The Hornet's Nest GB 10/10-10/11
    July 2003
Posted by sidure on Thursday, December 2, 2010 3:33 PM
Here are my latest developments on my 18-E from Revell. Got the top and bottom coats on and the first pic shows the fins just dry fitted. I was a little heavy handed on the bottom and the pre shading was a little heavy but the top looks spot on.
then came the masking for the squadron specific colours
an hour of masking for 5 minutes of painting but it was worth it. I applied at least 4 coats of glosscoat and it still never got as glossy as I wanted so I went on. Next will be some decals and a panell wash. Not too heavy as this is a CAG bird and presumed it would be cleaner than most.
Hope to get working on the decals soon. I also bought the Hasegawa weapons set and I am going to load this F-18 to the teeth and I dont care if its correct or not as there are so many different combination that can be carried acording to the loadout chart that came with it. I figure if Im going to pay for a weapons set by golly im gona use them, hehehehe
Steve
    September 2003
Posted by Daywalker on Thursday, December 2, 2010 6:48 PM
Great stuff Steve, thanks for the update!
I think you are right- those CAG birds are usually VERY clean!  A little dirt around the engine area and the gear bays and that should do it.
Frank
    March 2010
Posted by Julez72 on Friday, December 3, 2010 3:25 AM
Very cool Steve, nicely doneYes
    June 2009
Posted by STFD637 on Friday, December 3, 2010 9:39 PM
After looking at sidure's Super Bug pics I now know why I couldn't order my clamps from Micro Mark!Crying.
Looks great.....super masking job too!
Travis
"If a lie is told often, and long enough, it becomes reality!"
Travis/STFD637
make an avatar
    February 2004
Posted by arki30 on Monday, December 6, 2010 11:19 AM
Nice masking job Steve. Yes
I've officially started!  Albeit only washing the sprues.
Building Now:
1/48 Academy Bf-109G6 - 100%
1/48 Tamiya F4U-1A - 5%
Upcoming:
1/48 Revell F-14D
    July 2003
Posted by sidure on Thursday, December 9, 2010 1:20 AM
Thanks for the comments guys its appreciated. I have had little bench time but have managed to get some of the decals on. The main squadron stuff is on but the tons of stencils are still to go and that might drive me crazy. I may skip some here and there as a lot of them will blend with the paint job anyway. Sorry for using up all the clamps but I needed every one of them and I swear if you sneeze on the nose section it will fly off, its under a lot of tension to get it to fit right. Hope to have some progress pics after the weekend
Steve
    September 2007
Posted by firesmacker on Thursday, December 9, 2010 2:13 PM
Looks good, Steve. Real sharp masking job. I have quite a bit done and will post some pics tonight or tomorrow.
Regards,
Jeff
    September 2007
Posted by firesmacker on Thursday, December 9, 2010 4:05 PM
All the major work is done. Ordnance is finished and all the gear bay doors are drying. I should have this one wrapped up in the next week or so.
The landing gear consisted of a whopping 78 parts including tires but not including any of the doors or support struts.
Thanks for looking. As always, any comments or suggestions are welcome.
Regards,
Jeff
    September 2003
Posted by Daywalker on Friday, December 10, 2010 9:53 AM
The more I see that jet Jeff, the more I like it!  Great work so far, and glad that the decals worked for you. Yes
Frank
    February 2004
Posted by arki30 on Tuesday, December 14, 2010 11:48 PM
As noted, all the sprues have been washed and I've sorted through the aftermarket to determine what exactly I'll be using.  First up, the obligatory sprue shots.
This particular kit must have been a special edition or something as it came with some bonus "detailing" parts.  Contained within a separate Hasegawa box inside, I assumed some PE for seats or such and never bothered to look.  Imagine my surprise when I discovered not only some standard Dragon USA PE for seat, canopy and cockpit but also some white metal landing gear!  Nice!
Royale Resin wheels, slightly blurry picture, very clear and detailed resin casting.
Aires resin cockpit.  Nothing appears broken or missing which is a nice change of pace for an Aires set.  I'll be using everything in this set except for the seat.  This is a late model F/A-18C and the seat is an early version.  I'll put it in the spares section for another Hornet.
As mentioned, the particular markings I'll be doing from TwoBobs are for a late-model F/A-18C, whilst the kit is an early C-model.  Wolfpak to the rescue.  Set provides late model antenna, updated weapon pylons, and late model SJU-17 NACES bang seat, and an entire replacement nose section with the 5 IFF "bird-slicer" antenna.  Frankly the IFF antenna could be scratched, but this saves me the headache and provides an easy way to display the refueling probe extended.  Hopefully there won't be any resin shrinkage at that nose section.  We'll see.
Last but not least, I have a set of Eduard placards for the Hornet.
As far as a weapons loadout, I have no idea.  I'll figure that out later.
I'll be starting on the cockpit first, naturally.  Progress pics to come.
Cheers
Building Now:
Upcoming:
1/48 Revell F-14D
    July 2003
Posted by sidure on Tuesday, December 21, 2010 3:45 PM
Nice looking sprues Arkii, so when do we see some construction on the beast.
I have been plugging away on my kit and should have posted some more pics but its almost done and hope to have it finished by Christmas. A few minutes ago I just had a disaster when I dropped a blob of glue on the black spine area of the fuselage and I want to cry now. I dont know if I can match the sheen of it. The aircraft has its decals and gloss and dull coats applied so I am a bit upset right now. Oh well I will do some touchups tonight and hope its close. Here are the latest progress. All work on the fuselage is done and im working on matching the Hasegawa weapons to the Revell pylons right now and of course they dont match. So I am supergluing metal pins in the bombs and attaching them that way. I have no idea if the loadout is correct but I am arming this thing to the teeth, if I have to pay extra for weapons im going to use them.
and here is a pic of the tails, I just had to go with the Christmas option in the spirit of the season plus they are very cool I think. Hope to have this one done by Christmas day if the weapons co-operate
Thanks for looking and any comments welcome
Steve
    September 2003
Posted by Daywalker on Tuesday, December 21, 2010 8:01 PM
Awesome looking Hornet Steve, love the season-appropriate markings too!  I have Jolly Rogers Santa markings somewhere, may have to get those for Christmas NEXT year (I'm really slow...LOL)
Bummer about the glue blob, been there-done that!  Hope you get it sorted out without too much difficulty.
Frank
    February 2004
Posted by arki30 on Tuesday, December 21, 2010 11:01 PM
Liking the X-mas Felix Steve. Yes  Progress is halted on my end for the holidays.
Cheers
Building Now:
Upcoming:
1/48 Revell F-14D
    July 2003
Posted by sidure on Tuesday, December 21, 2010 11:17 PM
Thanks Frank, I am going to do some touch up paint on Fri and see how it matches. I got the bombs sorted out tonight. I made some pins from stretched sprue and drilled corrisponding holes and took care of them like that. All I have to do to finish is some touch up details here and there.
You have Christmas Jolly Rogers decals, bet they are cool. I just bought Jolly Rogers decals for my F-14 that I am just about to start
Steve
    July 2003
Posted by sidure on Tuesday, December 21, 2010 11:19 PM
Know what you mean Arki, thats why im rushing to finish this one by friday. Look forward to when you get it started
Steve
    July 2003
Posted by sidure on Friday, December 24, 2010 4:18 PM
Well Im calling this one done and just in time for the big day. I took a few quick shots for now but will do some better ones in a few days plus with the details. So heres a few pics
Thanks for looking everyone and I want to wish everyone a Merry Christmas and happy modelling next year.
Steve
    March 2010
Posted by macattack80 on Sunday, December 26, 2010 1:29 PM
Great build sidure.  I like the paintjob and decal selection.
Kevin
    March 2010
Posted by macattack80 on Sunday, December 26, 2010 1:33 PM
firesmacker, your big ol' bug is coming along nicely.  She is lookin good.  Nice job with the nose decals. Yes
Kevin
    September 2007
Posted by firesmacker on Sunday, December 26, 2010 9:36 PM
Steve, that thing looks really, really nice. Whatever glue blob you were talking about is nowhere to be seen on my end.Yes
Regards,
Jeff
    September 2003
Posted by Daywalker on Monday, December 27, 2010 12:55 PM
Agreed!  That is a stunning example of the Hornet, well done!  I am envious of you, what I wouldn't give to have one that nice in my display case. Bow Down
I updated page one for you!
Frank
    July 2003
Posted by sidure on Monday, December 27, 2010 1:52 PM
Thanks for all the comments guy's its much appreciated. Of all the decal options I looked at this one caught my eye the most from Afterburner decals. The glue blob was just to the left of the blade antenna on the spine but it cant be seen to clearly in these pics. I painted the spine with semigloss Tamiya and the brush paint touchups are a bit too flat. I will be posting better pics soon and it may be more visable in those.
Steve
    September 2007
Posted by firesmacker on Monday, December 27, 2010 5:33 PM
This one is getting really close. All I have left is attaching a few bits, a final flat coat and then the clear parts. Oh yeah, and some Tamiya clear here and there.
Regards,
Jeff
    September 2006
Posted by raptordriver on Monday, December 27, 2010 6:30 PM
Way to go Steve! I like it!
Jeff! Nice work on the nose decal I like that too.
Andrew
    September 2007
Posted by firesmacker on Monday, December 27, 2010 6:52 PM
Thanks, Andrew. It's been a mostly fun and pain free build. Having said that, I can't wait to get this big sucker off my bench and move on.
    September 2003
Posted by Daywalker on Monday, December 27, 2010 6:57 PM
Great stuff Jeff, that thing is armed to the teeth!  Exactly how a Hornet SHOULD look.
Frank
    September 2007
Posted by firesmacker on Monday, December 27, 2010 7:22 PM
Thanks, Frank and I agree, that kit come with like 5 sprues of ordnance and whatnot. I don't care if it is a CAG bird, I ain't letting it all go unused.
Regards,
Jeff
    February 2004
Posted by arki30 on Monday, December 27, 2010 10:57 PM
Steve, great finish.  I've always liked the Felix markings and the loadout looks serious, although likely hypothetical! Big Smile   Nice job!
Jeff, great progress and another good choice for markings.
Building Now:
Upcoming:
1/48 Revell F-14D
    July 2003
Posted by sidure on Tuesday, December 28, 2010 12:06 AM
Thanks a lot guys
Jeff, that hornet is wonderful and hope to find those decals one day for another hornet build, they have to be one of the most striking schemes Ive seen. Also like the look of the loadout, if you got weapons use em I say. My Revell only came with sidewinders so I bought a Hasegawa set and figured if im going to shell out extra for weapons Im going to load it to the teeth. Great build and cant wait to see it with its canopy on
Steve
    September 2007
Posted by firesmacker on Wednesday, December 29, 2010 5:16 PM
I'm going ahead and calling this one done. Can't really think of anything else to do to her:
This was a really fun build but I'm glad to put it behind me. This is the biggest kit I have ever attempted.. Keep up all the good work guys. Even though I am done, I am still part of this GB and will be popping in to check it out.
Regards,
Jeff
    September 2003
Posted by Daywalker on Wednesday, December 29, 2010 9:44 PM
Dang Jeff, that really came out NICE!  What an enormous beast, can't believe you finished it already!  I really need to get cracking on mine. Embarrassed
Page 1 updated! Yes
Frank
