As promised, here's some WIP shots of my Tamiya Meteor.
I finally got back to work on it a few days ago when I realised how close the deadline was, and wasn't about to have a host no-show on two GBs in a row!
I built the fuselage ages ago and began this round by following the plans and attaching the lower wing, with its counterbalance weight to the fuselage. Right there I would heartily recommend diverging from the plans: if and when I build another I will attach the top wing halves to the bottom, and probably go through the whole nacelle phase too, before mating the assembly to the fuselage, as the slightest misalignment throws the rest out of whack, right down to the fit of the intakes. I'm not thrilled with the fit but it's not bad.
I started the nacelle phase by prepainting the engines. The intakes are open and although I'll be building her with closed nacelles the engines are still visible, so I painted just the front of the engines with Tamiya acrylics. Here are the two units:
Then I went on to building the nacelles around them, the intakes and top panels needing a bit of jiggling into place:
In the end the intakes snugged into place fairly well, there are a couple of joints that could do with a whisker of filler, but nothing compared to the fuselage/wing underside joints. The front one fit great until I committed to glue, then it was a mile out...
Here she is with the tails and airbrakes fitted:
The cockpit is the next stage, and I have a mask set on its way, due this week. I have one of the three correct shades of paint in stock and will pick up the others next week also... I want this one on the shelf by New Year!
Cheers, thanks for looking,
Mike/TB379
