Nice Duster there Wayne. I do love that old Tamiya kit, even if it is quite outclassed by the new AFV kit. I have one in my stash along with all sorts of upgrades that I will tackle one day soon.
Thunderbolt, my biggest issues with the MM Acryls is poor coverage and adhesion. The now discontinued Marine Colots line had the worst adhesion I have ever seen in model paints. Now this particular color thay I used here on the Tiran does not have that issue, although many others have. But it does have very poor opacity and if there is no primer or base coat down, it is even worse. I have changed my thinning ratios down to where I am barely using any thinner, and while this reduces that issues, it does not eliminiate it all together. In almost every case that I have used MM Acryls, a second coat is needed after the first coat has dried overnight. The base coats are transluscent. Which is a shame because their color selection is awesome. The Polly Scale line had better one coat coverage over bare plastic, but of course Testors, who produces both, has discontinued that line. The tip drying issues with those I solved but cutting in a little bit of Future into the thinned paint prior to airbrushing and that gives it just enough wetness and tooth to work really sweetly, and ended up with a slight satin sheen like much of the Gunze Aqueous line.
Well last night before I was rousted off my work bench by my spousal unit, I got a bit more work done:
decals (very few) on, and Solvasetted into place... with minimal silvering where I had feared as there was no gloss base coat...
a couple tow cables made from some old Tamiya T-34 type kits and teh bad plastic replaced with parachute cord guts
I drilled out the slot where the co-ax machine gun goes next to the main gun
and modified a 105mm tank gun ammo crate to fit on the glacis as shown in some photos
and I added a coat of Tamiya Clear Green on periscopes and sights
more to follow after todays work session at the bench...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
