Combination of progress and intense frustration with the Wildcats last night.
It was still raining pretty good last night, so no dice on priming the engine or cowl interior. One day...
In the meantime, I got the wings installed, finished up my initial Mr. Surfacer/sanding pass of the main fuselage seams, and went back in with the putty.
![](http://i780.photobucket.com/albums/yy86/doogsatx/F4F-3%20Wildcats/288d09fa.jpg)
The wings were tricky. The mounting tabs are extremely shallow, and there's basically no way to "seat" the wings so that they stay up on their own. This made for an interesting process that involved bracing one side of the 'cat with a bottle of Windex, applying CA around the mounting tab, shoving the wing into place, then grabbing the Touch-n-Flow and doing the solvent thing while holding the wing in position with my left hand. Everything went together mostly well enough up top. There's a small step between one of the wings and the fuselage, but I figure the yellow wing/NMF fuselage will more than hide it, especially after sanding and filling.
The bottom is a bit nastier. Focusing on getting the topside alignment correct created a pretty massive misalignment between the bottom wing and fuselage that will have to be filled with probably two layers of putty.
![](http://i780.photobucket.com/albums/yy86/doogsatx/F4F-3%20Wildcats/db52d05a.jpg)
Lastly, I got around to test fitting the canopies last night. I was going to go ahead and Future them, but after the Dauntless' stacking-averse canopies, I figured I'd be a bit extra diligent on this front. Good thing, too, since the windscreens on both kits sit noticeably higher than the canopies (and the canopies are too thick to be mounted open). I thought about trying to shim the bottom of the canopies to bring them level, but that would create an arguably more noticeable misalignment between the canopy and the fuselage immediately aft. And shimming at an angle would throw off the windscreen/canopy vertical alignment. So I spent an hour carefully sanding and filing the bottom of the windscreens. It helped somewhat, but the height difference is still noticeable, and I'm afraid any more filing will start to compromise lower framing and overall fit.
Here's after filing:
![](http://i780.photobucket.com/albums/yy86/doogsatx/F4F-3%20Wildcats/6007d483.jpg)
I keep telling myself "these are for the kids...they don't have to be perfect"...but the perfectionist in me hates that! So I did some digging on the interwebs, found a few others with the same issue, and one person who fixed it by replacing the windscreen with glass from another manufacturer's Wildcat kit. So at present, I'm planning to call Tamiya and order two replacement canopies. I figure at best, the windscreens work as a direct replacement (minus the telescopic sight, which, since I'm going for "accuratish" rather than accurate, who cares?). At worst, I'll have the bits to pose them open canopy.
Any thoughts on the plan? Ridiculous? Retarded?
