Still Too Many Props GB - 2013
    August 2009
Posted by TREYZX10R on Wednesday, March 6, 2013 8:16 PM
B17Pilot thanks ,and yes I've been dry fitting ,shaping sanding and dry fitting again! I believe the fit is going to be okay at this point.
I'm happy with the floor and bulkhead fit now,still need to add a lot of details yet. For that reason I'm not hard glueing parts in yet. For fit reasons it was essential to get the front floor level and fitted first,after a lot of test fits its properly aligned and level now. The forward bulkhead IP assembly ties into the front floor nicely now and a test fit of the fuse halves shows no major alignment problems in this area now. This has been the most challenging resin interior I've encountered to date!
    August 2009
Posted by TREYZX10R on Sunday, March 10, 2013 8:41 PM
The next issue was dealing with the nose turret. The resin parts deal away with the kit mount and solid floor which was innacurate. I needed to scratch the support assembly and attachment point from styrene tube and square stock. A pretty straight forward affair and was fairly easy to align using the top hole on the chin turret as a guide for placement
gave a basic wash to the navigators station,once buttoned up most of this area will be entombed and not seen
Opened the Verlinden upgrade set and wow lots more resin goodies to add!
Another test fit of the fuse and all still fits well
Lots more to come stay tuned
    April 2004
Posted by cossack on Tuesday, March 12, 2013 3:49 PM
Looking pretty awesome Trey ... daunting standard to live up to!  I must get some photos up of my Beau.
    August 2009
Posted by TREYZX10R on Wednesday, March 13, 2013 8:25 PM
Thanks Paul,looking forward to seeing some of your Beau pics! Thats one on my to do list!
Even though this area wo'nt be seen in great detail once its entombed I could'nt just leave it as is. First I cut away this clunky blob of what ca'nt even be identifed and replaced the hole with some sheet styrene
Then after cutting down the kit supplied front table it was painted and glued in along with the support leg made from a standard wood toothpick
Next up was building the radio stack. I finally found a use for the resin mold bases,after some sanding they turned into suitable replacent boxes for the equipment.
Added some details and painted it
Finally installed
    August 2009
Posted by TREYZX10R on Monday, March 18, 2013 8:15 AM
I've been ordered to open the bomb bays so broke out the razor saw. The Verlinden update set included some nice brass doors with some rib detail added.
I had to adjust the nav/radio seat and desk position to a more 'scale' size and location
Then added some more radio detail and gave it a light wash to perk it up
Waist gun areas up next ,more True detail resin. The kit details removed with a dremel and the parts fit right in.
More nose detail added and more yet to come,the small resin bits to the left will be the bomb sight eventually
    September 2009
Posted by B17Pilot on Monday, March 18, 2013 8:21 AM
Trey, awesome job! Nice use of the resin pour stubs, I never thought about that. I did the same thing to the radio table on mine. I think I'm going to do that on all my B-17s from now on.
    August 2009
Posted by TREYZX10R on Wednesday, April 10, 2013 8:25 PM
I'm making some corrections in the waist gunner area ,had to remove some details first
Got it all sanded will start adding the corrected floor and replacing stringers next
    April 2006
Posted by waynec on Wednesday, April 10, 2013 8:30 PM
well i guess i best be about figuring out how to build stong wing mounts for the wings and stabilizers on my ME-264. hey bish i may even finish it this time.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
Posted by Bish on Tuesday, April 23, 2013 2:15 PM
I hope you can wayne. I would love to see one of these built up.
Just dug out my B-24, i will be starting that next, once my Me 262 is done.
Posted by Bish on Tuesday, April 23, 2013 2:16 PM
TREY, looks like you got a lot of work going into that.
    September 2009
Posted by B17Pilot on Friday, April 26, 2013 8:53 AM
I have started my B-26. By started I mean, I sprayed things interior green, cause I had to spray that color on one I was finishing, and I figured, why not just spray the B-26? Been sitting like that for a couple of weeks as I finish up a couple of others for a show in two weeks.
    April 2004
Posted by cossack on Monday, April 29, 2013 6:17 PM
OK all ... despite my silence, I have (FINALLY) been able to finish my Beaufighter.
Sorry there were no "Work In Progress" pics.  Painted using predominantly Tamiya colours (scheme was easy - Med Sea Grey and Sky!!).  Decals are aftermarket.  Otherwise built out of the box.
So its a Tamiya 1/48 Beaufighter, done to represent a 489(NZ) Squadron aircraft - part of the Banff Wing. As a Kiwi, this aircraft goes towards a representative "squadron" to represent the seven NZ squadrons serving in the RAF during WWII.   So now have completed 485 (Spitfire Mk XVI), 486 (Tempest), 487 (Mosquito), 488 (the Singapore edition - so a Buffalo), and 489 (the above).  That just leaves 75 and 490 (Wellington and Sunderland respectively).  Those two are going to have to wait until I have a LOT of space to display!! :)
I hope you enjoy ...
Posted by Bish on Tuesday, April 30, 2013 1:30 PM
Paul, nice looking build.
    August 2009
Posted by TREYZX10R on Tuesday, April 30, 2013 8:07 PM
Real sharp looking Paul !
    April 2004
Posted by cossack on Tuesday, April 30, 2013 8:30 PM
Thanks gents.
Was fun - I have just a couple of regrets:
1.  I could not find a definitive reference for this aircraft as to the alignment of the Yagi radar in the nose - I went with vertical, cos I thought it looked best.  If it ever gets snapped off, I might change my mind :)
2.  I prefer painting on the identity stripes.  This caused me two problems.  Firstly, I didn't consult my reference material (i.e. the Tamiya instructions!!), so blindly masked up, and painted standard fighter stripes first.  Only to THEN see that these were too narrow.  So out with the stripper, sandpaper, etc, and repaint / remask /repaint.  Lesson learnt!!  But the one thing I did not go back to fix, is that I did not allow for the faint register of the while on the side roundels.  So the black does sorta show though, if you look closely.  So memo to self - make sure I leave mask off white for under the roundels next time!!
    September 2009
Posted by B17Pilot on Thursday, May 2, 2013 8:55 AM
Nice Beaufighter! Looks great! Got me one of those kits, I'll get to eventually. Front page updated.
Posted by Bish on Saturday, May 4, 2013 11:54 AM
Coming along nicely TREY, nice work as always.
    September 2009
Posted by B17Pilot on Tuesday, May 7, 2013 10:38 AM
Awesome job on the tail wheel! Don't forget the wood planks used for the floor in the waist area
    April 2004
Posted by cossack on Tuesday, May 7, 2013 9:39 PM
Looking good Trey :)
    April 2013
Posted by SchattenSpartan on Friday, May 10, 2013 6:02 PM
A lot of nice looking models here!
I have to join this one as well (those GBs are addicting as hell)
I'll build a B-25D Mitchell. It's the AM kit reboxed by Academy. It says B-25G on the box, but you can build a B, C, D or G model out of it.
As far as markings go, I'm most likely going for a rather unconventional nose-art:
A B-25D called "Yankee Warrior". It is stationed at the "Yankee Air Museum".
You can look up it's story here: http://www.clubhyper.com/reference/b25flightse_2.htm
I'm afraid I wont be able to replicate the Waist guns on my model, as they aren't supplied in the kit...
Clemens
    September 2009
Posted by B17Pilot on Friday, May 10, 2013 8:46 PM
Welcome! Looking forward to your Mitchell!
    April 2013
Posted by SchattenSpartan on Saturday, May 11, 2013 3:20 AM
I hope I can start the build in July (the Mitchell will need untill the end of June to get here, sadly...)
Clemens
Posted by Bish on Monday, May 13, 2013 12:34 PM
That will be a nice build, how come it will take so long to arrive.
    April 2013
Posted by SchattenSpartan on Monday, May 13, 2013 1:11 PM
I don't know, Bish
The owner of my local store just got a message that there are some problems with the availability of this kit and he won't recieve it this month. And the next order he will place will be in June so it wont get here before the end of June.
But I have a lot of other birds to build untill it arrives so I'll be busy anyways.
Clemens
Posted by Bish on Thursday, May 16, 2013 1:07 PM
Right, I see now. I am sure it will be worth the wait.
    April 2013
Posted by SchattenSpartan on Thursday, May 16, 2013 1:23 PM
I hope so! The decalsfor this are going to be an interesting project on their own!
Clemens
    August 2009
Posted by TREYZX10R on Tuesday, May 28, 2013 7:32 PM
    April 2013
Posted by SchattenSpartan on Wednesday, May 29, 2013 6:08 AM
Thats a nice looking fortress, Trey!
I want to build one so badly, but it seems like the Revell kit needs some major improvements. I'll just wait untill the big one from HK-Models comes out... Stick out tongue
Cheers, Clemens
    April 2013
Posted by SchattenSpartan on Wednesday, May 29, 2013 6:38 AM
Look what I came across:
www.themodellingnews.com/.../now-this-is-large-scale-modelling-folks.html
I NEED that kit!!!
Clemens
