Hunting After Dark, 2011-2012 Night Fighter Group Build
    January 2003
Posted by p38jl on Monday, June 13, 2011 6:23 PM
Very Sweet Owl !Yes
[Photobucket]
    January 2010
Posted by CallSignOWL on Monday, June 13, 2011 8:26 PM
thanks everybody! It was a sweet little kit and very enjoyable to build. IF you ever need a de-stresser kit, this would be a nice one to get! Toast
Manny, are you gonna enter a build or are you lurking? Come to think of it, I'm not sure if I ever saw one of your builds yet. I must not be looking in the right places....
OWL
Now that I'm here, where am I??
    August 2009
Posted by TREYZX10R on Monday, June 13, 2011 8:30 PM
Owl somewhere in the begining of the thread Manny posted some choice build pics and again very nicely done build!
    January 2010
Posted by CallSignOWL on Monday, June 13, 2011 8:51 PM
found 'em TREY, how could I have missed those? LOL
    October 2009
Posted by Gregbbear on Monday, June 13, 2011 9:30 PM
Hello, after spraying on my flat coat, most of my weathering seem to disappear.  So, I tried some oil paint washes, a little bit of dot filtering.  It was my first time, and it went okay.  I repaired the rickety main gear (again), this time using epoxy.  I started putting stuff together, and I realized I forgot to paint the inside of the gear doors.  100 degrees today, so it didn't get done.  Almost there though....  Here are a few pics.  Forgive my photography, please.
Cheers,
Greg
- yat yas!
    April 2010
Posted by Ripcord on Monday, June 13, 2011 9:37 PM
100 F degrees! Nice...Add 15 more for me and it would be perfect.  100 is a little chilly for me.  Only 97 today. Long sleeves for me.  Good job on the model.  Does your airbrush paint dry as soon as the trigger is pulled?  I usually end up with a powder coat.
    October 2010
Posted by Casper the Chihuahua on Monday, June 13, 2011 9:41 PM
Thanks for everyone's kind words! Wink
Cheers
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    September 2003
Posted by Helo H-34 on Tuesday, June 14, 2011 1:43 AM
Your P-70 is looking quite good Greg Yes
I'm yet to try any real type of weathering and washes on my aircraft builds , all my stuff looks way too clean most of the time !
Casper's Sea Venom is awesome , especially the cockpit seats .
Well done Sir Toast
I have managed to get the tan (Gunze H-310) layed down on my B-57G ;
I'll mask tonight for the two greens , H-303 and then the H-309
                              John .
    January 2003
Posted by p38jl on Tuesday, June 14, 2011 7:44 AM
Caspar.. nice jet dude !Toast
[Photobucket]
    March 2010
Posted by Hercmech on Tuesday, June 14, 2011 8:12 AM
Greg,
Glad to see your build progressing so nice. It does suck to get to a certain stage and realize you left something undone.  Anxious to see it completed.
13151015
Posted by Gamera on Tuesday, June 14, 2011 3:01 PM
Great job on the 262 Owl! Sharp work on the crazy camo esp!
Greg and Helo: Nice work guys, look like you're coming right along.
    August 2009
Posted by TREYZX10R on Tuesday, June 14, 2011 3:09 PM
John  Greg great work guys!
    October 2009
Posted by Gregbbear on Tuesday, June 14, 2011 5:14 PM
Thanks guys, I appreciate it!
John, B-57 is looking good.  Thanks to you, Canberras are singing to me!  I'm not sure when I'll get to it, but I won an Airfix Mk20 in 72nd scale.  I want it to be an RAAF in Vietnam night intruder when I get to it.
Ripcord, yes 100 degrees is a brisk day in AZ!  But it is the DRY heat, lol.  My wife is from Phoenix, and all she ever does is complain about the humidity.  She says Texas should be the bad hair state, not the lone star state.  If I try and paint on a day like that, all I get is grit too.  I still have to spray a lot closer than I do during the rest of the year.  How's it with the dust out there?
Cheers,
Greg
- yat yas!
    September 2003
Posted by Helo H-34 on Tuesday, June 14, 2011 6:32 PM
Gregbbear
Cheers,
Greg
Thanks Greg and congrats on the ebay score of the Airfix RAAF Mk20 Canberra Yes
I think I read somewhere that the Airfix kit has those wing tip bomb pylons/bracket included , if that is the case , when you get yours would it possible to post a pic of one , as I need to scratch a couple up for my High Planes Mk20 Canberra .
Speaking of Night Intruder Canberra's , we've had a bit of wet weather here in Sydney these past couple of days , quite the opposite to the sunny days in Texas , so airbrushing paints has been put on hold for the time being . So in the mean time I still would like to add some more B-57 Canberra's to your GB and I mentioned before about a "Candle" trio of a C-123K Provider Flare Ship , a B-57B (Hells Angel) and the O-2A Skymaster FAC .
I searched around the net for some images of the Flare Ship and found these two C-123K pic's ...
Because of the wet weather and no airbrushing I decided to jump ahead a little and do some prelim' work on Mach 2's C-123 ...
I have built two of these kits before (however their yet to be painted) and there is quite a lot of work involved in getting the parts cleaned up and ready for glueing .
On the inside of nearly every piece are these big lugs that stick up and need to be ground down with a motor tool ...
Because there is so much Grinding , sawing and filing ; I set up the bench in the garage so as not to cover my work area inside with plastic dust ;
There are a few major issue's with the kit and having some previous experiance in putting them together , I was able to do a fair bit of the heavy filing early on ;
The wheel well opening for the main landing gear and wheels is too small and I needed to saw and file about 3mm more to get the wheel to fit ;
This also means I will need to extend the sides of the wheel boxing that fits inside each fuselage half and I'll do that later on .
There is also quite a bit of heavy filing on both fuselage pieces in the middle (top and Bottom) so the nose and the tail can close up a bit better ;
Also the slots for the rear horizontol stabilizers are heavilly  flashed over and the moter tool is required to clean out the slots ;
That's about it so far , as well as modifying the main gear boxing next , there is some additional work on the cockpit floor and bulkhead to get them to fit correctly .
I hope the Flare Ship fits in with the theme of the Night Fighter GB , seeing that the C-123K is the most difficult to build out of the Three aircraft 'candle Trio' I just thought I would make a start on her first , the B-57B Night Intruder goes together easily and the O-2 looks straight forward as well .
Fine weather predicted for tomorrow , so it will be to airbrushing the B-57G .
                              John .
    October 2009
Posted by Gregbbear on Tuesday, June 14, 2011 7:11 PM
Hi John, good info to know about the Mach 2 C-123.  From my understanding, you can build the gunship version too.  I am very tempted to pick one up, and at least I know what I'm in for if I do.  As for the Canberra pieces, when I get it in, I will take pictures and send them to you.
http://www.fortunecity.com/meltingpot/portland/971/Reviews/50s/canberra-m.htm
I am not sure if you have seen this review/build of the Airfix Mk 20.  If not, this is pretty interesting.
Cheers,
Greg
- yat yas!
    October 2009
Posted by Gregbbear on Tuesday, June 14, 2011 7:35 PM
Cheers,
Greg
- yat yas!
    September 2003
Posted by Helo H-34 on Tuesday, June 14, 2011 10:14 PM
Thank's for the link Greg ;
The pic's of the RAAF Canberra are great too .
Did you notice the nose glazing on the Mk20 in that the bomb sight is off center towards the left .
An important thing to remember when glueing the clear nose piece onto your model , I made a written note on my instructions sheet so I wouldn't forget when I build mine Confused
                                   John .
    June 2009
Posted by STFD637 on Thursday, June 16, 2011 11:18 AM
Finally reaching the completion of this kit!! This was probably one of the most problem laden builds I have had in a while. Just when I got ready to shoot I started haveing Airbrush issues. Censored I still have some weathering to do but the big stuff is all done. Here are some shots. Hopefully I can get some work done on it today.
[View:/themes/fsm/utility/Photobucket:550:0]
Working on some new and hopefull better quality pics.
"If a lie is told often, and long enough, it becomes reality!"
Travis/STFD637
make an avatar
    March 2010
Posted by Hercmech on Thursday, June 16, 2011 12:16 PM
Great looking build Travis!
13151015
    October 2009
Posted by Gregbbear on Thursday, June 16, 2011 5:44 PM
Looks good Travis!  You did the squiggles freehand?  And on 1/72?  There are some good painters in this GB!
On another note, what does STFD637 mean, if you don't mind me asking?  I am curious because of the FD part.  As in Fire Department?
Cheers,
Greg
- yat yas!
    June 2009
Posted by STFD637 on Thursday, June 16, 2011 7:50 PM
Greg: Yes the squiggles were done by freehand. I ended up painting and wiping about 4 times due to some airbrush/paint thinning/human issuesSuper Angry. I would have loved to have had a .2mm tip available on a high end airbrush, but not yet. I used my Aztec.
STFD637 stands for South Trail Fire District (where I work full time) and the 637 is my employee number. Just a simple handle to come up with. We are located in SW Florida.
I finished up the 110 tonight!!!!!Toast I haven't built a WWII aircraft in a while. I ended up doing some weathering experimentation on this one. It is hard to tell in the pics and hopefully I can get  some better pics later. I am working with a cheap dig cam and my iphone.......the iphone camera won in this battle. What I found interesting was the "Blue Hue" in some of the pics. The colors were Tamiya Sky Grey and RLM 74.
[View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0]
The antenna wire was 6lb fishing line. It looks about right. I tried to stretch some sprue but it kept breaking before I got it to the correct size or it wouldn't be long enough. This was a trying, but fun kit!
Travis/STFD637
make an avatar
    August 2009
Posted by TREYZX10R on Thursday, June 16, 2011 8:25 PM
Travis great looking build and great freehand work with the a/b! I use small guitar string for my antenae seems to work okay
    February 2010
Posted by Stage_Left on Thursday, June 16, 2011 9:23 PM
Travis,
Nice looking Bf-110! I picked up this kit a couple months ago, and out of the box it looks decent enough. You really made the detail pop. Thanks for the heads up about the seams and lack of landing light.
    October 2009
Posted by Gregbbear on Thursday, June 16, 2011 9:46 PM
Travis, good looking 110!  You are on page one.
South Trail, is that a woodland district?  I am a firefighter for San Antonio myself.  I wish I was a Florida firefighter though!  I grew up in Clearwater, and I sure miss it.
Cheers,
Greg
- yat yas!
    June 2009
Posted by STFD637 on Friday, June 17, 2011 6:40 AM
Thanks guys. Yeah I fish a lot so there is always fishing line of different diameters and strength.
Stage Left:  The landing light was a big bummer. I have several Italeri kits in the stash and it seems to me it is just a matter of which mold they copy (i.e. Tamiya. Zvezda, Testors) on how the kit looks. Some have nice recessed lines and others have raised. Another thing I found was the decal sheet is missing a decal for the "rescue" hatches on the fusilage sides behind the cockpit. Instead they gave me an extra set of tank markings in the area where the other marking should have been.
Greg: No we are a Metro area with some wildland/urban interface issues (especially lately). I spent 4 hours of my last shift driving up and down I-75 with 5 other engines running between a brush fire in North Port and a Possible tornado in Naples. We are in between Naples and Tampa.....just past that imaginary line where it goes from hot (Tampa/Sarasota area) to Damn HOT!!!! (here). Greatest job in the world. I moved from California to here about 7 years ago.
Thanks again. Very nice GB!!
Travis/STFD637
make an avatar
Posted by Gamera on Friday, June 17, 2011 11:18 AM
Wow, great job STFD637! Love those crazy Luftwaffe camo schemes! And I think it's amazing what you guys do with those complex radar ariels on the nose, I'd have broken them off multiple times till they ended up eaten by the carpet monster.
    August 2009
Posted by TREYZX10R on Friday, June 24, 2011 3:36 PM
Hey Greg get that Ace badge ready ! I'm pulling way out of my comfort zone with the next one a Do217N2 Koster conversion of the Revell D0217E-4.
the kit lay out
and the Koster bits
with any luck this will be the end result
heres the real one
    March 2010
Posted by Hercmech on Friday, June 24, 2011 3:50 PM
Trey,
You are putting us mere mortals to shame. Embarrassed
Looks like it will build into a nice looking kit.
13151015
    October 2009
Posted by Gregbbear on Friday, June 24, 2011 4:36 PM
Hello all, I am pretty much finished with my P-70.  One of the pitfalls of dragging out a build as long as I do, is that I end up losing stuff.  I lost one of the radar aerials, and mv lenses for the landing lights.  The lenses are easily replaced at my LHS, but I will have to order the aerials from either Owl or Hannants.  I apologize for the dark photos.  I get them either too bright or too dark.  Well anyways, here it is.
Cheers,
Greg
- yat yas!
    March 2010
Posted by Hercmech on Friday, June 24, 2011 5:01 PM
Nice job on the weathering Greg. I am working on a Tiger Meet A7 that is black and it is a pain in the butt to weather so my hats off to you.
13151015
