Falklands/Malvinas War 30th Anniversary GB
Posted by Bish on Friday, March 9, 2012 6:09 AM
I was hopeing to have this done this week, but though i am close, theres still a little to do. So here another update. I am away for a couple of weeks on a course, so i should have this wrapped up soon after i get back.
I gave it a flat coat and then used Pro Modeller wash for some weathering. I had tried just to do the raised panel lines, but this didn't work out to well. So i used a cotton bud and covered large areas with it. Once it had dried i used a damp bud and removed most of the wash. I rather like the result. Slightly grimy with the panel lines standing out a little from the rest.
I added the terrain useing Celluclay and added the grass. I wanted the Chinook sunk into the soft soggy Falklands ground . So i cut off half of the wheels and then sunk the rest into the still damp Celluclay.
Once this was done, i replaced the antennas on the left side and started adding the windows. I still have to confirm which type of windows go where on the left side. The rotors are almost ready, so its really just thos ethings and the patchs to go on the front of the base.
So close and yet so far.
    October 2008
Posted by bsyamato on Friday, March 9, 2012 6:19 AM
Great sunk of a chinook YesYes
With flat coat really looking better Bish
Posted by VanceCrozier on Friday, March 9, 2012 7:12 AM
I like the look
of your Chinook!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by Bish on Friday, March 9, 2012 3:23 PM
Your a poet
and we didn't now it
Thanks vance.
    October 2010
Posted by Casper the Chihuahua on Friday, March 9, 2012 7:38 PM
Some work done on the front wheel
and the inside of the airbrake
Slow work but it's starting to come together
Cheers
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    October 2010
Posted by Casper the Chihuahua on Saturday, March 10, 2012 10:21 PM
First Sidewinder. This almost took 3 hours of work to assemble! I think I'll only do 2 of these are fit the external fuel tanks as well.
Cheers
Posted by VanceCrozier on Sunday, March 11, 2012 12:56 PM
wow Casper, look at all that brass! The rivet details look great!
Posted by Bish on Sunday, March 11, 2012 2:09 PM
Ye, with the price of metal at the moment, i would keep that Harrier safe, it will be worth a fortune. That's looking very nice indeed. I like the look of the undercarriage.
    November 2006
Posted by dupes on Sunday, March 11, 2012 4:08 PM
Bish - great looking Chinook!
Casper - man, that is a lot of PE. Nice work. Yes
The Scimitar is still in the works, once the spring contests are over here in the next few weeks, I'm going to chain myself to the bench until it is DONE. Don't even remember when I started that guy.
Posted by Bish on Sunday, March 11, 2012 4:54 PM
Thanks dupes. Its been a while since i have seen any of your work so i'm looking forward to it.
    January 2003
Posted by el_jere on Tuesday, March 13, 2012 4:19 PM
Bis, your Chinooks looks great! I like it, you are close to th finish lin my friend, one las effort and you will be done.
Casper: all the brass looks damm good, I like it too. It´s a big bird you hve there, so all the detail you can add worth the effort.
bst regards guys
Jere
Res non verba
    January 2003
Posted by el_jere on Tuesday, March 13, 2012 4:26 PM
I am close to finish my build too... this is how it looks today
Sorry for the quality of th pics, but I was in a hurry to take som pics before the sun sets completly.
The decals are a mix of home made (strips, numbers and th Fuerza aerea) and commercial (the flags and round ntionl markings) I don´t like the hue of the light blue, is too dark, but I had no choice but to use that decals.
Is not perfct, there are a few errors but since the spirit of this build is to tke it ligh the are no problems LOL.
maybe this week end will be finished, I still have to add some decals (I forgot to print a little id number on the nose) and add a few antennas.
well that is all for now, regards
Jere
Res non verba
Posted by Bish on Tuesday, March 13, 2012 5:23 PM
Thanks jere. And yours is looking sweet. I can't see any errors form here. Are you adding any legs to this or is it going to be wheels up.
    October 2008
Posted by bsyamato on Wednesday, March 14, 2012 5:11 AM
El Jere good finish friend Toast
    October 2010
Posted by Casper the Chihuahua on Friday, March 16, 2012 7:04 PM
So the stage that I have been putting off for as long as I can is the canopy. As nice as the Flight path set is, the instructions leave a lot to be desired!
The front canopy section has a raised section just where it meets the front of the fuselage. The Flight Path set contains nice sill details with riveting. It however does not mention how to apply the new sill to the clear plastic part.
So I had a think about this and there is a secondary brass part that fits on top of the front of the sill. I thought that this simulates the 'bulge' in this section so I decide to saw off the front part of the canopy.
A disaster! A poor sawing job, the blade kept bouncing and making a new cut and finally the glass snapped in a very conspicuous place.
Lucky there are 2 front canopy parts in this kit. The second part seems to be a bit messier in its molding but Future should help with that. So I carefully scribed the cut outline first and made very slowly but slightly firmer strokes. A much better result.
PHEWW!!! Huh? A botched canopy can ruin a model. A test fit with the brass sill confirms that this will work just fine.
Also got the first external fuel tank done. Note the brass sway braces, they really help with the detail.
Cheers
    December 2009
Posted by Azorean on Sunday, March 18, 2012 4:27 AM
Back to the SUE.
I did a kid of card board.
With the canopy closed.
Already with the white on.
    December 2009
Posted by Azorean on Sunday, March 18, 2012 4:34 AM
Nice Harrier, Vance.
 The Chinook looks great. Bish. Great work.
What a big work on a big kit, Casper. Keep the good pace.
Nice advances on the Harrier, Stikpusher.
I´m amazed with your Learjet, Jere. What a great look. I have on to to do some day.
    January 2003
Posted by el_jere on Tuesday, March 20, 2012 6:41 AM
Great looking bird Casper, so far so good!
The Sue is turning out great too Azorean, you are almost there.
Bish, the Lear will have wheels, I was working with those part yesterday, I will post a few pics maybe tomorrow.
best regards
Jere
Res non verba
    October 2008
Posted by bsyamato on Tuesday, March 20, 2012 8:46 AM
Azorean
Back to the SUE.
http://i1200.photobucket.com/albums/bb328/pacheco1976/sue52.jpg
this is white on Sue Yes
Posted by VanceCrozier on Tuesday, March 20, 2012 12:41 PM
el jere - very nice looking Lear Jet
Azorean - paint time on the SUE… makes me want to get mine out now, but I haven't even started the Pucara yet, hoping to do so soon,
Posted by Bish on Thursday, March 22, 2012 4:08 AM
Thanks Azorean, Ditto on the SUE. We will see some paint on it soon i hope.
This time next week, i hope to almost/actually finished. So fingurs crossed.
    October 2010
Posted by Casper the Chihuahua on Saturday, March 24, 2012 7:57 PM
Fuselage almost complete. There were some very nasty gaps whee the intakes join to the fuselage. Lots of Tamiya putty this week!
Cheers
    January 2003
Posted by el_jere on Monday, March 26, 2012 4:46 PM
Just out of the oven,
Not perfct but it´s finished. I added some anntenas, som modifcations, clar lenses, static discharges, etc etc....
Seeing the pics I realize that I still have to correct some things, but this is it. The amin was to build a simple model and a rlaxing projct and that is what I have done.
best regards to all
Jeremias
ps: sorry for the pictures qualities, almost non peparation, pooor light and a dirty background LOL
Res non verba
    April 2005
Posted by Thunderbolt379 on Monday, March 26, 2012 5:43 PM
El jere -- marvelous work! The Lear is a very rare subject and you've done it justice! Top stuff!
Mike/TB379 (whose PhD came through yesterday!)
http://worldinminiature.blogspot.com/
Posted by Bish on Monday, March 26, 2012 11:57 PM
Jere, that looks damn good to me. I can't make out what needs correcting, but then i'm no expert. But i would be more than happy with it. Yes
Mike, whose a cleaver boy then Wink Congrats, what was the PhD in if you don't mind me asking.
    October 2008
Posted by bsyamato on Tuesday, March 27, 2012 6:03 AM
Well done El_Jere Toast i'm with the two above comments, no visible mistakes there
    April 2005
Posted by Thunderbolt379 on Tuesday, March 27, 2012 6:43 AM
Bish -- it's in Archaeology. I have the trifecta -- Honours, Masters and Doctorate.
M/TB379
Posted by VanceCrozier on Tuesday, March 27, 2012 8:30 AM
el_jere
http://i63.photobucket.com/albums/h141/el_jere/Learjet%2035/PICT0017.jpg
Nicely done Jeremias! Yes Yes
    January 2003
Posted by el_jere on Thursday, March 29, 2012 5:12 PM
Thunderbolt379
Thanks a lot guys! (and congratulations to yo TB379!!! I am just about t start my own Ph.D on agricultural sciences, I still have a long path to travel LOL)
I am glad you liked the model, it does have some issues, I know because I know where to look LOL.
I hope to see more finished jobs soon!
best regrds to all
Jeremias
Res non verba
    December 2009
Posted by Azorean on Saturday, March 31, 2012 12:02 PM
Jeremias, you did really a great work on the Learjet. I love the final result and i want some day to do the same model. Congratulations. What a project!
