Airfix Group Build 2011-2012
    March 2010
Posted by Hercmech on Tuesday, May 8, 2012 12:29 PM
Very nice Vance! Looks like the agent is planning which part to eat...at least that is what mine does
13151015
Posted by VanceCrozier on Tuesday, May 8, 2012 1:48 PM
No, actually she's very good with the "look, don't touch" rule. Almost always makes an appearance during any particular kit build for an inspection. Hangs out for a few minutes & leaves without touching. Like she's reporting back to someone...
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    October 2008
Posted by bsyamato on Tuesday, May 8, 2012 4:38 PM
Good updates Vance Yes strange thing about the use of the upper brown
Posted by VanceCrozier on Wednesday, May 9, 2012 7:43 AM
Yes, I was mixing my own olive-green colour for that & once sprayed on & dried next to the other green... way more brown than I had planned on. This isn't a contest-build by any means, so I'm just going to leave it as it is.
    April 2005
Posted by taxtp on Thursday, May 10, 2012 11:15 PM
Wow, this is a fantastic GB. I've been working on their 1/350 HMS Trafalgar submarine. Could I sign up please ? I've done most of the construction, but that's only a couple of hours work, it's a simple kit. It's completely bald and unpainted at this stage, and there are still some seams to clean up. The kit was released in July 2010.
Cheers
Tony
I'm just taking it one GB at a time.
    March 2010
Posted by Scorpiomikey on Friday, May 11, 2012 12:44 AM
yeah sure. Ill update the front page.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    April 2005
Posted by taxtp on Friday, May 11, 2012 3:40 AM
Thanks. here's a pic. The white thing under the Conning tower is a bit of plastic card I've used to replace a part that I couldn't find. Not sure if I lost it or it was missing, but probably the former.
You can just make out a white line of putty in front of the prop, that's a pretty ugly seam.
Other than that, I'd say I was surprised that the kit doesn't depict the tiled effect visible on the real craft, but it goes together easily enough.
It'll give it a prime tonight, to see how it goes.
Eventually I'll spray it 'near black', so that I can use pure black for the panel lines and weather accordingly.
Cheers
Tony
    March 2010
Posted by Scorpiomikey on Friday, May 11, 2012 3:56 AM
The skin of the sub is surprisingly smooth. What your seeing in the "Tiled" effect is actually variations in the colour of the skin.
Unless your talking about the decking?
That seam you filled. Are you sure it was a seam and not the gap between the prop hub and the fuselage (or whatever its called on a sub)
My signature
    April 2005
Posted by taxtp on Friday, May 11, 2012 4:22 AM
Thanks for the pic. The photo depicted on the box art shows a really distinctive tiled effect on the conning tower. The photo here illustrates what I'm trying to say, and also shows some tile like detail on the hull.
I think the seam I filled is meant to be separation, however it is is really wide and uneven and can't be left as such. I've use the fill and wipe method, so the fill is slightly recessed and will be treated with a black wash to highlight it.
    April 2005
Posted by taxtp on Friday, May 11, 2012 5:48 PM
The first light prime revealed a couple of spots that needed some tidy up...
Hopefully this next prime won't show any more.
Cheers
Tony
    October 2008
Posted by bsyamato on Friday, May 11, 2012 6:46 PM
Scout updates
Tail rotor striped
And start to add pieces on the engine
    April 2005
Posted by taxtp on Monday, May 14, 2012 8:43 AM
Good progress on the Scout. I built that thing many many years ago, in fact, it's the only 1/72 Helo I've ever attempted.
I've got the Trafalgar to the decal stage. Here's some photos in it's gloss black coat, with fresh decals. It will get a coat of dullcote and some shading and weathering with chalk pastels in the next 48 hours or so.
Looks way too shiny right now, but I think it will be quite striking in black. The other subs I've built are shades of grey.
This is the first time I've used Mr Mark Setter as a decal setting agent. It looks to be quite a good product.
Cheers
Tony
    October 2008
Posted by bsyamato on Monday, May 14, 2012 10:00 AM
Nice work on the little Trafalgar YesYes
build more helicopter Taxtp ,it's too funny Big Smile
This is the result of 20 years of helicopters ,all in 1/72
After looking better to the scout engine ii replaced the exhausts too!! are totally wrong on the kit
First attempt
and the second was better
now it's time to fill the engine with lots of cables and conductors Big Smile
Posted by VanceCrozier on Monday, May 14, 2012 10:23 AM
That's a nice-looking bunch of helicopters bsyamato! I need to sit down without anyone else at the house & get my Heinkel finished up here soon. Maybe I feel a "sick day" coming on ~cough Ick! cough~ Wink
    October 2008
Posted by bsyamato on Monday, May 14, 2012 10:42 AM
age coming on Whistling
i hope nothing serious Vance
Posted by VanceCrozier on Monday, May 14, 2012 11:15 AM
bsyamato
I'm sure a few days home will cure it! Wink
    April 2005
Posted by taxtp on Monday, May 14, 2012 4:53 PM
Good bunch of helos there. I like to see collections like that. Maybe I should build some more...
Cheers
Tony
    October 2008
Posted by bsyamato on Monday, May 14, 2012 5:16 PM
out of the scout i have the little cayuse from italeri but next time will look for huge russian copters Embarrassed
    April 2005
Posted by taxtp on Wednesday, May 16, 2012 8:53 AM
My HMS Trafalgar has come together pretty quickly. I need to do a second coat on the prop, and one or two little touch ups around it, and maybe accentuate the panel lines some more, although they show up better to the naked eye than they do under my terrible photographic skills. It's near enough to being done that I'm calling it.
Note that it's not attached to the stand, so the lean is temporary :)
Overall I'd say it's a very pleasant kit, and one that certainly makes me enthusiastic about trying some more of new 'New' Airfix releases.
Cheers
Tony
Posted by VanceCrozier on Wednesday, May 16, 2012 9:04 AM
taxtp
http://i10.photobucket.com/albums/a102/tonymollica/Model-HMSTrafalgar004.jpg
Hey, it's smiling at me!!!! Nice work. I've never tried my hand at a submarine, may have to give it a go at some point.
    October 2008
Posted by bsyamato on Wednesday, May 16, 2012 9:53 AM
Fine work Taxp YesYes
    March 2010
Posted by Scorpiomikey on Wednesday, May 16, 2012 3:41 PM
Well done, ill get that front page update. Feel free to grab the badge any time.
My signature
Posted by Alex Shaw on Wednesday, May 16, 2012 4:26 PM
Great job on the sub taxtp Yes
    April 2005
Posted by taxtp on Wednesday, May 16, 2012 6:57 PM
Badge grabbed, thanks for hosting this GB. I'm building another Airfix kit (HMS Amazon) over on the Falklands/Malvinas GB, so I'll post the odd picture here just to keep it bubbling along.
I hope that Airfix do well out of this and do some more new British ship kits, particularly subs. Then again, I hope they do more 1/32 car kits, and more aircraft, and...
Cheers
Tony
    February 2011
Posted by randypandy831 on Saturday, May 19, 2012 4:30 PM
when does this GB end? i got a seafire 17 i wanna throw into this.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
    March 2010
Posted by Scorpiomikey on Saturday, May 19, 2012 5:14 PM
Hey randy, it ends in September. Ill put your name down?
My signature
    September 2003
Posted by checkmateking02 on Saturday, May 19, 2012 5:17 PM
Great results on the sub, Tony.  If it loos as good in real life as it goes in the photos, I don't think I'd touch it any more.  It has a very appealing and attractive finish already.  Outstanding.
    February 2011
Posted by randypandy831 on Saturday, May 19, 2012 8:01 PM
Scorpiomikey
Yes,please!
48 scale seafire 17.
i'll update with pics tonight. currently cleaning the parts and sanding down the injector pins inside the wings.
out of the box build besides the eduard mask.
    March 2010
Posted by Scorpiomikey on Saturday, May 19, 2012 9:04 PM
Front page updated.
My signature
    February 2011
Posted by randypandy831 on Sunday, May 20, 2012 8:02 PM
update from last night.
awesome fit upon testing
wing halves glued. one of my clamps may have gave it a few scratch marks. something mr.surfacer can handle
would have loved to get more work done today, but i had a killer migraine.
