Progress update with pics. As noted last update, intakes are installed and I've begun the dreaded filling and sanding. Little bit more work to do on the underside.
Meanwhile, I've also turned my attention back to the top to finish the area behind the cockpit. That requires some surgery first. The colored areas have to be removed for future Aires resin and PE.
Some quick work with the Dremel and sanding sticks...
Behind the cockpit is an avionics storage area. I believe it's called the "hell hole" on F-15's, no idea if the Navy calls it the same. It's also where the canopy mechanism sits. First up for this area is the Aires resin top glued to the piece I just modified.
Here is the Aires resin avionics detail. This will be glued to the underside of the Aires top portion.
There is a mesh screen represented in PE that goes in last, but I need to paint it first. I'll install it toward the end of the build.
And lastly install the completed assembly onto the fuselage. Now I can finish the seam work on the top of the aircraft. Joy.
Cheers
Oh, there's a break-down of AM manufacturer's for this effort back on page 17 with pics.
