Falklands/Malvinas War 30th Anniversary GB
Posted by Bish on Thursday, June 30, 2011 5:54 AM
I must admit i like the look of the pucara. Its not my usual subject to build, but i might just be tempted to get one.
From the Special Hobby kits i have, i don't think they re-box anyones kits. They certanly ain't for the novice. Some if not all the ones i have don't have locating tabs, at least on the wings. They would put them down as more of a limited run company rather than a mass production.
    December 2009
Posted by Azorean on Thursday, June 30, 2011 5:55 AM
bsyamato
Is the airfix pucara better than the special hobby kit? (or is the same reboxed?)
Is the same. The Special Hobby brings PE and some resin parts.
Posted by Bish on Thursday, June 30, 2011 6:13 AM
Ok,i stand corrected. Though to be honest, most of the SH kits i have haven't been done by any body else that i am aware of.
Posted by VanceCrozier on Thursday, June 30, 2011 7:09 AM
Hey gang, finally followed my trail of bread crumbs back to the GB thread! Bust busy busy with work & "summer stuff". I think I may get some time on the Sea Harrier this weekend... (I took a few vacation days next week to turn it into an extra-long weekend!)
bsyamato - loving that SUE (which is my wife's name, by the way!) Ditto to Azorean's comment - the Airfix kit is almost the same, only missing the PE and resin pieces. I need to order some decals for mine before too much longer, I don't have anything in the "spares" that will look right.
azorean - sand & prime, sand & prime!!! Hey, you're getting there, it will be worth the extra prep time when you see that final coat of paint lay down nice & smooth!
bondoman - thanks (again) for the heads-up about the canopy-fuselage step. I need to go back through the posts, but I seem to recall an issue with the fuselage being rather narrow for the cockpit assembly… maybe shaving a little off the sides of that section will help - is there much room once that assembly is in place & fuselage sealed up??
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    March 2007
Posted by bondoman on Thursday, June 30, 2011 10:05 AM
Azorean
 bsyamato:
I don't know since I don't have the Airfix kit. But if so, there'd be a lot of frustrated beginner modelers. It's the type that doesn't have numbers on the parts or the sprues, and the few locators provided get in the way of a good fit.
Vance, when I trial fit it all, narrowing the fusie did not seem an option. As it is, I had to bust  the back seat loose once it was all buttoned up, and move it, just to get the canopy down onto the thing. I think the best plan would be to open the canopy, as pretty much the whole thing except the bug screen swings up. That will involve cutting it in two and scratching up a little bit of frame and struts. But as I type this, I am forming a plan!
Posted by Bish on Thursday, June 30, 2011 10:28 AM
Bondo, are their location tabs on the wings and slot for them to fit into.
    March 2007
Posted by bondoman on Thursday, June 30, 2011 8:04 PM
No. It's set up like the old Heller airliner models- there are five parts- middle bottom, left bottom outboard of the engine, right bottom outboard of the engine, upper left and upper right. It all fit together really poorly- wing roots bigger on one side, sticking out a little further, stuff like that. I did do what I like to do on this type- glue the tops of the wings to the fusie first, get the joint all clean, then offer up the bottom halves.
Posted by Bish on Friday, July 1, 2011 1:40 AM
That deffinatly doesn't sound like an Airfix kit does it. Interesting idea on attaching the wings.
    October 2008
Posted by bsyamato on Friday, July 1, 2011 12:55 PM
thanx for the replies .. if i could i'll get the airfix Hmm surely cheaper, the absence of details are not a problem
at least will get am seats.
bondoman
somethimes the model factories like to complicate life of modellers
VanceCrozier
Big Smile have you a syster called dassault  Vance ?
    March 2007
Posted by bondoman on Friday, July 1, 2011 4:42 PM
bsyamato
You'd be surprised, when I bought mine a couple of months ago there was only about a $ 5 difference. I just looked at an -n-box review, it is the same kit except that AF has an extra sprue of plastic in lieu of the resin stuff in the SH kit. And, I haven't tried them yet, but the SH decal sheet is a much better looking one.
Posted by Bish on Saturday, July 2, 2011 1:09 PM
Sometimes these kits can be a nice challenge. Its all to easy to stick to the kits that build themselves, but i find you can have alot of fun with a kit that takes a bit more work. And you get more satisfaction when you produce a good kit, and you learn a hell of alot you can put into other models.
I haven't built any SH kits yet, but i bought the first one now more than 2 years agon and have been buying them ever since. Got a nice little selection of them and some sunbjects no one else does, and can't wait to start building one.
    December 2009
Posted by Azorean on Sunday, July 3, 2011 1:03 PM
The white on the top is done. But first I had a big problem. The top began to crack along the union of the halves.Angry
I had to filling again and in the end the result is not good but I will not touch. Whistling
Posted by Bish on Sunday, July 3, 2011 1:18 PM
Do you mean the fuselage itself came apart.. not heard that happening before. But it is looking very nice. I can't see anything wrong on the first 4 photos, but on the list one i can see what looks like a line along the centre. You are certainly doing a great job despite the problems.
    January 2003
Posted by el_jere on Monday, July 4, 2011 9:34 AM
Azorean,
Sorry to read that you had some troubles with your build, but for the pictures it looks like you managed the problem just fine. I had the same problem once, I belive it happens when you sand putting a hard preseaure on the kit, I also have problems with the wings and tail.
Anyway your build looks great! D
Do you know wich scheme will you paint the model?
best regards
Jere
Res non verba
    December 2009
Posted by Azorean on Monday, July 4, 2011 3:34 PM
el_jere
That's exactly what happened, Jere.
I will make the T-82.
    March 2007
Posted by bondoman on Monday, July 4, 2011 7:48 PM
That happens- the fuselage/ hull halves split also when you drill a hole on the center line and try to expand it by twisting a #11 blade tip in it, I found out.
I'm looking forward to seeing the paint. Did the kit include all those nice looking flap actuators?
I just finished the third coat of future on Pucara- ready for decals. but wait, I took the instructions to work to blow them up for the camo pattern, and left them there! Tomorrow night I will put on the stickers.
    December 2009
Posted by Azorean on Wednesday, July 6, 2011 4:48 PM
bondoman
Yes.
    December 2009
Posted by Azorean on Friday, July 8, 2011 1:03 PM
The grey is on.
Now i´m masking to apply the black. And then mask again to paint the dayglo paint.
Posted by Bish on Friday, July 8, 2011 1:50 PM
Coming along very nicely, thats looking good.
    October 2008
Posted by bsyamato on Saturday, July 9, 2011 8:50 AM
Azorean ,good progress on the twin plane Yes
Bish you posted something about your b-17f? have the same kit but is sleep on the box
finally changed my spent darked ctr monitor with a new lcd monitor, and finally get more details from reference pictures i have.
Actually working only on the sue, but few time for modelling, i'm moving my work office to another location
Posted by Bish on Saturday, July 9, 2011 8:59 AM
I'm currently building it for the Mighty 8th GB that i am hosting. I put an update in there last weekend. I have also put it down for a couple of other GB's. Its been slow going, but things are picking up now.
    December 2009
Posted by Azorean on Saturday, July 9, 2011 2:57 PM
The masking is being a big task.
Time to take the masks off. Let´s pray...
Not bad...
Some little retouch I have to do but nothing to hard.
Posted by Bish on Sunday, July 10, 2011 5:06 AM
Nice job, thats comeing along really nicely.
    February 2011
Posted by bigua on Sunday, July 10, 2011 10:01 PM
Hello friends of the group, here I leave them the figures that Argentinian finishes of the tactical divers and of the royal marinade, I hope that they like.
 Regards
 Pablo
"Los soldados de la patria no conocen el lujo, sino la gloria."
General Don José de San Martin
    March 2007
Posted by bondoman on Sunday, July 10, 2011 10:15 PM
Muy bueno, Pablo.
Posted by Bish on Monday, July 11, 2011 5:42 AM
Some nice little figures there, i rather like them. And nice to have some figures in the build.
Think we might be getting another Pucara entered into the GB. lewbud, over on the Mighty 8th GB, saw one in his model shop and said he may well pick it up. Seems to be a popular build, but i can see why. Might well get one myself.
Posted by VanceCrozier on Thursday, July 14, 2011 9:45 AM
bondoman
Me again gang, sorry to be dropping in & out like this, but summer is far too short up here & I'm on a softball diamond any chance I get! I've been finishing up a couple of other kits as well so I can focus on my Falklands kits when the time comes.
bondoman, do you think adding some styrene strip inside that wing assembly would be any help for alignments, or just another layer of "something could go wrong"?
Posted by Bish on Thursday, July 14, 2011 1:37 PM
I know you have to make the most of the weather while you can vance, so no problem popping in when you are able. I have been haveing a few problems getting on myself. My connection is lousy when i am in camp, this is the first time i have been able to get on this week for more than 10 mins without loseing it. That should mean i get plenty of my builds done, but i spend half the evening trying to get online.
Posted by VanceCrozier on Thursday, July 14, 2011 2:08 PM
Bish - how's the hand feeling?
Posted by Bish on Thursday, July 14, 2011 2:12 PM
Not bad thanks. The caste has been off just over a week. I have on of those braces now that i can remove. Theres was still a small fracture, its going to take a while to heal fully and i have to be careful. But at least i can model properly now.
