Dave... so you felt the atak zim was so thick you wanted to (had to?) sand it down?
Mail comes in about an hour and hopefully there will be zim. In the mean time, since I can't do too much, I noticed the welds on the top of the turret looked a little to deep down in a trough so that was filled with Squadron green, wiped with an acetone dampened q-tip and "welded' with one of my little tools for that task.
Kit didn't come with cables for some reason. I had some extra tow loops in the sparse box. The loop itself was the exact same size as the one the came in the G that was my 1st ever armor kit from long ago in the before time. The sleeve was too thick and long. I chucked a piece of plastic tube in a Dremel and snaded from .095" to about .082", taped one end and glued the loop cut off the big one to the tube.
I went on a hunting mission yesterday looking for the cord that Carl used on his KT. 1st went to the biggest tackle shop around here... then Micheal,s AC Moore, Hobby Lobby, Lowe's and Home Depot... NADA. But I think I got this one all squared away.
I've tried twisting all different kinds of wire in all different combinations and while some were OK... they were just OK. If the twist was in any way uneven it didn't look right. I've tried picture hanging wire before but it was of such poor quality... in the way it was twisted... it didn't look good either. I looked at the picture wire section again and found one I had not seen before made by "Ook". it covered with a clear plastic sheathing like an electric wire but the twist looked very even. After taking the plastic off, annealing the cable to soften I tightened the twist and I am very pleased with the way it turned out. The 1st pic below is a closeup of some wires/cables. from left to right.. What usual comes in a Dragon kit (looks more like rope than cable), Then the Ook wire with the plastic off before and after annealing and tightening. And an AM cable for armor. Except for the fact the twist is opposite... and I won't tell anyone of you don't... the last 2 look pretty darn close to me.
The AM cable... $6 each and ya need 2. The Ook cables... 9 feet for 3 clams. At that price the twist nearly looks like it goes the right way after all
