with automotive dark gray primer, then a mist coat of auto light gray. Finally a acrylic flat black wash followed with a med. gray LIGHT dry brush.
The lower hull needs a strip of styrene to hide the gap in the sides above the tracks, this will be done before paint as the upper needs to be complete to dry fit to get this accurate.
All this shown in 1 picture!
Decided to stick with the open hatches, thus the interior detail is finished accept the 75mm gun interior components and a few minor details like a fire extinguisher & maybe a head phone set or two...
