Official Harrier GB
    October 2010
Posted by Casper the Chihuahua on Friday, February 24, 2012 7:57 PM
Haven't got much done this week. It has been a bit of a rough week here. One of our chihuahua's, Lychie, died this week. He was very old, 16 but much loved and will be truly missed.
Got some work done on the intake doors. This is tough work but the PE fits nicely and when painted should give a very realistic look to the plane.
Cheers
PS. My avatar will be changed to honor Lychie for the time being.
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    October 2010
Posted by Casper the Chihuahua on Sunday, February 26, 2012 11:13 PM
Some more work on the Harrier. Fusing the cockpit section onto the rest of the fuselage. This is being glued only on the starboard at the moment but it's necessary to temporarily tape and hold the port side so it makes a better match. There are many gaps in this kit already Super Angry
Cheers
    October 2009
Posted by jetmodeler on Monday, February 27, 2012 5:48 AM
Looks like you've had a lot of progress on this one. I really like how your CP turned out. It looks very busy.
    October 2010
Posted by Casper the Chihuahua on Friday, March 2, 2012 10:59 PM
My first exhaust nozzle with PE. 1 down, 3 to go. A bit fiddly but worth the effort
Got the engine fitted inside and glued the fuselage together. Quite a nasty seam underside as you can see Tongue Tied
Cheers
    October 2008
Posted by bsyamato on Saturday, March 3, 2012 9:45 AM
Don't worry , you was not alone with fuselge gaps Whistling relatively for the scale, the nose gap of the italeri gr3 was more than your giant
good work Casper Yes
    October 2010
Posted by Casper the Chihuahua on Saturday, March 3, 2012 9:37 PM
Slow progress but slowly coming together.
Cheers
    October 2010
Posted by Casper the Chihuahua on Friday, March 9, 2012 7:38 PM
Some work done on the front wheel
and the inside of the airbrake
Slow work but it's starting to come together
Cheers
    October 2010
Posted by Casper the Chihuahua on Saturday, March 10, 2012 10:21 PM
First Sidewinder. This almost took 3 hours of work to assemble! I think I'll only do 2 of these are fit the external fuel tanks as well.
Cheers
    October 2010
Posted by Casper the Chihuahua on Friday, March 16, 2012 7:04 PM
So the stage that I have been putting off for as long as I can is the canopy. As nice as the Flight path set is, the instructions leave a lot to be desired!
The front canopy section has a raised section just where it meets the front of the fuselage. The Flight Path set contains nice sill details with riveting. It however does not mention how to apply the new sill to the clear plastic part.
So I had a think about this and there is a secondary brass part that fits on top of the front of the sill. I thought that this simulates the 'bulge' in this section so I decide to saw off the front part of the canopy.
A disaster! A poor sawing job, the blade kept bouncing and making a new cut and finally the glass snapped in a very conspicuous place.
Lucky there are 2 front canopy parts in this kit. The second part seems to be a bit messier in its molding but Future should help with that. So I carefully scribed the cut outline first and made very slowly but slightly firmer strokes. A much better result.
PHEWW!!! Huh? A botched canopy can ruin a model. A test fit with the brass sill confirms that this will work just fine.
Also got the first external fuel tank done. Note the brass sway braces, they really help with the detail.
Cheers
    October 2010
Posted by Casper the Chihuahua on Saturday, March 24, 2012 7:57 PM
Fuselage almost complete. There were some very nasty gaps whee the intakes join to the fuselage. Lots of Tamiya putty this week!
Cheers
    October 2010
Posted by Casper the Chihuahua on Saturday, March 31, 2012 9:45 PM
Slowly getting towards painting. Canopy finally attached (the brass sure looks nice but is a total PITA to install on canopy plastic!!!!), cockpit masked off. Just some more greeblies to fit, also completed the vortex generator replacement in brass on the wings.
Cheers
    October 2010
Posted by Casper the Chihuahua on Wednesday, April 4, 2012 2:46 AM
This bird is such a marathon to paint. Two hours and I've got the top done and half of the underside. I can't believe I ran out of paint, used up one and a half of Mr.Colour H333. Time to pay a trip to the LHS tomorrow.
Cheers
    October 2010
Posted by Casper the Chihuahua on Thursday, April 5, 2012 9:37 PM
OMGZ, this thing IS a monster! Devil I have finished the painting, touched up with a good brush on the areas where it was hard to get in with the air brush. Nose and tan/black masking's done. Next a gloss coat in prep for the decals.
Cheers
    October 2010
Posted by Casper the Chihuahua on Saturday, April 7, 2012 8:30 PM
Entering the home stretch on this build. Got the decaling done and started to attach the greeblies. A lot of those on this bird. I have almost finished the exhaust nozzles. Got the rear exhaust plates to Alclad in magnesium, I have painted the AIMs white and then they will get a gun metal tip. Then it will be time for weathering and shading.
Cheers
    October 2010
Posted by Casper the Chihuahua on Tuesday, April 10, 2012 2:08 AM
Slow progress on the Harrier. getting all of the geeblies sorted slowly.
AIMs turned out well. I'm getting better at airbrushing gloss white but it's still a PITA! Did the tips in magnesium, makes a nice contrast. Next decaling for them;
Cheers
    October 2010
Posted by Casper the Chihuahua on Saturday, April 14, 2012 1:55 AM
Ok, I'm calling the Sea Harrier done. This kit really did show it's age, not great fits on joining parts etc. Lots of flash, ejector marks etc. But it did spruce up ok with the Flightpath set (despite the not-so-clear-instructions included). I gave the plane a not so subtle oil wash, I wanted to show a bit of battle grime and the elements out on the aircraft carriers deck.
Cheers
    October 2010
Posted by Casper the Chihuahua on Saturday, April 14, 2012 6:20 PM
Scorpiomikey
Very very nice build. Can you post a photo of it next to another smaller scale? (eg a 72nd spit if you have one) Just to show the difference in size.
Ok, just to show the difference in scale, here is the Sea Harrier 1/24 next to an F-16 in 1/48
Quite a size difference, huh!!?? Whistling
Cheers
    October 2009
Posted by jetmodeler on Sunday, April 29, 2012 1:09 PM
Casper~ I love how it came out. The build looks awesome. Nicely done.Toast Sorry I missed out on most of the build but I haven't really had the time lately to do much.
Your build is now posted on the first page.
    August 2009
Posted by TREYZX10R on Sunday, April 29, 2012 1:50 PM
Casper that came out really well ,nicely done Sir!
