Longest Day GB
Posted by Bish on Friday, September 13, 2013 6:35 PM
Jack, welcome aboard, I like the dedication. So if I am looking at that right, the only part from the Tamiya kit is the turret. I have not done a resin armour kit, will be interesting to see this one. I will add you to the roster.
    September 2013
Posted by Raven728 on Friday, September 13, 2013 7:38 PM
Those finished Steel Cats GB models are unbelievable. Compared to those, my models look like they were built by a hyperactive 6-year-old. Embarrassed
- Steve
Posted by Bish on Friday, September 13, 2013 7:46 PM
Raven728
Ye, theres some stunning builds over there. But I am sure yours will be just fine.
    April 2006
Posted by waynec on Saturday, September 14, 2013 12:07 PM
hey bish
put me down for a german 150mm towed field gun. dark yellow and going to try some freehand A/B camo and also multiple layers of washes as explained in the ARMOR T-62 post
heard from eagle90. he is trying to figure out how to get a SATURN V home from florida.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
Posted by Bish on Saturday, September 14, 2013 12:20 PM
I just got a message from him as well. Seems he managed to escape Duffy's clutches.
I am assuming the gun is 35th scale, which kit is it.
    April 2006
Posted by waynec on Saturday, September 14, 2013 12:59 PM
DOH!!!!! cyberhobby 1/35
Posted by Bish on Saturday, September 14, 2013 1:03 PM
O, nice. Looking forward to seeing this. Are you building one from one of the German Div's or is this a part of the fortifications.
    April 2006
Posted by waynec on Saturday, September 14, 2013 1:41 PM
field gun. at least some green camo, maybe some brown too. probably not the crew. fixin' to get all the gray painted on the inside and deck of LCVP.
Posted by Gamera on Saturday, September 14, 2013 6:35 PM
Ohhh very cool Wayne.
Posted by Bish on Sunday, September 15, 2013 7:43 AM
Looking forward to seeing more of it wayne.
    April 2006
Posted by jgeratic on Sunday, September 15, 2013 4:00 PM
Bish, yes you are right in that the Tamiya Firefly turret is the largest single piece that will be kept with the build.  I know I will also utilize their tracks, wheels and boogies, and a quick glance  shows the resin hull deck requires the crew hull roof hatches as well.  I've also a couple PE sets from Hauler and Part.  As  seen, I've already  attached the AM barrel from Armorscale.
Today I started cleaning up the resin parts.  The hull floor is a bit wonky,  on one side, the center curves outwards, while the opposite is slightly curved in.   Could be just the nature of the beast, or a quality control issue.
regards,
Jack
Posted by Bish on Sunday, September 15, 2013 4:10 PM
Does look like a bit of bad casting there. I've only used small resin pieces so far, from AM sets. Though I do have a couple of resin aircraft to build. But I see no reason for poor casting like that, especially given the cost of resin. So my guess is poor quality control. Looks like it could have been a wonky mould.
Posted by Gamera on Sunday, September 15, 2013 4:53 PM
Hmm, wonder if it warped during cooling maybe? Looking forward to seeing her come together Jack, I've never really used that much resin in a project.
    May 2005
Posted by pyrman64 on Sunday, September 15, 2013 9:20 PM
Jack: You probably won't be able to use the Tamiya tracks from the M4 - the M4A4/Sherman Vc had a longer hull than the others in the M4 series.
Greg H
"There is many a boy here today who looks on war as all glory, but, boys, it is all hell." Gen. Wm T. Sherman (11 April 1880, Columbus, Ohio)
    April 2006
Posted by jgeratic on Monday, September 16, 2013 3:26 AM
Thanks Greg, I wasn't aware of the different lengths until I put the hulls side by side to compare detail. I wondered why the resin set had some extra track links, so hoping the ten they provided will be enough to make up the difference.  If not, what style track links should I shop for?
Four pieces are now glued together.  I didn't bother sanding too much of the 'yaw' shape of the floor as it won't be noticeable.  Another problem area now is one side wall comes up short, (interestingly it is on the convex side of the curved floor edge).
 Dry fitting the transmission housing, it looks it can be corrected by placing a shim in the space.  Next bench session will take a closer look to see if a little more sanding can close the gap, and make sure every angle is perpendicular.
Won't say I've bit off more than I can chew, but this resin set would be more enjoyable to someone such as a shermaholic - lol. Propeller
regards,
Jack
Posted by Bish on Monday, September 16, 2013 12:44 PM
Kits with problems like this can be tough at the best of times, but when its not your preferred subject, it can make it a struggle to keep going. But I am sure you can sort this out.
Posted by Gamera on Monday, September 16, 2013 12:58 PM
Yeah, the M4A4 had the Chrysler 'Multibank' engine - basically five truck/lorry engines bolted together into a single power unit. Most of these mechanic's nightmares were dumped on our allies... sorry! These engines were longer than the aircraft engines used in the other models forcing a longer hull.
Not sure about the tracks but the areas with poor fit could always be covered with a little mud build-up!
    January 2013
Posted by jibber on Tuesday, September 17, 2013 8:28 AM
Waynec, are things any better in your area? I'm seeing some horrific things on national news.
    April 2006
Posted by waynec on Tuesday, September 17, 2013 9:40 AM
hey jibber
we are fine where we are. up north still getting creamed. also SW colorado around 4 corners and northern new mexico has flooding. the flood waters are as far east as nebraska  border and they are still helo lifting folks out of the canyons. people are starting to return home which usually means guttting the entire interior of a house; drywall, carpet, furniture, freezers assuming they even have a structurally sound house. to add to the difficulties is lack of power, water, sewage and roads. lots of roads and bridges destroyed so you can't even get into towns to start anything or bring in heavy equipment. with winter coming many roads and bridges won't be repaired until next summer. plus the tourist industry in the area and the farming have been decimated. many will never recover. this is hurricane type damages.
Posted by Gamera on Tuesday, September 17, 2013 9:43 AM
Yuck, glad you escaped the worst of it.
    January 2013
Posted by jibber on Tuesday, September 17, 2013 11:25 AM
I'm really sorry to hear that and our thoughts are with those who need it the most. All the best.
    July 2013
Posted by bitbite on Tuesday, September 17, 2013 8:54 PM
Ok. The last paint I needed to finish my model arrived today. Painted the goggles and here it is. Does it look finished to you guys?
"Resist the urge to greedily fondle the parts . . ." - Sheperd Paine "Modeling Tanks and Military Vehicles" Page 5
    April 2006
Posted by jgeratic on Wednesday, September 18, 2013 2:46 AM
bitbite - looks good to me - if you're happy with it, I'd call it done.  I do notice a sheen on the  turret top, was this photo taken in direct sunlight?  That could be washing out some detailing you have done.
regards,
Jack
    July 2013
Posted by bitbite on Wednesday, September 18, 2013 7:07 AM
Yes, it was.  I'll take a betterr one once I hear from Stik (my advisor).  I was in a hurry yesterday.  Smile
Posted by Gamera on Wednesday, September 18, 2013 7:34 AM
Look finished? Looks perfect to me!
Great job on the storage, the dirt on the running gear, and the commander.
    January 2013
Posted by jibber on Wednesday, September 18, 2013 7:53 AM
I love the shading and the tracks are perfect. Do you have any close up shots, I'm dying to see more. Bit I think this is a great build for the group.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, September 18, 2013 9:23 AM
Well I finally got the paint (and more) I needed to order for my Spitfire. Along with that order, I decided to take a chance on Model Master Black Detail Wash. That being said, I was able to resume builing and painting the cockpit of the P-47 Thunderbolt 'Bubbletop'. I did a test run on how this wash works on an old scrap jet kit (same one I practiced using an airbrushfor the first time) and was pleased somewhat. I thought, "What the heck... let's give it a go on the 'Bolt."
I used the wash on the cockpit, landing gears, wheel hubs (haven't done so yet), wheel wells and gear doors. So far, I didn't think it looked too bad for a first time attempting a wash. I will post pics as soon as I can.
Seeking advice - I'm thinking of painting the Invasion stripes instead of using the decals to give it a more realistic look. Would measuring the invasion stripe decal's overall width by masking the areas white first then split it up by masking where the black stripes would be the way to go? The aircraft fuselage overall color will be bare metal silver.
Also - what would be the best way to create a weathered wash on the white stripes? Would using a Dirty White wash work or simply use a black wash throughout the aircraft?
Knowing decals stick better on a gloss coat, do I need to spray another coat of gloss once the decals on  before doing a wash? I am planning on putting a final finish using a flat clear coat.
** My goal is to order a couple washes by Flory (black soot and either mud and/or dark earth brown).
Any pointers or suggestions will be greatly appreciated.
    October 2009
Posted by greentracker98 on Wednesday, September 18, 2013 12:23 PM
Black Sheep - Is your P-47 a tamiya kit? I'm doing the same. bare metal finish and thinking of painting the invasion stripes.
So, i'll have to keep a watch on this question
A.K.A. Ken                Making Modeling Great Again
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, September 18, 2013 12:56 PM
Yes it is. Doing one with different code numbers
    July 2004
Posted by stikpusher on Wednesday, September 18, 2013 1:55 PM
Black Sheep, yes invasion stripes are best painted by doing the white first, masking them off, then painting the black ones.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
