Guys, its been a busy weekend, but I managed to plug away at the A13:
I sprayed some dark greenonto areas that would be hard to reach with the AB later on. Tamiya XF-27 Black Green was already on the bench so I just used that.
The muffler assembly took several hours to assemble! First I had to fill the gaps in the muffler and exhaust pipes, open up the "fishtail" exhaust ends, scratchbuild some flanges for the pipes to sit in (otherwise there's a big gap that's barely covered by a stupid, thin PE disc with bolts??), figure out how to bend the muffler bracket PE without breaking it (which I did of course! ), and position those exhaust pipe brackets! In the end it wll worked out but I did manage to install one of the PE muffler straps on backwards (or outside in?)
Here's the assembly before adding to the back plate:
and after installation:
I also assembled the air intake covers and the muffler shroud and presprayed the interiors with dark green:
While some of this was drying I managed to assemble the basic parts of the turret. The front turret plate isn't glued on yet as I need to figure out how to tighten the pivot points on the mantlet.....its a bit loose and the main gun keeps falling down!!
most of the major assembly is done. A few more items and then I'll move on to the tracks. All the little bits and doodads hull will be added after I get the tracks fitted and right before painting as I'm notorious for breaking such things off during construction!
Sorry that I haven't responded to any posts! I'll check things out tomorrow after work!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
