Airfix Group Build 2011-2012
    September 2011
Posted by Centhot on Friday, October 7, 2011 8:24 AM
[quote user="VanceCrozier"]The Buffalo is in the home-stretch! Can't wait to see that one finished up./quote]Astonishingly good painting for hand-painted.
2012 A/B/C: 10/3/0 (Acquired/Binned/Completed)
    October 2008
Posted by bsyamato on Friday, October 7, 2011 8:32 AM
Centhot don't give up about the camel, really a pita kit but at least give it the wheels and the gun Yes
TD the buffalo is really good Yes
Posted by VanceCrozier on Friday, October 7, 2011 8:41 AM
[quote user="Centhot"]
VanceCrozier
It's all about thin paint & multiple coats! I've got a few in the display case that are from my pre-airbrush days that I am still pleased with the finish. Patience patience patience. I suspect I was so patient because I was trying to avoid homework assignments at the time!  Hmm
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    January 2009
Posted by Griffin on Friday, October 7, 2011 9:53 AM
VanceCrozier
I used to clean my room and do laundry.  I totally should have worked on models instead! Bang Head
    September 2011
Posted by Centhot on Friday, October 7, 2011 1:34 PM
I tried rigging the Camel, but, a disaster!  So, here's the final picture, before it goes to the last mission, a terminal mission, that will only end in it's loss...
    September 2003
Posted by checkmateking02 on Friday, October 7, 2011 2:32 PM
You've done a creditable job with perhaps very little to work with.  When I did WWI years ago, I preferred Revell's Camel to Airfix; just seemed better.
Nonetheless, congratulations on your perseverence and the skills you've learned.  I don't think I'd have stuck with it like you did.
    September 2011
Posted by Centhot on Friday, October 7, 2011 4:40 PM
OK, so, after the debacle of the Camel, here's the Widgeon.
Here's how it was when I started the GB
I'd read elsewhere, several times, that the engines didn't fit the nacelles, as can be seen here:
The solution was green putty and plenty of it!  I also removed the rather pathetic coolers (?) on the top - I'll fashion new ones.  If nothing else, would be hard to blend every in with them extant.
One done!
Both done, and the mainplane attached.  Some blending will be needed though, as the square section is a different size to the fuselage...  I'm getting the idea that everything is to a different scale here!  Still, the fuselage fitted nicely (mostly), almost Tamiya infact!
    March 2006
Posted by TD4438 on Friday, October 7, 2011 5:43 PM
Glad to see you forging ahead on another kit Centhot.
Thanks for the kudos on the Buffalo fellas.I am enjoying it.The decals however totally blow!
They just won't lay down in places for Micro Sol or Micro Set.The a/c reg. numbers broke into five pieces each.I tried to salvage the first,but it folded up and that was it.I should have it finished in a day or two.Pics to follow ASAP.
    June 2008
Posted by lewbud on Friday, October 7, 2011 7:43 PM
Centhot way to keep at it!
TD, looking forward to seeing the Buffalo finished.
Dupes, looking forward to seeing the lawn dart finished.
Kinda stalled out on the Spit for the moment.  Really should get back to her, as all she needs is the exhausts painted, the landing gear installed and the decals applied.  Went to the local HobbyTown today and came back with this (has the corrected SLA, CSM and BPC):
Went into my closet, and found this (vintage 1978):
 Upon opening the Shuttle, I found my Cutting Edge resin SSME set, Shuttle Tile decal set, Shuttle vinyl mask set, SILTS pod and an updated Shuttle Logo set.  Plan on meeting some friends at a not so local HobbyTowntomorrow for lunch.  They had the updated Saturn V in Skylab configuration last time I was there, maybe bringing that home as well.  If so, the Saturn Ib will be in a Skylab paint scheme.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    February 2011
Posted by the real red baron on Friday, October 7, 2011 11:27 PM
my paints are humbrol acrylics, never mind the alcohol idea though ill try and pick up some future stuff...
    March 2006
Posted by TD4438 on Saturday, October 8, 2011 1:01 AM
Current progress.
All usable decals applied and sealed.Just gotta finish up the canopy and weather this bad boy.
    September 2003
Posted by checkmateking02 on Saturday, October 8, 2011 10:22 AM
TD, that is really nice.  Great work.
    March 2006
Posted by TD4438 on Saturday, October 8, 2011 9:03 PM
Thank you sir.The canopy is gonna take forever.The paint goes on very thin,so it's gonna need numerous coats.
    October 2008
Posted by bsyamato on Saturday, October 8, 2011 9:09 PM
Centhot nice to see back on work Yes
nice incoming pieces Lewbud
great nice work on the buffalo TD Yes
    September 2011
Posted by Centhot on Sunday, October 9, 2011 3:32 AM
checkmateking02
I'll second that!
    March 2007
Posted by JMart on Sunday, October 9, 2011 7:15 PM
There is some great work in here; lots of "old friends" (the kits I mean ;)
so you accept cross-overs? I just joined in the SAR GB with the olf Airfix RAF 63ft Rescue Launch. I can x-over here if allowed.
cheers
    March 2010
Posted by Scorpiomikey on Sunday, October 9, 2011 7:27 PM
Yeah sure, ill put you on the list.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    November 2004
Posted by cdclukey on Monday, October 10, 2011 6:47 AM
Scorp--
I've got Airfix's new HMS Trafalgar kit. The hull is together but no paint or fiddly bits have been put on. Is it eligible?
    September 2011
Posted by Centhot on Monday, October 10, 2011 7:59 AM
This GB has been most useful and fun - it's made me actually get those old kits built, and in the case of the Camel finished (not well, but as I say, the worst finished model beats the best unfinished one) - including fabricating some new parts to replace missing bits!  Alone, I probably would have just binned it.
I'm actually thinking I might run my own GB, for kits from companies that no longer exist, which is rather small actually, but includes some classics.  Matchbox, Frog, and Esci spring to mind.  How does one go about creating a GB?
    November 2004
Posted by cdclukey on Monday, October 10, 2011 2:46 PM
Just start a thread and see who signs up!
    March 2010
Posted by Scorpiomikey on Monday, October 10, 2011 4:29 PM
Well thanks for the compliment centhot. The best thing you can do is start a feeler thread. If you get enough responses, just make an official thread with a badge and a set of rules.
If you build it, they will come.
My signature
    September 2011
Posted by Centhot on Monday, October 10, 2011 4:47 PM
Oh, well, I just went for it!  It's called Erstwhile Classics, which maybe is a bad name?  Need to think of a badge, and how to make one.  Anyway, let's see who signs up!  Basically, I was inspired by this GB!  I have an Esci 1/72 F-16B which is just crying out to be built!  Then there's a Matchbox Buffalo, and a Frog DH.Hornet., and a...
    September 2011
Posted by Centhot on Monday, October 10, 2011 4:48 PM
Scorpiomikey
Field of Dreams!  Doh!  Didn't pick-up on that reference immediately! Very good.
    March 2010
Posted by Scorpiomikey on Monday, October 10, 2011 5:13 PM
Actually i think i got that quote from waynes world lol.
My signature
    August 2007
Posted by DUSTER on Monday, October 10, 2011 5:17 PM
Centhot
 Scorpiomikey:
That makes you the Keven Costner of the GB anyway   Cool
Steve
    March 2006
Posted by TD4438 on Monday, October 10, 2011 6:47 PM
Centhot
You could call it the OOP Group Build!
    September 2011
Posted by Centhot on Monday, October 10, 2011 6:56 PM
TD4438
Well, I was thinking of a British Classic GB, but, Esci produced great stuff too
    August 2007
Posted by DUSTER on Tuesday, October 11, 2011 12:44 AM
Some ideas if you dont mind, yours if they help- I like the idea of the GB (could get rid-er- build some of the old timers in the stacksYes )
Classic Companys Group Build
Now Long Gone Group Build
Past Not Present Group Build
Steve
    September 2011
Posted by Centhot on Tuesday, October 11, 2011 3:37 AM
Good ideas Duster!  I renamed it the Long Gone Classic Companies GB, mixing two of your ideas
    February 2011
Posted by the real red baron on Tuesday, October 11, 2011 4:26 AM
Centhot - I've always wondered this, do you like oranges?? Stick out tongue
