QUOTE: Originally posted by jimz66
I am doing the Patriot Hornet from Twobobs. I am using the Aluminum for a basecoat. Like I said earlier as that fellow did in FSM a couple years ago with that Helldiver. He used the natural Metal finish as a basecoat. You think this is a bad idea?
Hi Jim. I didn't mean to sound critical, I'm mostly just curious because bare metal seems out of place on a Hornet. It makes sense (to me) for something like the Helldiver because when paint would chip off, you'd see bare metal. I think in the article you refer to, the author used that effect for weathering.
QUOTE:
I have the whole model assembled. Nothing is painted other than the cockpit. I have to paint the aluminum for around the weapons pylons plus the engine area in the back.
I know there's bare metal around the engine exhausts, but I wasn't aware there was any near the weapons pylons.
QUOTE:
I just figured it was the best way to go. My sanding isn't perfect but for this one I am still learning. I will work on this for each subsequent build I do in the future.
I am getting there I will do some more sanding before I proceed. Then rewash. You disagree?
Absolutely not! It's your model. Build it the way you want it. I'm at the relatively inexperienced end of the model-building pool. I've seen a couple of articles where folks have primed their planes with some sort of bare metal finish, so it's not a crazy idea. I'm simply curious about your take on the pros or cons of doing that for your plane.
I spent
a lot of time sanding and finishing the Phantom I'm working on. The primer coat really helped me spot the areas that still needed work. I'd work on something, shoot a primer coat of Testors light gray spray enamel, and then sand some more.
That's one advantage to a natural metal finish -- you'll certainly see where additional sanding needs to be done.
I'm glad I took the time to really work on the model before painting it. I simply can't see the seams now. There are still a couple of areas that could have used some work, but I'm the only one who is going to notice.
In any event, I apologize again if I came across as critical.
Good luck, and enjoy the build!
Regards,
