B-36 Peacemaker Group Build
    November 2013
Posted by Teutonic222 on Thursday, November 14, 2013 10:04 PM
Regarding fuselage warping, I got lucky. My kit looks nice and tight. I can pop the fuselage halves together and I don't see any gaps.
On a different note, is anyone else seeing large white gaps between some of these posts? I'm wondering if that is where my photos were supposed to be showing up, although those gaps didn't appear in my first two attempts at trying to post photos. I off for a few minutes to try PhotoBucket and see if that works. Otherwise I'd like to find out if there is a way to contact the forum moderator and find out what 's going on with my photo posts.
    November 2013
Posted by Teutonic222 on Thursday, November 14, 2013 10:12 PM
Okay. One more attempt at photo attachments. This time I'm using Photo Bucket.
[View:http://s1012.photobucket.com/user/mlundquist1/media/20131108_165605_zpsc3660b88.jpg.html?filters[user]=138233167&filters[recent]=1&sort=1&o=0:600:0]
[View:http://s1012.photobucket.com/user/mlundquist1/media/20131108_165623_zps5ceb4568.jpg.html?filters[user]=138233167&filters[recent]=1&sort=1&o=2:600:0]
[View:http://s1012.photobucket.com/user/mlundquist1/media/20131108_165631_zps9204c352.jpg.html?filters[user]=138233167&filters[recent]=1&sort=1&o=1:600:0]
    November 2013
Posted by Teutonic222 on Thursday, November 14, 2013 10:14 PM
What is up!! I am using rich formatting, selecting Insert Image. Copy URL from the specific photo (yes, I know how to do that). Paste URL in the Insert Image box. It place the text you see in my previous post (i.e. [View:http://s1012.photobucket...]. And I get the results above. It should be this hard.
    November 2013
Posted by Teutonic222 on Thursday, November 14, 2013 10:21 PM
This time I'll try pasting a slightly different code directly into the message.
<a href="http://www.flickr.com/photos/25391811@N02/10812384474/" title="20131108_165605 by mlundy, on Flickr"><img src="http://farm4.staticflickr.com/3723/10812384474_f9d32bb996_b.jpg" width="1024" height="768" alt="20131108_165605"></a>
    November 2013
Now we'll try it with BBCode.
    November 2013
Posted by Teutonic222 on Thursday, November 14, 2013 10:24 PM
God, that was painful. Following the directions in the forum photo pasting instruction doesn't work. Pasting BBCode directly into the rich formatting version without using the Insert Image did work. Soooo.
You have now seen my ISS & Shuttle model. Two more pics below.
As I originally said. It isn't a B-36, but does have five engines plus a bunch of thruster.
    November 2013
Posted by Teutonic222 on Friday, November 15, 2013 2:56 PM
Here is the drawing I sent to Chris at Click2detail of the Featherweight III windows. Dimensions are really just best guesses using my ruler. The B-36 photo is a decent shot of the blister replacement window.
    September 2011
Posted by lajntx on Friday, November 15, 2013 4:04 PM
Teutonic222
1 question.
The drawing shows the hole to where the opening would go for the window, but the window was flush with the fuselage contour. Are you having these built with the hole to install a clear piece, or just have the lines etched to show where the window is?
B-36 Peacemaker Builds
On the Bench: B-36 paint test  fusealge & RB-36E assembly test build
In Que: YB-36 Conversion Build & B-36 carries B-58 Airframe to Wright Patterson
Conceptual Planning: RB-36 X-15 Mothership
    September 2011
Posted by lajntx on Friday, November 15, 2013 4:07 PM
Good news, I found the other kit I was going to build a couple years ago of this, and the fuselage has sat stored taped together which will elimnate the need to correct the warpage. I`ll switch over the wing spar, and use the warped fuselage to experiment with some painting to see how well a rattle can job can be done on this.
Ive found two different paints for the OD Green and I`ll use this to see which one I like better as well
    November 2013
Posted by Teutonic222 on Friday, November 15, 2013 7:00 PM
In my opinion, I think just a hollow area, painted black and then make a window using Model Master Window Maker would be the best solution. If the window is molded all the way through, the thickness of the plastic makes it difficult to glue in a window that looks flush. But, Chris didn't say which way he would go.
    November 2013
Posted by Teutonic222 on Friday, November 15, 2013 7:02 PM
Why not fasten the two complete fuselages together at the wing spars, twin tales, and then have double the bombing volume with just the 10 engines?
    November 2013
Posted by Teutonic222 on Friday, November 15, 2013 7:31 PM
More questions. More questions. I mentioned before that I plan to hang my aircraft.
1. It's been a while since I have hung a model plane. I'll use fishing line, but what do you all recommend as the best places or ways to attach the line, especially since I'll still have it nose-weighted for use on a shelf/table if I ever have the inclination?
2. Has anybody ever modeled the B-36 in a flaps down position (probably 15 or 30 deg flaps or so)? If so, how did the mod go? Or is this one of those "what are you thinking" modifications.
3. Has anybody modeled the main landing gear in the accurate position where the bogies are actually hanging forward (i.e. the front pair of wheels hangs lower than the rear pair of wheels)? I have both the original plastic gear and the aftermarket metal gear. I thought I would use the metal gear for on-the-ground display and modify the plastic gear for the hanging position. I'm guessing I could easily trade off the gear due to the fairly large pin-to-hole dimensions (usually a little tack) and hopefully do a similar thing with the wheels since I only have one set of wheels.
    September 2011
Posted by lajntx on Friday, November 15, 2013 7:32 PM
Teutonic222
The only way something like that is even contemplated is *IF* the Japanese had put up a stronger fight, and drastically slowed the Allied Island Hopping Campaign. Then it would have became necessary to bring the B-36 into production over the B-29 and launch bombing attacks against the Japs from Alaska or Hawaii. This in turn would cause the think tanks to come up with better ideas to put more bombs on a target.
Something similar with B-36`s was on the drawing board to use against the Soviets so the 36 wouldnt have to land in Alaska and refuel- Or have a way to make the ship go faster. During project TOM-TOM when it was being tested on having fighters link up on the wings of a B-36 and "piggy back" to the battle front it was suggested that instead of Mating two F-84`s on the wings of a B-36, to simple link up 3 B-36`s together with this linkage and either use 1 plane to carry the other two so they could conserve fuel and fly on.... Or use the 3 together to fly flaster and escape faster in a hot zone. I used to have drawings of this, but cant find them. In the meantime here is some video of the TOM-TOM project showing the F-84 Parasite being mated up to the B-36
    September 2011
Posted by lajntx on Friday, November 15, 2013 7:41 PM
Teutonic222
No idea there, you`ll have to use what you know and figure it out as you go along.... If it doesnt break and fall -- then it works. If it breaks and fall -- It didnt work
I havent, but there used to be a B-36 vet over on the B-36.net board that built models and said he did something along those lines once. Never saw a picture of it though.
Welcome to the exact thing I have been spending the last 3 years trying to figure out. As you know in flight the wheels hang slightly forward and the pistons are in different postions as well. I talked to the guy at SAC that does those metal gears once a few years ago and tried to talk him into making that. He told me I wouldnt like the price if he did. I asked.... and it was over $1000 to make those since it would require a completely new casting and the R&D that would go into it. Other than doing surgery on a plastic set and living with the fact it still isnt looking right... Or just living with it in "on the ground" position is about as far as I have been able to get with it.
    February 2011
Posted by Reasoned on Friday, November 15, 2013 8:45 PM
I am also modeling my B-36 just like Teut22 and put in nose weight (just in case) but plan to hang from ceiling in landing mode, never thought about the gear being inaccurateConfused.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    September 2011
Posted by lajntx on Saturday, November 16, 2013 12:24 AM
Reasoned
The landing gear is molded in an on the ground postion, not really a lot you can do about it other than manufacture your own, pay someone good money to make a part very few people have an interest in, or just live with it.
Chalk it up to one of the limitations of this kit
Here is a good pictures of what it looks like:
    November 2013
Posted by Teutonic222 on Saturday, November 16, 2013 10:10 AM
Thanks lajntx. I wasn't particularly serious about, however. :)  It would have made for a particularly interesting concept, though.
    November 2013
Posted by Teutonic222 on Saturday, November 16, 2013 10:12 AM
Well Reasoned, I hope you aren't OCD, because now that you know the landing gear is not quite accurate it could nag at you for the rest of your life. :)
    November 2013
Posted by Teutonic222 on Saturday, November 16, 2013 10:17 AM
lajntx - your insight on hanging the model was totally underwhelming. Made me laugh. Maybe a safety net underneath in case it stalls out and decides to come crashing to the ground..
The flaps down position also seems like one of those "is it worth it" mods. The landing gear ought to seem easier, but it's the rocker toggle that cause the problem.It's fairly easy to cut the bogie and re-calibrate the angle. It's fairly easy to trim/extend the cylinders. It's that dang beam connecting them that's the big problem. I might look deeper into it.
    February 2011
Posted by Reasoned on Saturday, November 16, 2013 11:46 AM
Teutonic222
Ha!  Well since it will hang from my 9yr old's ceiling, I suspect it will last all of a week before a high altitude crash anyway.
BTW, In response to your question regarding hanging it, I'm planning on using 2lb mono fishing line wrapped around the tail section and somewhere on each wing then have them come together in one spot in order that I can tie off on a hook in the ceiling.
    September 2011
Posted by lajntx on Sunday, November 17, 2013 1:03 AM
Today I played around a bit with my warped fuselage with some spray cans to see how well it would work. Out of the 4 I tried today..... 1 was a complete failure, 1 didnt work well, 1 looked nothing like the color of the cap, and the last really wasnt the color I was looking for but it just might work for other things.
Firstly I put the test paint fuselage together but it just didnt quite fit
Hmmmmmm, I put the wing spar in upside down. Hmm
I know Ive seen this somewhere else before. Whistling
The silver paint looked too light, and the "Chrome" was a complete failure. Back to the drawing board there.
I tested 2 greens. The one with the perfect color based on the can cap came out too regular green, and the camo green came out a little too dark... But looks to be the perfect color for an armor build or even a B-17 in OD Green.
For this build though... I just might build it with that Camo Green to see how it looks.
    September 2011
Posted by lajntx on Sunday, November 17, 2013 1:11 AM
Reasoned
Teutonic222
That`s why you should make the engines operable so it doesnt fall Stick out tongue
    September 2011
Posted by lajntx on Sunday, November 17, 2013 1:17 AM
Teutonic222
Just as in the video above. Let`s just go all the way like this guy did.
    February 2011
Posted by Reasoned on Sunday, November 17, 2013 8:20 AM
LOL!  That's 6 turnin' , now just imagine 4 burnin!
Hmm You know I've got those Estes rocket engines of my son's………
    February 2011
Posted by Reasoned on Sunday, November 17, 2013 8:24 AM
lajntx
Gee, I wonder where? Embarrassed
    November 2013
Posted by Teutonic222 on Sunday, November 17, 2013 10:40 AM
Sorry, if I'm going to do this, I want to see great clouds of smoke coming out at engine start-up. Since I was/are a model railroader, I think a model railroad locomotive digital sound system needs to be installed too with the B-36 engine sound .wav file I've seen/heard on the Internet.
    November 2013
Posted by Teutonic222 on Sunday, November 17, 2013 8:51 PM
1. Do you, or the rest of the build group, typically build fuselage and wings separate then attach the wings at the end of the build after painting each separately, or do you build up the whole aircraft (fuselage and wings attached) and then paint? I'm thinking fuselage masking and painting would be better without wings on, but I'd like not to have wing-to-fuselage seams.
2. I don't recall if I told you all, but you can order the DVD version of Strategic Air Command from ClassicMoviesEtc.com. It's $14.95 + S/H.
3. I was playing around tonight to see if I can create my own B-36 notices: the ones that are not included in any decal sheets (OEM or aftermarket), except the German Revell kit. Once my Wayne Wachsmuth book arrives, I'm hoping I can see all the notice markings I need. I have the exact "stencil" font and played around with proper letter spacing in MS Word, then shrunk it down and printed it out. Then I took that printed version and used the copier to shrink it again at 36% percent and printed it (printers can only get down to a certain size, so it needed to be shrunk via the copier). I was testing it out on the notice about fuel just forward of the port hatch. The decal-sized version scales out to about 5.8mm wide by 1.2mm high. My printed version actually works. It looks good. So, I'm thinking I can then just print on decal sheet. If I pull it off, I'll try to create as many notices as possible and make it available to all of you. If I can do it, it will be a couple of months, but hang tight.
    September 2011
Posted by lajntx on Sunday, November 17, 2013 9:16 PM
Teutonic222
Ive always put the wings on and painted that way.... but with the 1/72 kit... This will be my first go round with it when I complete the "test build" RB-36E to learn a few things first hand before moving on to my more challenging covervsions. Ive seen two builds where the wings were made to take off for better packing/travel results for builds that were for show display. Its your personal preference, but do be prepared to do a ton of masking which ever way you go, and always do the props last so you dont break them.
Cool, thanks! Up until now the only DVD versions I have come across were not available for play for the US region unless you had either a DVD player for that region or a world zone dvd player.
I`ll do you TWO better....
1. I`ll  send you a complete uncut copy of that Revell Germany sheet with all those markings and notices if you`ll reverse engineer some sheets for us. A side note though, there are some things on the warbirds stripe sheet that arent on that one, so having both gives you a compete job.
2. I`ll send you a landing gear set with those figures if you want to try and make it look like its landing gear extended in flight. If it doesnt work, then you arent out a set of gears. If you can make it work... I`ll send you another set and let you do mine, so when I hang this baby on my ceiling it will look correct.
Just let me know
PS... Scroll to 42:03 of this vid which shows the loading of the B-58 to the B-36. They just dont think out of the box like that anymore at General Dynamics do they? Stick out tongue
    November 2013
Posted by Teutonic222 on Monday, November 18, 2013 12:54 PM
Thanks for the updated answers. Still not sure about the wing-to-fuselage decision.  I'll probably opt for building it complete - wings attached.
I'll take you up on your decal and landing gear deal. This is the reason group builds are good! Everyone benefits. Hopefully now we can all have more notices, Featherweight windows via Click2detail, and other stupid stuff that few others appreciate.
    November 2013
Posted by Teutonic222 on Monday, November 18, 2013 2:16 PM
Regarding the out of the box thinking, no it doesn't happen quite like it used to. I got out of aerospace for that reason. The following numbers are off, but Aviation Week magazine had an article around 1995 that said (and here is where my numbers are off)...
If you graduated in engineering in the 1950's you would work on approx. 50 aircraft duruing your whole career that would actually fly (experimentals, test beds, and production versions)
If you graduated in the 1960's you would work on approx 32 aircraft that would fly.
If you graduated in the 1970's you would work on approx 15 aircraft that would fly.
If you graduated in the 1980's you would work on approx 6 aircraft that would fly.
They predicted (based on the trends and the use of computer modeling instead of actually building an airplane and testing it) that someone graduating in the 2000's+ would work on ... wait for this ... TWO aircraft that would actually fly DURING THEIR WHOLE CAREER. For me, that would be a non-starter if I were starting an aerospace engineering career today. The thrill is actually seeing something you worked on hit the skies.
I could see that already happening. I was blessed, based on my type of work and my position to have way exceeded those numbers, but most didn't and most won't. The problem was multi-fold:  1) the government continued to cancel programs before military production-intended aircraft even got to the experimental stage; 2) the DoD doesn't seem to work on any purely experimental aircraft anymore; 3) it is now cheaper (and probably better) to upgrade avionics rather than airframes to create a more advanced airplane; 4) drones (which are simpler and lower cost) are replacing many of the piloted aircraft, and; 6) commercial aircraft are becoming more and more expensive to produce, hence the reason we get versions of 737, 757, and 767 ad nauseum, rather than lots of new types, and; 6) the consolidation the aircraft industry (which needed to happen) means less competition, less ingenuity, and less new competing models (which mostly happened during competitions).
It's too bad, but life continues to move forward. I suspect there may also be another really big overlooming reason. We haven't had a big air war in a long time. There are very few "super powers" ... US, Russia, Europe, China (doesn't have a very good aerospace industry). Plus, in the "old" days, it was simpler to make an airplane, thus more countries could create them. Sort of like locomotives in the old days -- almost every developed or developing country had a locomotive industry during the steam days. Now, there are only a handful of loco manufacturers.
