Day 4....
Jgeratic and greenshirt- Thanks again for your help. Between the sites you listed and some googling, I have come up with a final plan that I am pretty happy with. Several sites have info about the PR's, unfortunetly some of it is conflicting, so I am again going with "what looks right."
That being said, this is mostly what I am going for:
Overall the pale pink color, with no roundels on bottom. The only modification I plan to this is I have read that several PR's did not have a designation code on the fuselage at all. I may go with that plan just for simplicity.
Some noteable mods to the plane are obviously the camera holes, one on the left side and two on the bottom. Also the lack of a radio antenna, as the radio was removed in many PR's to not only make room for the camera, but also to enforce radio silence. One other thing is that the PR's did have an enlarged canopy, as was mentioned, and since I don't have the time or money to fiddle with the aftermarket set, I plan to just use the bubble canopy and call it close enough.
As for the build, still going smoothly. Cockpit and pilot are mostly painted, just need to do the instruments and the pilot's face. Should only be a couple more days and I can put it all in. Fiddly bits are in place and painted inside the fuselage, which is also now glued together.
Before:
![SDC12734](http://farm8.staticflickr.com/7148/6486366201_cb7048c47e.jpg)
After:
![SDC12736](http://farm8.staticflickr.com/7157/6486366209_84f7984ba0.jpg)
The red arrows point to approximately where the camera ports will be. I probably should have cut those out before gluing it together. Oh well.
One other thing to mention is I got the wheels glued up into the wing, which required a lot of trimming. I almost had to cut the struts in half to get everything to fit in the "up" position.
27 days to go....
