The Hornet's Nest GB 10/10-10/11
    September 2006
Posted by raptordriver on Sunday, February 20, 2011 7:46 PM
Hello everybody, here is what my plans are.
I have a whole extra set of Revell Mk. 83 bombs, so I plan to put eight on the Hornet. This is a F-18C, but I think they can still hold a ton!(More like 7) I also am going to put on two AIM-9 missles on the racks, and a drop tank if possible. My question is, is this overloading? These jets can carry a lot, so I don't think it is, but tell me if it is, because I want accurate!
I am only at this stage, but I think it will be fun. Sorry its blurry, but an iPod is my camera.
I was looking through my builds earlier today. I realize I appreciate the quality builds more. If you remember me building three years ago, I was building planes faster than Fermis. I realized today that quality beats quantity(Gee I am building like 1 in two months now). I am going to apply several weathering techniques to this build, so I think I should do good. I always do the weapons first, and then the build.
Andrew
    March 2008
Posted by FastasEF on Sunday, February 20, 2011 8:04 PM
I have a question for the Hornet's Nest. I have the 1/48 Revell Blue Angels F-18 Hornet and was wondering if it could be turned into a military used variant? Inside the box it has two different sets of cans and has bombs in there also.
If this is possible, which variant would it be? If this turns out to be possible, I will join up with you guys on this GB. Might be the first GB/ model I've finished in a quite a while, lol.
Thanks!
    June 2009
Posted by STFD637 on Sunday, February 20, 2011 8:14 PM
Fastas:
Knowing that it is a Revell kit it is probably the F-18A variant. Most of the Blue Angel kits out there are of the "A" model. There is no real difference from the planes the group flys than those of the fleet A/C. (Save the smoke ejectors). As long as it has wing pillons you should be able to creat a Combat "A" version.
The A and C models are a little more sleek looking than the "Beefed Up" super bugs. I can't see the Angels switching over.....but I could be wrong. Personally I was bumbed when they switched from A-4s.
Best of luck.
Travis
"If a lie is told often, and long enough, it becomes reality!"
Travis/STFD637
make an avatar
    March 2008
Posted by FastasEF on Sunday, February 20, 2011 10:18 PM
Thank you for the info STFD!
I have two sets of decals on the way now so could I get added to the list? Progress pics to start showing up soon.
    September 2003
Posted by Daywalker on Sunday, February 20, 2011 11:18 PM
Scott- I am very eager to see that HobbyBoss kit, how do you like it so far?
Andrew- Not sure if this helps, but here is a page with typical Desert Storm loadouts on F/A-18A/C/D Hornets:
Desert Storm Hornet loadouts
HTH!
FantasEF- By all means, Welcome Sign to the GB!  I added your name and kit to page one, and I listed it as a "C"- hope that's OK! Yes
Frank
    September 2006
Posted by raptordriver on Monday, February 21, 2011 12:16 AM
Hey Frank! Thanks man you rock! I have found this:
WingFuselageBellyFuselageWing
Wingtip Outboard Inboard       Inboard Outboard Wingtip
AIM-9M Mk.83 LDGP Mk.83 LDGP AIM-7F/M Fuel tank AIM-7F/M Mk.83 LDGP Mk.83 LDGP AIM-9M
That looks like the answer I was looking for. 8 Mk. 83s that is a lot, but the hornet is beastly. I seriously don't know why the majority of modellers like WWII planes better. Modern Jets rule!
My question is though, where do the AIM-7F missles go? I don't know where the fusalage pylons are.
Again thanks Frank!
H
Andrew
    March 2008
Posted by FastasEF on Monday, February 21, 2011 12:17 AM
Thanks DayWalker! I think it is an "A" model though.
I ordered 2 sets of different A+ decals for it, as the only difference between the two is the Hughes AN/APG-65 in the "A" model and the Raytheon AN/APG-73 in the "A+" model, which are both in the nose and thus not visible.
I cut both fuselage halves off their sprues and started filing and fitting them to each other. Outside of that I've only just perused through the instructions. I'll probably start painting interior pieces tomorrow but won't do any major gluing until my Tamiya Super Thin gets here (happy dance).
    March 2010
Posted by Julez72 on Monday, February 21, 2011 9:35 AM
Good to see some Hornets being builtStick out tongueI'll be starting mine at the end of this month...That should be enough time to finish itYes
    February 2004
Posted by arki30 on Monday, February 21, 2011 9:43 PM
Daywalker
 arki30:
Filling and sanding....
Sanding and filling....
=my least favorite part of a build.  How bad is it on your kit?
Good fit, but typical Hasegawa over-engineering.  A lot of sub-assemblies that create more seams.  It's just tedious and my least favorite part of a build.  The good news is I've taken that as far as I can and will be putting primer down soon to see what I missed.  Progress pics coming by the end of the week.
Deadmau5. Yes
Building Now:
1/48 Academy Bf-109G6 - 100%
1/48 Tamiya F4U-1A - 5%
Upcoming:
1/48 Revell F-14D
    February 2004
Posted by arki30 on Monday, February 21, 2011 9:56 PM
FastasEF
Thanks!
The Blue Angels fly F/A-18A and B variants.  Wikipedia has a little blurb here.  I swear I've seen a post somewhere on a forum that detailed the "changes" the Angels aircraft have over the full military version, but darned if I can remember where.  I know the gun is removed. Big Smile
Building Now:
Upcoming:
1/48 Revell F-14D
    February 2004
Posted by arki30 on Monday, February 21, 2011 10:11 PM
raptordriver
Again thanks Frank!
H
Ah, no not quite, Andrew. Indifferent  That's a single Mk. 83 bomb on four stations, so only four Mk. 83's total in this loadout.  MER's aren't cleared for Mk. 83's on a Legacy Hornet so that's out.  I wonder if a TER could be used however?  Not sure on that, I'll dig around and see what I come up with.
Here's a link to MAW decals Hornet info.  Great site, click the ordnance button to see a nice diagram of the stations.  The AIM-7's would go on stations 4 & 6.  Ordnance loadouts here are all USMC, fyi.
Edit:  Speaking of USMC loadouts, there are several schemes which have 2 Mk. 83's on a station.  They must be using TER's then.
Building Now:
Upcoming:
1/48 Revell F-14D
    September 2003
Posted by Daywalker on Monday, February 21, 2011 10:22 PM
Thanks for the info, good to know the Hasegawa kit is typical Hasegawa.  Decent fit but a fair bit of smoothing to get them to look nice.  Thanks for the head's up!  Good catch on the loadout, thanks for the advice on MAW's site.  I forgot about that one!
arki30
Deadmau5. Yes
That guy ROCKS! Bow Down
Frank
    February 2004
Posted by arki30 on Monday, February 21, 2011 10:42 PM
Glad to help.
Andrew, you could tackle this loadout from Franks link.  That's six Mk. 83's, plus the Sidewinders, and the fuel tank you wanted.  If you don't have the AAR-50 sensor, I might have an extra.  I think.
Just a thought.
AIM-9M Mk.83 LDGP VER AIM-7F/M Fuel tank AAR-50 TINS VER Mk.83 LDGP AIM-9M
    Mk.83 LDGP Mk.83 LDGP       Mk.83 LDGP Mk.83 LDGP
Building Now:
Upcoming:
1/48 Revell F-14D
    September 2006
Posted by raptordriver on Monday, February 21, 2011 10:57 PM
Lol I knew it was too good to be true! Thanks man! I am obviously a green jet modeler, but that loadout looks suitable. Does anyone know where I can get pylons for the outboard wing single Mk.83? What do they even look like? More research I guess. What is a MER? What is a TER? Much for me to learn master   masters!
Andrew
    September 2003
Posted by Daywalker on Monday, February 21, 2011 11:07 PM
LOL, isn't that one of the best parts of modeling?  Learning new things along the way, best part IMHO.
The MER is a Multiple Ejector Rack
The TER is a Triple Ejector Rack
Frank
    March 2008
Posted by FastasEF on Wednesday, February 23, 2011 1:20 AM
I got the pit all painted and finished up tonight. Gonna try and finish the pilot tomorrow morning and then move on to the tedious fuselage halves fitting tomorrow night. One of my least favorite, and most favorite parts of the build, lol.
I will try and get photos up tomorrow too.
    March 2010
Posted by macattack80 on Wednesday, February 23, 2011 5:23 PM
Things are moving forward on my 2 SuperBugs.  I got the forward and main fuselage sections together.  The fit is pretty bad though.  Lots of putty and sanding will be in order.
The decals for the cockpit were not good.  One decal decided to break up and I was able to save about 2/3's of it.  Angry I little black paint to replace the lost decal should make it look ok.  I guess I know which plane will have the closed canopy....
The panel lines are so fine and well done I hate to sand them away.  I tried to rescribe the ones that have already been lost but the look too heavy handed when compared to the surrounding detail.
I was able to borrow a camera so I will have to post some pics tonight.   Keep up the good work everyone!
Kevin
    March 2010
Posted by macattack80 on Thursday, February 24, 2011 3:41 PM
Here are a few progress pics
The wing sections
[View:/themes/fsm/utility/:550:0]
I tried to get a close up of the cockpit with no avail
The belly
I only took pics of one of the models but I am doing 2 both of which are at the same point in the build.
I will throw some putty on a few spots and smooth out some areas tonight.
Kevin
    January 2011
Posted by Christian Theodotou on Thursday, February 24, 2011 3:55 PM
I just noticed this group build and as I am currently working on a 1/48 Hasegawa Super Hornet I was wondering, is it still possible to get in on the group build?
    March 2008
Posted by FastasEF on Thursday, February 24, 2011 9:32 PM
Hey guys, I think I have decided to do up the plane in this scheme:
https://www.aviationillustration.com/shop/images/f_a-18c.54.jpg
I have two sets of decals coming and this one seemed more interesting and colorful. Question though, what color(s) were their flight suits? The plane is from VFA-201 `Hunters' which started flying the F/A-18 in 1999 and was deactivated in 2007.
The flight suit schemes I've seen are tan, tan camouflage and the typical green. Any info or even photos would be appreciated, thanks!
    March 2008
Posted by FastasEF on Thursday, February 24, 2011 9:46 PM
Oh, and here are some crappy cell phone pics of the progress:
    March 2010
Posted by macattack80 on Thursday, February 24, 2011 9:56 PM
That red really pops on the gray.  Looks sweet!  Nice choice.
Kevin
    March 2010
Posted by macattack80 on Thursday, February 24, 2011 10:01 PM
FastasEF, awesome job on the cockpit!  Nice detailing!  BTW, for a cell phone camera those are pretty good photos.
Kevin
    March 2010
Posted by macattack80 on Thursday, February 24, 2011 10:09 PM
I found this pic of a pilot from VFA-201 flying.  Looks like a green flight suit.
http://www.pbase.com/keith1959/image/58024866
Kevin
    September 2003
Posted by Daywalker on Thursday, February 24, 2011 10:42 PM
Christian- Welcome Sign to the GB!  I added your name to the roster on page one.  Which version of the Super Hornet are you building?
Great looking work guys, I really gotta get my behind in gear!
Frank
    March 2008
Posted by FastasEF on Thursday, February 24, 2011 10:47 PM
That's a great website! Thanks for the photo mac!
    January 2011
Posted by Christian Theodotou on Friday, February 25, 2011 8:29 PM
F-18F, I'm doing one from  the VFA-41 Black Aces
    March 2010
Posted by Julez72 on Friday, February 25, 2011 10:41 PM
Daywalker
You and me both Frank... i'm quietly confident i'll finish on time thoughYes
    March 2008
Posted by FastasEF on Saturday, February 26, 2011 12:08 AM
Alright guys, I got the pilot done and also have the fuselage halves mated up along with the intakes.
Question, what all should I attach before the overall gray? I know that the vertical and horizontal stabilizers should be on, but what about the landing gear covers and the center line fuel tank? Or the wing pylons?
And would you guys paint the gear bays before or after the overall paint scheme?
Thanks!
    March 2010
Posted by Julez72 on Saturday, February 26, 2011 3:07 AM
Fastas, if it were me i'd attach all the pylons before painting but leave off the disposable stores until the final coat of flat clear, that way they're not in the way during decals, washes ect.... I personally would paint the gear bays first and mask them off with blutac, the Hornet i'm doing has red on the edges of the gear bay doors so that makes 3 colors on each gear bay door so i'll be doing mine seperatly and again attaching before it's final coat...
