French a/c group build 2012-13
    June 2010
Posted by DoogsATX on Tuesday, August 14, 2012 2:46 AM
Finally have an update for y'all! Bigtime painting session tonight...still need to go back and do some cleanup in a few areas, and I'm guessing I may have to do some more general painting if there are any areas that look "light", but I want things to cure overnight at least before I make that call.
To give a sense of how much I've been thinning paint down lately, here's the first few passes of my blue mix:
And...
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by VanceCrozier on Tuesday, August 14, 2012 7:09 AM
Sprue-ce Goose
VanceCrozier
Interior pics of those WW2-era french machines do seem hard to find.
Even on the French language sitesHmm
Well, slightly easier I suppose. Need to switch my brain into full-on Français mode & start googling terms that way, see if I can get some better results.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by VanceCrozier on Tuesday, August 14, 2012 7:15 AM
You are certainly thinning the paint down - it's more like staining than painting!!! Is this just to make sure you don't lose the pre-shading, or is it to allow you to paint despite the Texas heat?!?! I love the colours you're using. Tamiya Acrylics - or are those bottles just there to prop up the kit?  Yes
    June 2010
Posted by DoogsATX on Wednesday, August 15, 2012 2:38 AM
Went back and re-shaded some of the brown and and khaki areas, then touch-ups all around, followed by a filter coat of the upper surface blue-gray thinned with white and 90% thinner to knock down the contrast and blend the colors a bit.
Pretty sure this wraps up the main camoflage portion of painting!
    September 2009
Posted by sub revolution on Wednesday, August 15, 2012 5:15 AM
Looks nice! They had some very strange colors, and I think that adds to the, um, uniqueness of the planes!
NEW SIG
Posted by VanceCrozier on Wednesday, August 15, 2012 6:52 AM
Looking good Doogs!
    June 2010
Posted by DoogsATX on Wednesday, August 15, 2012 9:55 AM
VanceCrozier
I'm actually using Gunze lacquers exclusively on this one - they're a lot more "dustproof" than Tamiya's paints in this heat but airbrush about the same.
The thinning, though, is more something I've been into lately, both to preserve the preshade and to add some depth to the paintwork.
I should also note that I freehanded the camoflage - first time I've done that in a LONG time since I'm usually the king of overspray.
Posted by VanceCrozier on Wednesday, August 15, 2012 10:09 AM
Freehanding it as well? Looks good. My hands are steady enough to do that on larger areas, but I need to pick up an a/b that can handle the finer details. (Yes, I'm blaming my tools!)
    April 2010
Posted by Theuns on Wednesday, August 15, 2012 11:12 AM
Dang Doogs that look good!
Do you find that the gunze lacures cure well if so thin? I have treid the same thing with humbrol and tamiya enamels to keep the shading but found if thinned to much they tend to not cure like they should, they rub of with handling the model more easlely.
Theuns
    September 2005
Posted by Sprue-ce Goose on Wednesday, August 15, 2012 1:31 PM
DoogsATX
Beautiful kit, Doogs. Nice work.
I am unfamiliar with the lacquer paint you are using.
Is it still available in the USA or must I send away to some former French SE Asia colony to obtain it ?
Posted by VanceCrozier on Wednesday, August 15, 2012 7:05 PM
I've never gone looking for Gunze's goods, but I keep hearing about them - must be available in the US without too much effort.
    April 2005
Posted by taxtp on Wednesday, August 15, 2012 7:28 PM
Looks great Doogs, and I like the pre-shading effect. I must admit I use many brands of paints depending on what I'm doing and what I have around at the time.
I've recently thinned Gunze acrylic with Tamiya Acrylic thinner, not sure if I liked it that much. I felt that something a little 'hotter' might be better,. What do you use ?
Cheers
Tony
I'm just taking it one GB at a time.
    June 2010
Posted by DoogsATX on Saturday, August 18, 2012 2:50 AM
Tony - I'm using Gunze lacquers (Mr. Color line) and thin them with Mr. Leveling Thinner. Can't easily get my hands on their Aqueous line so I'm not sure what thinners are compatible...
D.520 update:
Decals are on! Since I don't trust Tamiya decals, I picked up a sheet by Berna Decals, who I've never used before. They go on quite well - a bit resistant to moving around so place them carefully, but they're thin, don't tear or fold up, and seem to conform really well to surface detail.
This D.520 represents an Aeronautique Navale aircraft of Escadrille AC1 operating out of Algeria (Tafaraoui Airfield to be exact) in 1941...
    October 2008
Posted by bsyamato on Saturday, August 18, 2012 5:16 AM
Superb 520!!! another intresting subject
    April 2005
Posted by taxtp on Saturday, August 18, 2012 5:42 AM
Thanks Doogs, it's th other way here, I don't see Mr Color in the shops anywhere, except for the metallics for some reason the aqueous line is readily available. I think it must be the wholesaler.
Cheers
Tony
Posted by VanceCrozier on Tuesday, August 21, 2012 9:06 AM
DoogsATX
Not sure how well it worked as camoflage, but I love the look of those colours!
    March 2010
Posted by Scorpiomikey on Tuesday, August 21, 2012 11:24 PM
I think they were too busy surrendering to worry about the colour of their camouflage (I AM SO SORRY THAT WAS UNCALLED FOR AND INAPPROPRIATE)
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    June 2010
Posted by DoogsATX on Wednesday, August 22, 2012 2:03 AM
VanceCrozier
Well supposedly the German lozenge camo was really effective in WWI...this has some of the same hues going on so who knows? Though I'd be willing to bet the French put style first.
Had some fun tonight with some salt...
Oversprayed with a very thin mix of the gris bleu clair from the underside, then rinsed the salt off and threw down a coat of Alclad Light Sheen:
Posted by VanceCrozier on Wednesday, August 22, 2012 6:59 AM
hmmm - salt as a filter Doogs?? Hard to pick it up in the photos, how's it look "in-person"??
    June 2010
Posted by DoogsATX on Wednesday, August 22, 2012 10:11 AM
VanceCrozier
To be honest I think I need a slightly heavier coat. It was more pronounced with the salt staining before I put down the Alclad light sheen.
Posted by VanceCrozier on Wednesday, August 22, 2012 10:21 AM
ahhh - looks good in the close-up. I don't think I'd want the effect any heavier than that though. Most of these machines saw months of duty, not years, right?
    June 2010
Posted by DoogsATX on Wednesday, August 22, 2012 10:26 AM
Well...that's before the clear did away with the salt stains. It's much more subdued after:
As to service life, a lot of these D.520s actually served for years, from 1940 into 1942/43 (when the Free French got their hands on some P-40Fs and Ls). And in North Africa, no less. Not exactly the most hospitable of climates. Here's one example where you can definitely see the kind of fading and staining that they bore (especially evident near the base of the tail)
Posted by VanceCrozier on Wednesday, August 22, 2012 10:30 AM
Oh yes, the North-African machines kept on going, I was just basing that on the lack of Vichy-stripes. Yep, momre subdued after the clearcoat but it can still be seen. (Or maybe I just know it's there now?!?!)  That would be a great effect to try on a worn & weathered car, could be made to look like spots where wax has abandoned & paint has started oxidizing.
    July 2004
Posted by stikpusher on Wednesday, August 22, 2012 5:43 PM
Well I have not yet started my Rafale for this GB yet... but I did finally complete another French bird, my Mirage IIIEA for the Falklands GB, so I thought that I would share a peek at it here Wink
I have at least one more jet to finish before I can think about any new starts.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2008
Posted by bsyamato on Thursday, August 23, 2012 5:08 AM
Excellent mirage Stik Yes
Posted by VanceCrozier on Thursday, August 23, 2012 10:25 AM
Love how that one turned out Stik.
    June 2010
Posted by DoogsATX on Friday, August 24, 2012 8:18 AM
Excellent Mirage, stik! Jets typically aren't my thing these days but I dig that paint work!
The D.520's taken a few more steps toward completion. Some more salt fading, which will fade with the final matte coat...hoping to get to that tonight or this weekend.
Posted by VanceCrozier on Friday, August 24, 2012 8:34 AM
Love that salt-fading look. On the decals as well?
    July 2004
Posted by stikpusher on Friday, August 24, 2012 2:23 PM
Thanks guys!
Doogs, that D.520 is looking real sweet too! I loved building that kit! A great kit of a good looking fighter.
       - Plankton
LSM
    June 2010
Posted by DoogsATX on Sunday, August 26, 2012 2:01 AM
Sludge wash for the panels, final matte coat, unmasked the clear bits, started some chipping. Still have a lot of little things to see to, but this sucker's in the home stretch...
